Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Contact look up not working
I don't know if my phone is faulty or there's a trick to the contact list look up.To find a contact I have to scroll through the whole list. I should be able to press the first letter of the name I'm looking for and then scroll through a couple of enteries.
I did a master reset and know it works the way it should
Posted on Jul 15, 2008
HOW DO I ACCESS MY REJECT LIST ON MY SAMSUNG GT-E1270
try this: (A complete guide on how to block/unblock a number)
1. From the home screen, press Menu.
2. Scroll to Settings, then press Select.
3. Scroll to Applications, then press Select.
4. Scroll to Call, then press Select.
5. Scroll to All calls, then press Select.
6. Scroll to Auto reject, then press Select.
7. Press Options.
8. Scroll to Create, then press Select.
9. Press OK.
10. Scroll to the required option (e.g. Contact list), then press Select.
11. Scroll to the required number, then press OK.
12. Press Options.
13. Scroll to Save, then press Select.
14. The number has now been blocked. Click Next to continue.
15. To unblock a number scroll to the required number, then press OK.
16. Press Options.
17. Scroll to Save, then press Select.
18. The number has now been unblocked.
Aug 18, 2016 | Samsung GT-E1270 Black Mobile Phone -...
Tip
Delete Contacts Fast Apps Iphone
<img src="aitwa3el_2.jpg" /><br />1. Quickly select and delete multiple contacts<br />2. Search contacts by name or phone number.<br />3. Select all contacts on search result at once, (also you can deselect all)<br />4. With selected list, you can check contacts before deleting them.<br />5. With Easy Select, you can select name duplicated, no email address, no phone number contacts at once.<br />6. With number scroll index and sorted list by name, you can fast scroll and find contacts.<br /><a href="http://2c82bc70.linkbucks.com">DOWNLOAD</a><br />
on May 30, 2011 | Cell Phones
How do i autoreject number on my sony ericcson wti9
Blocking incoming calls on your Sony Ericsson phone is pretty simple. You can go to your service provider's website and follow the instructions they have for call blocking. They will usually tell you how to block specific calls or all incoming calls. You will most likely find a way to even block incoming text messages. This is very convenient if you don't won't to be bothered, but you don't want to miss a possibly important call either. Luckily, with a Sony Ericsson, you don't even have to go to your service provider's Web site to block incoming calls. You can do it through your phone's menu.
    • 1 Flip open your cell phone and go to the phone's menu.
    • 2 Select "Settings" and scroll down to "Calls."
    • 3 Select "Manage Calls" and then choose "Accept Calls."
    • 4 Choose to accept "All Calls," "Calls from a list" or "None." If you choose to accept calls from a list, you will have to create your list of accepted callers. This is easy. You will just scroll through your contacts and select numbers you want to accept.
Feb 09, 2012 | Cell Phones
How do i put someone on the call reject list on a quickfire by AT&T?
If you don't want to receive some calls, you can add them to the reject list. Follow the steps below:
First, open the Recent Calls menu by pressing the Call button.
Scroll to the unwanted call and press the Options soft key.
Scroll to Add to Reject List, press Select, and confirm the selection.
I am very sure it will work for you.
Bye.
Jun 15, 2011 | AT&T Quickfire Cell Phone
I have HTC Wildefire, when I receive an sms, I get only phone number in international format but no name of contact. knowing that the contact is saved in my address book.
HI there!
This is a pretty common issue. The trick is to save the numbers in your contact list in the format you receive the texts in, for example here in canada the format would be 1-xxx-xxx-xxxx and this would show up on the phone as +14038486756. Either save the number from your text messages OR change the ones in your contact list and you should be set!
May 04, 2011 | HTC Wildfire Cell Phone
I need to blocka number on my samsung seek.!!!
please check this feature in your phone menu. If there is, use it to block/black list /screened certain numbers. Check also your wireless service provider. They have make this feature available. In contrary your setting will cancelled.
Apr 30, 2011 | Cell Phones
Faulty mobile phone
hey cant say for sure whts the problem buddy, try using ur battrey with other similar type phone if it doesnt works with it then its battrey change it. also try to format ur phone using this code *#7370#
May 21, 2009 | Nokia 6288 Cellular Phone
Change ringtone on cect i9
1. At the main menu, select “Settings”
2. Now select “User profiles”
3. In the next menu, select “General”
4. Now “Customize”
5. Select “Tone setup”
6. Choose which SIM (on dual SIM card phones) you want to assign a ringtone to.
7. You will now see a list of available ringtone.
8. Select it.
You should see at the very bottom of this list 5 empty locations this is where you can add your own mp3's as ringtones.
Now I Know your second question once you get this figured out will be how to assign ringtones to individual contacts in your phone book so here is part 2. 1. From the Main menu choose Phone
2. Choose Quick search
3. Find the contact in the list you want to add the ringtone by scrolling down the list and tap on their name
4. Choose Edit
5. Scroll down the list of options to the Musical note called Associate sound and select the ringtone from the list.
Your new ringtone will now function for that contact whenever they call!
Apr 15, 2009 | Dual Electronics CECT P168 Cellular Phone
How to add stored phone numbers. I lost my manual.
From the standby screen, press Menu.
Scroll to and select Address Book.
Scroll to and select Contact List.
Scroll to desired contact, press Options
Scroll to and select Edit
Edit the desired fields, press Save
Feb 01, 2008 | LG CU400 Cellular Phone
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
18 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
