Question about Frigidaire GLRT216TA Top Freezer Refrigerator
Frig is not getting cold!
The refrigerator worked while it was in the garage. When it moved into the house it stopped working. The lights are on but it is not getting cold even though the temp settings are set to cold? What can I do?
  • martyqwsw Jul 14, 2008
    Model FRT885EW2 fridge and freezer not cold enough light is still working.
  • notcold Jul 14, 2008
    It was transported upright.
  • 89 Answers
How did you transport refrigerator? Standing straight up, or laying on its side???
Posted on Jul 14, 2008
  • Brian Gillespie
    Brian Gillespie Jul 14, 2008
    It sounds like the compressor isnt running. Most common problem with the compressor not running is the relays (located on the side of the compressor). You can buy relays cheap. (R041) is the type of relay you will need. If the relay doesnt get the compressor to work then you may have a bad compressor....(refrigerator would be junk in this case)....
    Note: Relays can be put on the compressor with a little common sense, BUT I do suggest having a professional do this for you! Always unplug refrigerator while messing with anything in the compressor department!
    If you insist on fixing this problem yourself... You can order this part at:
    http://www.gofarappliance.com/parts
    After recieving the part feel free to write back if ya have trouble putting the relay on and I can reference you to a tech page,...
    Goodluck, Brian
How do I keep my refrig/freezer from defrosting in the winter when store in the garage.
There is only one source of cold in many refrigerators. If yours is a top freezer, then most likely it is in the freezer.
But the thermostat that you set temperature with is in the refrigerator, not the freezer.
In the cold garages, what can happen is that the refrigerator stays cold enough that it does not call for cold. So the freezer does not get enough cold.
The freezer control works by diverting cold air into the freezer WHEN THE RERIGERATOR HAS TURNED ON THE COOLING. If it is not turned on, oh well.
The best you can do for this is to put both on max cold. Then the refrigerator will call for more cold at a lower temperature, and the freezer will get it more often and will divert more when it is cooling.
This can result in the refrigerator freezing things too. You can try raising the refrigerator setting JUST A LITTLE and see if both work, but keep freezer on max cool.
This works for my situation, but ambient temperature fluctuations in the garage make this dicey. We don't put things like lettuce in the refrigerator in the garage in the winter because freezing damages them.
Good Luck
Feb 05, 2015 | Refrigerators
I have a new frig that I keep in my garage to keep extra food and drinks in. Since the weather turned cold, the freezer is not working properly. The frig still seems to working great. Can you help with...
If the ambient temp is below 52 degrees the unit will not work properly throught the cycles you will need to get what is call a garage kit to install in the unit.
Dec 25, 2010 | Frigidaire FRT21H8 Top Freezer...
Refrigerator was unplugged for a week. We moved it from one house to another and plugged it in and it's not turning on. The light is on but motor isn't starting. Any Ideas?
ck power at new house ( the plug ) do the lights come on in frig ? if so look for wires under frig that may have been puled off during move .. this should not be a tuff one . / the frig should not been damaged by beeing off . did you lay it down dueing the move ( it chould have been kept upright .. as laying down causes the oil to ru up in the cold coil .) hope this hepls mm
Oct 24, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator light is on but it's not getting cold
Yes, I can help you. (If you like).But you will need to answer a few questions. For example was the freezer and refrigerator doors left closed for all that time with out allowing the moisture inside to escape and not cause the controls to rust or short out. Let me know and rate me if I am helpful, Thanks, Sea Breeze
Aug 05, 2009 | Dometic RM2852 Refrigerator
Refrigerator/Freezer not getting cold
Is the fan on the condenser coils spinning? (back side of unit behind the bottom access panel.)
If it is not, the heat extracted from the fresh food/freezer compartments is not being sufficiently dissipated.
As a short-term fix, you can aim a box fan (a regular ol' room/window fan) at the condenser coils.
Jul 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Garage frig
the garage kit, if even available for your unit, works pretty well, but your right in extreme colds your outta luck, other then buying a refrig designed to work in garage, yoll need to either insualte and heat garage, or wait till spring sorry.
Jan 11, 2009 | Kenmore 63822 / 63824 Bottom Freezer...
Freezer not working
is there frost building up in the freezer?mike
Nov 06, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator not getting cold
hello, my refrigerator got the following problem; it works fine at the freezer but there is no cold in the frig, when i unplug it from the wall connection and after few time connect it again, it start working, after few hours, the refrigerator stop, the freezer is fine and very cool,but the frig is not cool and the refrigerator do not start working again, even after the freezer gets warm.Please i hope you can help me with this problem.
Sep 03, 2008 | Refrigerators
GE ADORA Refrgerator :
The water line from the house to the frig works, however the water in the frig just stop working one day. Any suggestions?
Feb 09, 2008 | GE Profile PSW26P Stainless Steel Side by...
Frigidaire GLRT216TA Top Freezer Refrigerator Logo
194 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
