I have a 2006 PT Cruiser. I need to change th light bulb in my brake light. Can I just change the bulb or do I have to buy a new entire rear light?
The bulb in the rear light has burned out and to replace it follow these instructions: 1) go to your owner's manual to find out the part number. You can find and purchase the replacement bulb at Target, any auto parts store and even at Walmart for under $4.00; 2) pop open the trunk door; 3) get a phillips screw driver and unscrew the 2 screws holding the rear brake light fixture to your car body; 4) as soon as you turn over the fixture you'll see where to pull out the burned out bulb and replace it with the new one(s). Good luck!
Actually, that solution is not entirely true. I have a 2006 PT Cruiser base edition and my driver side brake light blew out. You need a T40 torx screwdriver and look up the bulb. Once you remove the single torx wrench, then slide the whole assembly down. This will release a tab at the top of the brake light assembly. Pull the assembly out (there are clips on the side) and then you can remove the brake light. It twists out of the light assembly. Good luck!
2003 pt cruiser
2006 pt cruiser engine died
Where do I go to see pictures of symbles of problem with my pt cruiser yellow light
my 2006 pt cruiser shows p0016 and p0508
how do I check the transmission in my 2006 pt cruiser
brake lights not working
Where do I plug the insurance monirtor into a 2006 PT Cruiser
all light s working but brake lights. Fuse is good.
fuse and bulbs are good.
when i press down on the brakes the brake lights don't work
