Question about Sony PlayStation Portable (PSP) Console
Psp doesn't turn on
The psp doesn't turn on, the green light flickers once and thats it. HELP
  • Eric Sanchez May 11, 2010
    where you updating your psp at the time then turned it off? if so you have a brick you will probably need pandoras battery or you have to buy a new psp.
    Problem Solver:
  • 5 Answers
Oh you have the famous black screen of psp, the black is screen in some cases means death but this problem have 2 solutions no more. First if you do a backup of your nand restore it. Second use the memory stick magic and the battery pandora to restore your files default. If you have no idea what i'm talking about contact me. I'm from guatemala i will help you with the process
Mago
Bye:-)
Posted on Jul 24, 2008
Need help my psp is not working when I turn on I can only see the green light no sounds no display just green light and after a few seconds later it turns off the last thing I did I update with something...
First you have to take out the battery and use charger to turned on and when it turn on just put on the battery or take out the battery and wait for minutes then put it on and tur on,if that doesn't work when you turn on just hold R and start or repair it
Feb 06, 2013 | Sony PlayStation Portable (PSP) Slim...
Hi My PSP's orange ligth won't turn off just always lightning when turn on my psp it's lightning with green light
Hi khangal74,
If you dont have issues playing your usual psp games, you dont have to worry about the orange light. That is normal. It means that your PSP is saving the data to your memory stick. Also make sure that your WLan switch is turned off ( that also causes a blinking orange light ). However, if you are experiencing a flickering orange light and your screen remains black ( and you cannot play any games), it means that your PSP is having issues reading you memory card.
Do these:
Remove the memory card and turn your PSP on without the memory card (it should turn on with no problems) Now, slowly re-insert your Memory stick. (You may need to do this several times until your PSP recognizes your memory card) If this still does not work, your Memory stick is busted or may be infected with a virus and therefore needs to be replaced.
Wishing you with positive results. All the best to you.
Jul 23, 2011 | Sony PlayStation Portable (PSP) Console
Hey, i have a problem with my sony PSP when i start my PSP the green power light is on but there is nothing to display and the memory stick light keeps flickering too , please help ???
Hello there
You'll need to hard reset your PSP and restore it to its factory settings. Once this is done, your PSP should work perfectly.
Hold the power button on the right side of your PSP down until the device completely powers off. Wait at least five seconds after the power is off before proceeding to the next step.
Press and hold the Select and Start buttons located in the bottom right corner of the PSP.
Press and hold the Square and Triangle buttons (located on the directional pad) while continuing to hold the Select and Start buttons.
Press the power button while holding these four buttons. When the flash (logo) screen appears, you can release the four buttons and your PSP will be reset to its factory settings and the screen will no longer be blank.
Oct 10, 2010 | Sony PSP (Piano Black)
My PSP will not turn on unless it is plugged into the outlet. When I try to turn it on by itself the power light flickers green for two seconds and then disappears. Also, the battery is fully charged. When...
replace the battery as it may be out of CYCLES even tho it says its fully charged if the battry is new your going to need a new element inside usually this consist of a new logic board under the battery pack.
good luck
Apr 27, 2010 | Sony PlayStation Portable (PSP) Slim...
Psp whont turn on
your psp is bricked. I did that once and it happened to me but i unbricked it by installing custom firmware 3.71 M33-2 with a magic mem stick and pandora battery. =D
Apr 18, 2009 | Sony PlayStation Portable (PSP) Console
Problem loading the NEW PSP ACTION REPLAY.
TADA! answer 4 u.
It's your battery. Take out your battery from the psp and look on the back of it. If, at the top, it says PSP-S110 and at the bottom it says made in China, be bummed. That's what mine said and the codejunkies website warns about that battery. Dunno where to get a new one though. Hey, diagnosing the problem is half the battle. Good luck.
Dec 03, 2008 | Video Game Consoles & Games
Psp broke
i dont believe this is a bricked issue. it cold be a short on the board or wiring some where inside. this noticable if it works after you lightly tap it like mine. but once it comes on it usally will stay on tapping a briked psp does nothing.
May 19, 2008 | Sony PlayStation Portable (PSP) Console
Psp won't turn on
im am soorrrry but go to gamstop and buy a new battery thats all
Apr 16, 2008 | Sony PlayStation Portable (PSP) Console
Psp
There are batteries that at 20% of charge left go off and keep blinking if thats your problem, just connect ac cable den put battery and restart manually. I have a similar battery
Dec 12, 2007 | Sony PlayStation Portable (PSP) Console
PSP
Your psp has bricked use 'pandoras battery' to flash it back to firmware 1.5
Dec 11, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
