Question about Janome Sewing Machines
Janome 1600P DB Stitch length
The stitch length varies from 1/16" to 1/2" while making a single stitch line. I've adjust the tension - it doesn't help. There's nothing in the manual to help with this problem. I use the machine for quilts, generally stitching on cotton fabric. I also clean and oil the machine daily as it gets a lot of use.
  • Anonymous Mar 12, 2014
    Stitch length does not vary, only sees long stitches even when on 0! I have oiled all points as per owners manual. Is there some obvious reason for this problem?
  • 323 Answers
The machine is skipping stitches and is probably out of time. Change the needle, rethread the machine and try it again. If it still skips stitches, try lowering the needle by about 1/16 inch and see if it works better. If the timing is off you should take it to a technician for a complete service.
Posted on Jul 15, 2008
Correct tension for fmq
Not sure what you're asking. FWIW, for FMQ, stitch length should really have no affect if you drop the feed dogs. The stitch length is determined by how fast you move the fabric and how fast the machine stitches.
For tension, it is dependent on your particular machine. To make that determination, make up sample sandwiches made of the same fabric and batting as your quilt and practice FMQ and adjusting the tension until the threads meet in the middle of the sandwich. For most of my FMQ, I use a specific bobbin case that has been adjusted and used only for FMQ.
Jan 17, 2018 | Sewing Machines
Adjusting top and bottom stitches...
the stitch length is set by the amount the foot pulls the material through
adjusting the needle thread tension is the main adjustment to ensure that both threads meet at the center of the materials being sewn
Mar 10, 2017 | Sewing Machines
How can I adjust the stitch on my 50 year old Phaff sewing machine? Even when I set the stitch at 4 it's tight. 4 is definitely not a basting stitch! I have loosened the tension but it doesn't seem to...
Is 4 the highest number? If so, the steps you took were really all that you can do. Just a thought, how about using invisible thread (almost like a thin fishing line) for your top thread and regular thread in your bobbin? It may be easier to remove the stitches with the lighter thread. Good luck
Jan 09, 2018 | Sewing Machines
Stitch length problem
the stitch length dial may need to be checked to see if it's worn or damaged or may need a adjustment.
Jul 27, 2013 | Riccar Sewing Machines
My top stitch is okay, however the stitiching on the bottom is wiggly, more like a zigzag stitch then a striaght stitch. Why?
try changing the needle--flat side to the back of machine
try adjusting the tension one number up--if it doesn't help put the tension back where it is
check to make sure the bobbin is in correctly
also check to make sure the bobbin is wound correctly
it's also possible that the machine is out of time which means a sewing machine repair shop would have to refix the timing of the machine, because they have the tools for the job
Jan 31, 2012 | Singer 7426 Mechanical Sewing Machine
I have a Viking/Lisa Model. I am having trouble with my tension and I am not sure if it is the top or bottom. My bobbin thread is all of the sudden too loose.
I just bought a Viking Lisa, and also had to adjust the tension. Use the manual to make sure you've threaded the machine correctly and put the bobbin in correctly. (I wasn't getting the bobbin thread the way it needed to be.) Then gradually increase the tension on the dial inside the top cover, checking the bobbin stitches every two inches, ending up on about 4 1/2. If this doesn't take care of the problem completely, gradually increase the side tension dial, and between adjustments on both dials, you should end up where the stitches look good. Also make sure to use cotton thread; mine doesn't like polyester thread. :o)
Aug 20, 2011 | Husqvarna Sewing Machines
The machine isn't making stitches. It's threaded correctly. I have been sewing leather recently and it's been acting up since then. I have cleaned the bobbin area. And have adjusted the tension...
Adjust the Stitch Length;
To make longer stitches, set the stitch length to a higher number. On many sewing machines, four is the longest possible stitch length and two is average.
To make shorter stitches, set the stitch length to a lower number. At a zero, the sewing machine may not actually make stitches, since the needle will go up and down in one place.
Cut a small scrap of fabric, preferably the same type you want to sew with.
Sew a few test stitches on the scrap. Examine the stitches to make sure they're the length you want.
Adjust the stitch length again as needed.
Jul 12, 2011 | Singer Sewing Machines
The bottom stitch is very loose. I've tried tightening and loosening the screw and the problem remains...HELP!
The bottom stitch is affected by the TOP thread tension :) First go back and make sure your bobbin tension is correct since you adjusted it. It should drop slightly when held suspended by danging it by the thread. If it reels out to the floor it is too loose. If it doesn't drop at all it is too tight.
Now that you have that adjusted look at your top tension. If it is loopy on the bottom side of the stitch the TOP tension is too loose. Increase the top tension.
Now take some scrap material and set machine to a wide zig zag, medium length stitch and sew a bit. Compare the top and the bottom sides of the stitch. They should look identical. Remember the TOP side effects the bottom and the BOTTOM tension effects the top side. Adjust accordingly until they look identical with no loose threads or loops and no puckering (puckering means it's too tight).
May 03, 2011 | Brother LX3125 Sewing Machine
How do i adjust mitsubishi industrial single needle sewing machine dy337
What needs to be adjusted? First of all make sure you have it threaded correctly. There are a lot more holes and threading points than an household sewing machine. If it is the tension that needs adjustment you will see the tension dial just above the needle slightly to the left. It's the grey knob. Turn it clockwise to tighten the tension. Turn it counter clockwise to loosen it. Thread with two different colors of thread, one color in the bobbin, another color for the spool. Sew a line of stitching...if you see the top spool thread pulling to the underside then you will need to tighten the tension. If the bobbin thread is pulling to the top side then you will need to loosen the tension. If you want to adjust the stitch length then turn the dial that has numbers on it. #2 is pretty small stitches, I use #3 for most sewing and #4 and 5 for topstitching or basting. Good Luck! Hopes this helps.
Jul 31, 2009 | Sewing Machines
Sewing Machines Logo
270 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
