Question about Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum
Suction When I extend the wand I lose suction and the noise changes
  • 3 more comments
  • Anonymous Aug 31, 2008
    when i extend the wand my vacuum looses suction
  • Anonymous Oct 26, 2008
    Lose suction when using wand and it makes a different noise.
  • loriwiley65 Oct 28, 2008
    first the extend wand had too much suction at the base and was pulling the hose in on itself. now there is no suction on the extend hose at all, yet the main vacuum is fine.
  • Kid755 Feb 15, 2009
    Me too...........carpet part works fine but when I want to use upright attachment a strange muffled noise occurs and no suction. I have pulled this thing apart everywhere I could possibl get into by hand. GRRRRRRRRRRR
  • ponderroses Apr 05, 2009
    Sounds like a gate closing that prevents suction to the hose/wand extension. Wand will not go all the way down into hose to close off top cap. Floor part works if wand and handle not attached.
  • 833 Answers
If the wand alone causes a suction loss, there are only a couple of issues:
  • leakage
  • blockage
If it is leakage, remedy the defect or install the wand correctly.  If it is a blockage, you'll have to find and remove it.
Posted on Nov 27, 2008
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
Oct 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
It wont pick up using the wand
There might be a few things you can try.
First, does the vacuum have a dial or control to turn the suction to the wand? If so, make sure you've set or turned this so that the wand suction is activated.
Second, most wands have a suction control vent. If this has been uncovered, the suction will not work efficiently. Look near the area where the wand connects to the vacuum and see if you can locate the suction control vent. There should be a plastic partial ring that can be moved to cover or uncover the hole.
I hope this helps. If so, please come back and rate my solution!
Jun 06, 2011 | Bissell Vacuums
Dyson hose does not produce alot of suction when extended.
Hi its Darran at Dyson.
It sounds as though the wand/hose is blocked. with the machine locked in the upright positino, remove the hose from the machine, switch on and test the suction. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If the suction is strong, you will need to check the wand for a blockage. If the suction is still poor, check the hose for a blockage.
You may find it useful to wash the filter as this can sometimes cause a drop in performance if its dirty and it wuold be more noticable from the hose.
I hope that this information is useful to you.
Kind regards
Darran
Dyson Customer Service
Feb 19, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
A Dyson dc 17 Animal and the wand/hose has lost suction
From your description of the problem, it sounds as though the wand/hose is blocked. To check this, remove the wand/hose assembly from the machine, switch it on and test the suction from the top of the wand with your hand. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its good here, then you know that the wand handle is blocked.
For the full diagnostics, check out the Support section on our website at www.dyson.com or call our Helpline on 1866MYDYSON.
Kind regards
Darran
Jan 30, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
No suction on wand of Dyson DC14 Animal
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Wand lost suction
cleaning all filter Assy and all Handle Assy and Hose Assy...
Nov 06, 2009 | Dyson Slim DC18 All Floors HEPA Bagless...
Dyson dc07 animal bagless
You probably have a blockage somewhere in the hose or in the base where the hose goes in. Remove the plastic tube at the base of the hose by simply unclicking it and remove the obstruction.
Nov 07, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hose has suction but will not stretch when turned on
Hi.
I have repaired Dyson machines for years & have never come accross this.
The only way you will have trouble extending the hose is if there is a blockage at the bend where you hold the wand could be a coin which when switched on flips accross & blocks oppening.
Is it easy to slide wand from flexi hose with machine switched off ? You will need to remove wand from hose & push broom handle down to the bend & tap coin out.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Too much suction
Hi.
If yes you probably have grit stuck under the collar that you push the button to unlock flexi hose from pipe.
http://dc07.atspace.com/
I will be logged in most of the time tonight if you need more help.
Chris..
Dec 23, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum Logo
255 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
