Question about Bissell 9400 ProHeat Upright Wet/Dry Vacuum
How to use it?
I lost my manual and I do not know how to use the machine. Where do I pour the liquid cleaner and which are the steps to follow to make it work?
Thank you
  • Anonymous Oct 17, 2008
    I need to know how to use this.
Hello i have vacuum i dont know how to use it
Posted on Aug 28, 2008
Why has my cleaner stopped working.
You did the right thing; you could get shocked when wet.
Jul 03, 2015 | Vacuums
Tip
How To Fix Your Bissell Carpet Cleaner When Solution Doesn't Spray
If you have a Bissell Carpet Cleaner, and you're machine is not spraying water on the floor, there are several things that might be causing this. Here's a list of possible problems that might be causing the machine not to spray water:
It may be a problem with your pump belt. Bissell Carpet Cleaners use a belt that powers the pump to spray solution out. There are also a few other possible issues, but as a Bissell warranty station, the belt going bad out-numbers all other problems.
Remove the belt access door and inspect the pump belt to ensure it is not broken, worn or stretched. You may also check the belt by turning on the power and watching the brush on the bottom of the machine. If the brush rotates the belt is not broken.
If your belt is worn out or broken, here's a direct link to that belt on our website:
Bissell Pro-Heat, Pro-Heat 2 6960W Replacement Pump & Brush Belts
Here's a great video that will show you how to check, and replace the pump belt on your ProHeat carpet cleaner:
How To Replace the Bissell ProHeat 2X Carpet Cleaner Belt Video:
http://www.bissell.com/VideoRating.aspx?id=1555
If this was not the problem, here are some other things that you may check:
  • Make sure there is liquid in both the Tank-in-Tank and the SmartMix bottle. Both tanks must contain fluid or the machine will not spray properly.
  • Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
  • Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized and the cap will not make proper contact with the unit. If there is no liquid present, you will need a replacement SmartMix Bottle.
  • Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
  • Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. (Bladder or SmartMix bottle may be empty or the valve may be blocked internally.) Use a soft-bristled brush and hot tap water to clear any debris. Replace autoload assembly or cap/insert if necessary.
  • Check if the small rounded window tabs on the top edge of the Floor Nozzle are locked in their mating slots on the base of the machine, and not inadvertently lifting the tank up out of place.
If these suggestions have not resolved the problem you are experiencing with your machine, you might want take your machine to a local BISSELL Authorized Service Center. I really hope that this information was helpful to you. If you find what's wrong with your Bissell and have specific questions about how you can fix it, please just let me know and I'll be happy to walk you through step by step to fix any problem you may have on your Bissell.
Thanks,
Chris Jones
GoVacuum.com
on Apr 12, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Tip
How To Fix Your Bissell Carpet Cleaner When Solution Won't Spray
Thanks,
Chris Jones
GoVacuum.com
on Apr 12, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
My machine is not putting out water or sucking anything up
Please try these suggestions to get your machine working properly:
Make sure there is liquid in both the Tank-in-Tank and the SmartMix Bottle and check for spray through the upholstery hose. If the hose does not spray please check the following:
- Remove the belt access door and inspect the pump belt to ensure it is not broken, worn or stretched. You may also check the belt by turning on the power and watching the brush on the bottom of the machine. If the brush rotates the belt is not broken.
- Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
- Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized, the cap will not make proper contact with the unit and the smart mix bottle will need to be replaced.
- Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
- Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. Bladder or SmartMix bottle may be empty or the valve may be blocked internally.
- Check if the small rounded window tabs on the top edge of the Floor Nozzle Window are locked in their mating slots on the base of the machine and not inadvertently lifting the tank up out of place.
If these suggestions do not solve the problem, please have a technician at a local BISSELL Authorized Service Center inspect your machine. BISSELL supports your machine with a one-year warranty for any defective or malfunctioning part.
Sep 26, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
It wont spray the water on the floor.what do i do
Try these suggestions to get your machine working properly:
Aug 05, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My bissell steam cleaner will not spray any water
Check to ensure there is liquid in the water tank and the formula bottle.
Note: This machine will spray with liquid in the Water tank only if the machine is set to the Water Rinse setting. On any other setting, you need to have liquid in the formula tank as well.
If no: add liquid to the Water tank and the Formula tank.
If yes: check each of the following....
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
-If everything is seated and attached properly, prime the machine by turning off the power, waiting one minute, and then turning the power back on and depressing the trigger on the handle.
- If priming the unit fails to fix the problem, remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
Jun 15, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
How to release and withdraw water solution to clean carpet.
Problem resolved by contacting a local retailer who provided instructions.
Dec 30, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell Steam Cleaner Model1694.Where to put soap?
The detergent will have to be poured directly into the water tank by using the measuring cup that is attached to the back side of this unit. I have a manual for you that you can print out as well.
Click here for your manual.
Mar 10, 2009 | Bissell 16943 Powerlifter Wet/Dry Vacuum
T2100 S Ladybug Canister Steam Cleaner
Visit the Ladybug Ladybug 2200S Vapor Steam Cleaner page and scroll to the bottom. There's a link that says, "Download owners manual."
Oct 20, 2008 | Vapor T 2200S LadyBug Canister Steam...
Bissell 9400 ProHeat Upright Wet/Dry Vacuum Logo
145 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
