Question about LG WM-2277HW Front Load Washer
OE error message checked drain hose for kinks drain hose is clear
  • LG Master
  • 1,902 Answers
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. As you have already checked the drain hose and it is clear so check the drain pump filter for any clogs to clean the error. If the problem is still there after cleaning then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Jan 15, 2011
What is oe standing for
An OE error code suggests that you have a drainage problem with the unit. Check for drain blockages.
Mar 21, 2015 | LG Dishwashers
Hello, My L G washing machine has an error code OE... what does that mean?
The OE error or fault code indicates that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
Oct 20, 2014 | LG WM-2277HW Front Load Washer
What causes the EO error message
Oct 04, 2014 | LG Washing Machines
OE ERROR CODE
The manufacturer has assigned the OE error or fault code to indicate that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
Jul 08, 2014 | LG Dishwashers
What is Oe error lg model lds5540st
The OE error or fault code to indicate that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
Jul 04, 2014 | LG LDF7561ST
Oe pops up and door is locked what do i do
OE is a drain motor error, or your drain hose is kinked, check to see if your hose is kinked on the back of the machine.
Once you check to see if the hose is kinked, press the power button on the unit, then hit "spin speed" and select it to "no spin", and then hit "play". This will manually set your unit to drain mode. If you still get this error, you will need to replace the drain motor on the unit.
Mar 30, 2010 | LG WM1814CW Front Load Washer
MY LG WASHER WONT DRAIN, IT SAYS THE ERROR MESSAGE
OE is a drain error - Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
May 06, 2009 | LG WM2277H Front Load Washer
Message OE
OE : Drain Hose is Kinked or clogged or The Drain Filter is clogged - Clean and straighten the drain hose / clean the drain filter.
also do check for the pump blockage.
for more info on this check the following link
http://pastoralfarms.us/2008/04/21/lg-fl-washer-2277-oe-error/
Dec 23, 2008 | Washing Machines
LG WM-2277HW Front Load Washer Logo
285 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
