Question about Belkin (F5D7231-4) Wireless Router
Modem router my modem router (berkin) will not let my windows up date, What can i do about it & how?
  • 6 Answers
  • You need to check your firewall settings. Do you have more than one (i.e.norton and mcafee)?
  • If so I would turn one of them off (I had the problem with a demo norton (symantec) trial version that was later deleted incorrectly.It had a left over firewall setting that somehow still blocked access to MS updates (and other server access too.) But I could still access the internet in general.
  • Had to get the symantec removal kit (going in in safe-mode with internet connection). Also could have reloaded the trial and removed properly (with its own utility and not the MS remove software route).
Posted on Aug 26, 2008
D-link dlr 655 shuts down modem
Go to iobit.com and get the free version of driver booster and run it and make sure all the drivers are up to date.
Apr 14, 2017 | Cars & Trucks
ONLY ONE OUT OF ABOUT 15 isatap NETWORK adapters is not working. could that be the reason computer can not connect to DSL LINE? THE GREEN LIGHT ON THE ROUTER IS FLASHING. WINDOWS CAN NOT LOAD DRIVERS...
Thank you for using FixYa
Yes that could be the reason you are not connecting, or your internet may be down. Do you have more than one computer? Are any other computers working? Have you tried to reset the modem, or at least power down and turn off the computer and the modem and then try again? Is there a router besides the modem? Did you reset the router?
Please include all this information on your next request,
I hope this was useful and please comment if this was helpful to you.
Apr 24, 2011 | HP Computers & Internet
I have had to unplug my computer for several months. my berkin router is now not working modle enhanced wireless router f6d4230-4v1 i have losted my cd starter disc, and can not find the instuctions for...
Instructions/User Manual for Belkin Wireless Router F6D4230-4can be download from this link. It has all the instruction for setting-up and configuring the router.
Good Luck!
Hope this helps!
CreativeTECH
Dec 31, 2010 | Belkin Computers & Internet
I have forgottten my Wireless security key
i want the whole codes to belkin wireless
Oct 10, 2009 | Belkin Security
LB2 with 1 computer 2 modems.
look wich modem is online and connect arouter to it with broadband before doing all this unplugged the modem and run ainternet cable called cat 5 from modem to router install cd after that restart pc and plugged modem and router back in outlet
Aug 05, 2009 | HotBrick SoHo LB-2 (LB2) Firewall
Linsys router not working with Dsl modem error 321
thank you for the clarification,
u need to perform the following steps:
1)donot use the cd for the setup.take the cd out from the computer
2)reset the router(if you look at the back of the linksys router you will see there is a small hole which contains the reset button,hold down the reset button while the router is on,once the time period of 30 sec is over turn off the router,turn it back on after 60 sec.
3)check the cables between your modem,computer and router.
4)the correct cables sequence should be following,there would be a cable going from you internet service provider modem to the back of the router(the post should be the one that is labelled internet or dsl) and there should be another ethernet(yellow/grey colored cable going from ports 1,2,3 and 4 )cable going to the back of the computer make sure the cables are plugged in properly
5)turn of the modem,router and computer,in a sequence that is given,modem----router----computer.
6)wait for 2 mins and then turn on modem wait for the light to be steady and then turn on the router wait for the lights to be steady and then at last turn the computer.
Hope this steps fixes your problem..
vedhick..
Feb 02, 2009 | Linksys Wireless-G Broadband Router
Acer 4420 Notebook does not see Linksys router
Try hard reset of the router and reconfigure it
Jul 29, 2008 | Acer Computers & Internet
My modem router will not let my windows update (Berkin) what can I do about it & how?
Are you certain it is your router that is causing the problems? often times a settings issue from windows. Check to see if the following solution will help your problem. (i posted this solution a little while ago on a similar problem)
"If possible, please do more than just "disable" your firewall. stop it and close it out all together and try again.
worst case scenario. you can go to the link below and use the microsoft updater to get all of your updates. If completely turning off your firewall does not work i would recommend doing this at least once since it should give you the latest updates for your system and may potentially fix the problem without any further intervention on your part.
Click here for microsoft updater.
The microsoft updater is actually a good tool to use anyways since it will give you the latest updates to all of your microsoft programs.
hope this helps you out, and please don't forget to rate my solution"
Jul 13, 2008 | Computers & Internet
I have a westell versalink 327w date on the bottom is 07/2007
You'll need to go into the administrative interface of the router and enable the wireless network and then you should be able to see if from any laptop/PC with a wireless networking card in it.
Feb 05, 2008 | Westell Wirespeed VersaLink...
Belkin (F5D7231-4) Wireless Router Logo
63 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
