Question about Danby DPAC8399 Air Conditioner
Missing the drain hose connector
The drain hose connector is missing. Given that this model has been discontinued, and it's proving to be impossible to get through to Danby, is there any place I could go that would offer me this part?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
A drain hose is a drain hose, go to home depot and get the dimension and lenght you need.
Posted on Jul 22, 2008
Model DM32M Haier Dehumidifier. I am missing a part which diverts the water into the hose drain. All the water now goes directly into the bucket. I want it to drain into the sink nearby.
Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Please rate 4 stars if this is helpful. Thanks and good luck!
Sep 22, 2017 | Haier Dehumidifiers
Lost my secondary drain plug?!?! help!
The plug should be a "common size" usually 3/4 pipe thread in America. If that's the case, go down to your local hardware store.
Jul 06, 2013 | Whirlpool ACP102 Air Conditioner
Drainage hose missing?
Fisher & paykel machines have the drain hose in the back,
Grab the hose & pull down & out,It is tucked inside the machine.
Jan 31, 2013 | Fisher and Paykel Washing Machines
Can't reconnect drain stub to nipple (MDB6100AWG)
Your not missing anything, the easiest way is just that, pull out the machine and save your forearm and about an hour of trying the hard way.
May 31, 2009 | Maytag MDB9600A Jetclean II Built-in...
Water not pumping out in the spin cycle anymore
Check the drain pump and drain hoses. The drain pump is located in front of the motor. To access it, remove the end caps from the console. Remove the 2 screw holding the console to the cabinet. Pull the bottom of the console toward you slightly and flip the console up. Unplug the lid switch molex connector. Inserting a flat screwdriver from the top and pushing back, remove the brass clips on each side. Open the lid. Holding the inside of the cabinet, tilt it toward you and remove it from the base. This will give you access to everything including the drain pump and the drain hoses. Try to remove as much water as possible from the inside since it will all come out when you remove the drain hoses from the pump (hopefully you are near a drain in the floor). Remove the hose clamps and check the hoses and pump for any obstructions. Chances are, you will find a missing sock.
If it all looks clear, remove the drain pump from the motor and inspect where the pump connects to the motor for a broken connection slot. Replace the drain pump if necessary.
Mar 03, 2009 | Kenmore Washing Machines
Owners manual missing - my problem
you should have a drain hose connector. this connecter is inserted into the back of the dehumidifier. your hose can then be connected to the connecter. if you are also miising your connecter,sears or any store similiar will have one
Jul 18, 2008 | LG DH404E Dehumidifier
Danby DPAC8399 Air Conditioner Logo
435 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
