Question about Tag Heuer 2000 Classic WK1113.BA0311 Wrist Watch
Tag wk 1113-0
Can you tell me how to adjust the time and date on one of these please? I have just bought one second hand but will no manuals.
cheers pete
The crown is probably a screw down style. The screw down stem is designed to keep the water out and should be screwed shut when not adjusting the watch. Look at the watch stem from the side, look from the 3 oclock to the 9 oclock, you should see the end of the stem. Now turn the stem counterclockwise. After a number of turns, the stem should pop out a bit, it is now ready to set. Most waterproof automatic day/date watches have 4 positions for the stem:
1: screwed down (locked)
2: unscrewed position A
3: unscrewed position B (stem pulled out to first "click")
4: unscrewed position C (stem pulled out all the way.)
Position A:
This is usually used to wind the watch, although some automatic watches cannot be wound by the stem.
Position B:
Used to set day/date. Turning the stem one direction will advance the day and turning it the other direction will advance the date.
Position C:
Used to set the time. Some watches will "hack," a term used to describe the ability to stop the second hand for accuracy purposes.
Be sure the watch is at least a little bit wound before starting theis procedure or it will not run when you get it set!
Unscrew the stem and pull it all the way out to position C. Now turn the stem to advance the time clockwise. Continue turning until the day/date advances, now you know you are in the AM 12 hrs of the day. It is important not to advance the day/date with the stem during the 3 hours before and the 3 hours after midnight, so go ahead and move the time to 8 am.
Now push the stem in sligthly until you are in position B. Sometimes it is easier to go to position A, the out to position B. Once in position B, advance the day/date until it is set for the current day/date.
Pull the stem out to position C. Adjust the time to one minute past the current time. Watch your reference timepiece until it matches your watch and push the stem in when they match.
Your watch is now set! Screw the crown down and wear it in good health.
Hacking. If you stop the second hand at 0 seconds, and wait for your reference timepiece to reach 0 seconds also, you can set the watch to within a second accuracy.
Movement slop. If you advance the time past the time you wish to set your watch and then "backup" to your chosen time, you will remove the slop from the geartrain and make your watch set more accuretly
Posted on Jul 19, 2008
How to seconds hand
Hi Johar,
I will advise you to contact your manufacturer to avoid warranty void due to damage during the process of setting it. Try the link below.
Contact Us TAG Heuer
May 09, 2014 | Tag Heuer Grand Carrera Automatic Calibre...
Need a manual or instructions for mt watch please!!!
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to resume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Have fun :)
May 04, 2017 | Watches
The scond hand on my tag formula 1 has stopped and wont resest,but the watch still works with the time. What could the likely problem be? Could it be the battery? or could it need servicing?
Sean, This watch has a disposable movement(guts). That means the battery is the only part that can be replaced. The thing is glued together instead of screwed. Take it to a watchmaker that can get the replacement movement from Tag as the ordinary movements out there are different from the genuine Tag movements. Date wheels specifically are different. Anyway, a professional watchmaker, not a jeweler or store clerk please, will be able to tell you if that is the correct course of events to take. Probably looking at 200 to 250 Michael, Watchmaker to the Stars!
Mar 17, 2011 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Time & date adjustment
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TAG HEUER watch manuals. Rate me, please.
Mar 31, 2010 | Tag Heuer Monza Calibre 36 Link Automatic...
I recently bought a Kenneth Cole KC 3790 as a gift and I am tying to set the date...the date is presently Saturday 27th February and I am having difficulty getting to the 27th day of February on the...
Pull out crown to the time setting position (second click) and set time to 5.30 pm or am. Push crown back completely. Pull out crown to the date setting position (first click) and set it to 26th, then pull out crown further out to the time setting position (second click) and adjust watch hands forwards until the date changes to 27th. Date is changing at midnight, so, continue to adjust hands forward to the right time. Rate me, plz.
Feb 27, 2010 | Watches
Tag Heuer date adjustment doesn't work. I pull the crown out one notch, turn it clockwise, and nothing happens. Turn in it counter clockwise, nothing happens. ???? The only way to adjust it is by adjusting...
The date change occurs at midnight, so winding it past midnight changes the date. To change it again wind the hands backward to (say) 11 O'clock) and then forward again will change the date again.
How far you need to turn it back will have to be found by experiment.
Jan 03, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
5034 G-1000 Cannot set Date/Time
gibb erish....the same problem that already happened it on me..but there is a solution for that.just focus..let your excitement blow up if u done it will..
a manual has shown a combination of bottons to press..there is a diagram showing the combination to press so that it will beep. just try.. sometimes i press D go back to A and try long press tell it beeps and so on just follow the manual.. while the hands are still on movement just wait to stop before you press some bottons..be patient our watch is awesome..
Aug 25, 2009 | Casio Watches
How do i change teh date on my tag watch with out having to wind it 24 hours to change one day. i need to change 15 days
If you pull out crown carefuly, you will notice there are two clicks. The first one is for adjusting calendar (day or/and date). Next one is for moving hands. Pull out to the first click and adjust the date by turning the crown.
Rate me, please.
Aug 04, 2009 | Tag Heuer cj1110.ba0576 Wristwatch
Aquaswiss trax watch
AQUASWISS TRAX MODEL:
For clarity:
There are three adjustment knobs on the right side of the watch. Two are smaller than the main time adjustment knob. For clarification I will label:
Top knob: #1
Middle knob: #2
Bottom knob: #3
To adjust the stopwatch feature:
1. Turn #2 counter-clockwise until it pops out to its adjusting position.
2. Pull #2 towards the right until you feel the first click. (There are two click positions).
3. Simultaneously hold both #1 and #3 down until you see the 1/16 hand and the 30 minute hand rotate automatically to a fixed position.
Now you are ready to calibrate the stopwatch feature.
4. Click mulitiple times on #3 and you will see the 30 min. had move clock wise incrementally with every click. Keep clicking on #3 until the 30 min. hand reaches its apex (to its 12:00 position).
5. Now click multiple times on #1 and you will see the 1/16th hand move in very small increments clockwise. You may be bold and try to hold down #1 and let it swing as close as possible to the 12:00 position and then multiple click #1 to get it precisely to its apex.
You are almost done.
6. Now simultaneously hold #1 and #3 until you see both the 1/16th second hand and the 30 minute hands auto-rotate clockwise to their respective 12:00 positions.
Fantastic! However, now you have to return the watch back to its original locked position. This is where it could get a little tricky.
7. Make sure the time is correct. Using #2 fully extended to its 2nd click position you may adjust the time.
8. Using #2 extended to its 1st click position you may adjust the date. (Here's the trick, do not set the date for today's date. Rather, set it for the day before or in some cases, 2 days before. I will explain in a moment).
9. Now, depress #2 fully back towards the main body of the watch as best as possible and while holding down #2 turn it clockwise until it locks into position.
During this operation you may notice that the date will go forward until the watch locks into position, ergo, I had to make sure the date was for the day before...and it some cases, 2 days before.
Your watch is ready to use.
The stopwatch feature for this analog watch works very similarly to that of an actual stopwatch.
Press and hold #1 once to stop the 1/16 hand. Press and hold #3 to have both the 1/16th second hand and the 30 minute hands return to their 12:00 positions. Now you are ready to race!
Press #1 to start the stopwatch. Press #1 to stop the stopwatch. Press #3 to return the hands back to their respective positions. You may even press #3 after you press #1 to get a second reading but I will let you figure that out for yourself.
Hope this was helpful!
vsndesigns
http://www.rgmarchitect.com
Dec 20, 2007 | Tag Heuer Kirium (CL1212.BA0705)...
Just Got a tag professional ( Previously Owned)
Hard to tell without knowing what model or caliber number (usually on back). Generally, if you pull the crown (winding knob) out all the way you can set the time. Push it ONE click in, you can set the date. Check with the manufacturers website for a book of instructions you can download.
Jun 24, 2007 | Tag Heuer 2000 WK1110.BA0317 Wristwatch
Tag Heuer 2000 Classic WK1113.BA0311 Wrist Watch Logo
1,502 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
