Question about HP LaserJet 1020 Printer
Possibly changing tray /paper settings
I would like to change the settings of the paper tray. I print insurance claim forms and the info is always slightly off in the boxes. Sometimes I push the forms in as far as I can and even bend them a little to get it to print in the correct boxes. Can this problem be fixed? Thanks!
Repairing
Posted on Jul 21, 2008
Lexmark T644 Drawer 2 Missing error message but drawer 2 is in place. Drawer 2 always has problems pulling form form drawer when printing from drawer 2.
If job prints from the wrong tray or on the wrong paper or specialty media, this is an indication that the operator panel menu settings do not match the media loaded in the tray.
Make sure the Paper Size and Paper Type specified in the printer driver match the paper size and type in the tray.
For further assistance, please contact Lexmark Technical Support
Feb 09, 2012 | Lexmark T644 Laser Printer
I wanted to print a form from the internet The printer said The rear loader is empty I only use front loader and it is full I did not ask it to change to rear loader I want to use the front tray as I...
It could be several issues - although commonly when a printer moves from it's default tray it's due to a paper size conflict. The form you are trying to print may be a legal size form (8.5x14) or a a non US standard such as A3. Regardless, if the size is different than what's loaded in your main paper tray it will move to the secondary tray or to the MPF (Manual Paper Feed) tray looking for the appropriate size.
If you don't have the appropriate paper, you should be able to enter your printer properties and adjust the settings to scale the document to fit to page.
May 02, 2011 | Canon PIXMA MP620 All-In-One InkJet...
Does not print to edge of paper
I had to stop and look up "truncated"..lol. Does it say "short paper" after it prints? If so it sounds like the paper size setting in the printer paper menu has been changed to A4 or something other than the size your trying to print on. If you go into the printer menu...cycle thru till you get to paper size. You can check the setting to be sure its set correctly to the size of the paper your trying to print on. If its off...and you can't change it, check the paper guide to make sure it has'nt slipped out of the correct slot. Last..if none of the above works...go back to that paper menu...go to that specific tray type setting...take the drawer and open and close it several times. Look to see if the setting in the display changes when you do that. If it does...then the tray card has gone bad. Its a little pc board inside the printer with 4 switches that tells the printer what size paper is in the tray. Its a pretty common problem with the Optra T series that have any kind of heavy use on them. If you had said truncated on the left only..it could be that the transfer roller(foam roller that sits under cartridge) has slipped to one side. But you said it happens at the top of the page too...so that would rule out the transfer roller. Unless someone got into the registration menu and messed with those settings...(which you'd have to know how to get to that menu)...then it has to be with the paper type menu settings...the tray itself...or that tray card. Hope this helps!
Jul 10, 2009 | Lexmark T654DTN MONO LASER PRINT Printer
Trying to print but it ask me to load paper or form feed. also got a bypass tray message.
Sound like the computer printer preferences "paper source" is set to bypass if set to "auto select" select the tray you want. Also make sure type of paper matches what is in printer.
-Carl
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
Receiving a "load paper" error message; has to do with paper size
Don't know this printer that well. Open tray one and look in the back and see if there is wheel or slider where you can change the paper size.
Apr 10, 2009 | Ricoh Aficio AP410 Laser Printer
Paper size setting
Change the marketing area from EU to US in Service mode.
Sep 02, 2017 | Konica Minolta bizhub 350 All-In-One Laser...
My HP C7200 printer won't print from the photo tray
If you using a mac: After choosing the Photosmart C7200 to print your file on the print preview, change PAPER SIZE to 4x6, then lower down, change from PREVIEW to PAPER TYPE/QUALITY, more options will open underneath, on SOURCE, change from MAIN TRAY to PHOTO TRAY. You should also change the PAPER TYPE to some kind of PHOTO PAPER (whichever one your using, but the standard seems to be HP ADVANCED PHOTO PAPER)
Jan 27, 2009 | HP C7200-69016 Network Adapter
Paper does not feed from Tray 1.
Check your printer settings.
Sometimes if your printer or the program you are printing from has the paper source set to "Letter" it waits for you to press the continue key on the printer which allows you to insert headed note paper before printing.
If it is set to letter, change it to A4 and this should solve your problem
You may need to change this in both the printer settings and/or each program from which you are printing
Jan 12, 2009 | Lexmark C532dn Laser Printer
E Studio163 - Printing - "No cassette with paper of size requested is available"
after changed one of the sensors ,the same problem-"no cassette with paper of the sieze requested is available" has happened,alway paper jam.
any ideas why?
machine:e studio0259
Aug 27, 2007 | Toshiba e-Studio163 Copier
HP LaserJet 1020 Printer Logo
48 people viewed this question
Ben Johnson
