Projection Televisions
Problem for Projection Televisions
Generic problem for all Projection Televisions
I have a 27 inch
By bwwolf on Jul 14, 2008
I have a 27 inch panasonic and have about 19 real thin lines across the top of the screen. It is in the top 4 inches of the picture tube.Model CT-2701G Built 9/03
Comments:
Jul 15, 2008
- Thanks for the fast response.
Best Solution
posted on Jul 14, 2008
Very Helpful)
Yazz226
Rank: Guru
Rating: 86%, 232 votes
how long hav u been havin this kinda problem
Comments:
Jul 14, 2008
- does the thin strip change size?
Jul 14, 2008
- it shud be a convergence problem..ie.if the strip does not change size
Jul 14, 2008
- or the horizontal line is a "collapse of field" and is usually caused by a dry solder joint, be very careful if you attempt a repair yourself (if you can find the suspect solder joint) because extremely high voltages are in certain areas of the circuit, especially in the line output stage. i suggest u get the help of a professional
Thanks for using Fixya
Rating Locked! (?) bwwolf has rated this solution as Very Helpful
Solution #2
Not Rated)
Jaime867
Rank: Guru  Televisions & Videos  Expert
Rating: 88%, 985 votes
This fault is located in the vertical section of your TV. It has leaky capacitors nearby the vertical output IC # 401 thai is mounted on a heatsink. Check C414, C417 and C427 with a capacitance meter, if you do not own one just replace them all.
Let me know if you need further assistance.
Comments:
Jul 14, 2008
- Find the location of the IC# 401 with the following markings: LA78041
Jul 14, 2008
- The mention lines of your TV can't no be adjusted using the remote or any other adjustments will work until the defective parts have been replace.
This might not be a DIY due to the danger of working with high voltage device such as TVs. High voltages are in excess of 32KV.
Solution #3
Not Rated)
maklean
Rating: 86%, 652 votes
Scan coils (field) measure about 5 to 15 Ohms from the plug where they connect to the main PCB
Look for the cables that come down from the scan coils (deflection yoke) to the main pcb
its either two cables and two plugs or a 4way cable with one plug to the main pcb
2 of the wires goto the vertical(height) and 2 to the width
try to work it out which (the fattest wire is width)
The width ones go towards the loptx(line output/flyback transformer),
and the height ones go to the field output chip (or transistor pair) Follow the printed circuit from the plug and look for a 7 or 9 pin chip on a cooling plate(heat sink for the posh),
it should have a diode connected to it and about 25v on both ends of the diode.
Comments:
Jul 14, 2008
- If the 25v is missing there is usually a fault in the chip, which blows the protecting resistor which takes the power from the loptx.
so follow the print back from the chip/diode to the loptx pins, and test all the small fusible resistors on the way, and replace as required.
If the 25v is ok its usually just the chip or no drive from timebase chip.
if the 25v is low and the chip is warm/hot then the chip is duff
whilst doing all this pcb track following check for bad joints.
If the 25v is ok then we need to look at the field_timebase_chip supplies (usually +12v)
Finding this chip can be fun, I usually guess, and test all the pins and find none have power, so then I go back to power supply or line derived power, and look for regulators
After repair leave it run for a few minutes and switch off and see if its getting hot,
if it is, there is something else wrong.
check/replace the electrolytic caps nearby and make sure the supply voltage is not too high (25v is usual)
if the line across is wavy then check the field scan coils for open circuit (right back to the plug)
Solution #4
Not Rated)
sweet_rascal
Rank: Wiz
Rating: 81%, 777 votes
dos the lines go and travel watery??
or do they remain still??
and are the lines like solid bars?
Comments:
Jul 14, 2008
- Take out the comb filter and replace the surface mount electrolytic capacitors (I think there were around 4 of them) on the comb filter and put it back in the motherboard.
Replace the electrolytic capacitors in the power supply section.
start with replacing (2) 860uf 180v caps just after the bridge rectifier and continue along the circuit.
Some (15) or so capacitors later, it will finally clear the the horizontal bars and lines
thank you sir
dont forget to rate the solution
have a great day
Popular Solutions for Projection Televisions
Questions and Unsolved Problems for Projection Televisions
Answer
i HAVE A 47" PANASONIC REAR PROJECTION TV. pURCHASED NEW FROM CIRCUIT CITY DEC 2001. wORKS... (More)
Answer
My 65" projection TV suddenly has snow on stations 1-6 and 95 Plus. All others are crystal... (More)
Answer
what is the right combination of buttons to start up the wd-52628
Answer
I have a Mitsubishi ws-55859 and got a code 22. If there is any way i can get instructions on what... (More)
Answer
how do i reset a philips rear projection tv 43P8341
Describe your Projection Televisions problem:
Select a Category:
Related Products & Issues:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in Dallas, TX
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Your name:
Your email:
Your friends email addresses: (e.g. Julie@email.com)
(Separate email adresses with commas)
Message:
Cancel
