Question about Epson Stylus CX9400 Photo Printer
Paper jam I was printing off the computer and the paper is stuck.I cannot see the paper from the back,about a couple inches in the front.HELP PLEASE,THANKS IN ADVANCE
  • Anonymous Jul 27, 2008
    paper has jammed. I can not see where it has jammed when i lift up the scanner, Is there a way to acess where paper comes out at the bottom?
How do you open the printer to see where the paper jam is? I cannot see anything jammed but know that it may be in the printer itself.
Posted on Nov 01, 2008
    Scholar:
  • 40 Answers
Usually paper jam error message on this machine is either caused by a physical paper jam or a printer error. To distinguish between the two I understand that you have already checked with the printer if there any paper or foreign object but there is none however, just to make sure you have checked everything out, check the left the side to double check. Now there is really nothing that you can see I really means that it is a printer error and that you would need to contact Epson directly to get a replacement. I do not recommend tearing off the printer because that's voids your one-year manufacturers warranty.
Posted on Jul 28, 2008
When printing documents no matter how few or how many pages, paper gets stuck in the middle of printing.
Try using regular paper on unit as specified by Samsung. If that does not resolve the issue then the hassle lies with the paper feed mechanism. Often a good cleaning of all the rollers in the path can take care of the issue.
Aug 24, 2015 | Samsung ML 2525 BW laser Printer
The printer pixma ip90 does not work, because when it is switched on, it gets jammed, while it is preparing to print.
Welcome to FixYa.
Paper may get stuck or jammed in the printer. Follow instruction below to find and remove jammed paper.
1. Turn off the printer.
2. Unplugged the cable of printer from the computer.
3. Remove all loose paper from the paper tray.
4. Do not pull jammed paper from under the front cover.
5. Press the resume button, If the paper is still jammed maybe there is still some scrap of paper, proceed to the next step.
6. Remove the back door or rear access door.
7. Pull the jammed paper out of the printer.
8. Check to make sure no scraps of paper are stuck in the printer.
9. Put the rear access door back into the printer.
10. Plug the cable printer to the computer.
11. Turn on the printer.
Hope this information will help.
Thank for using FixYa.
Apr 07, 2011 | Office Equipment & Supplies
Paper jammed when loading paper, don't know how to clear jam
Welcome to FixYa.
To clear the paper Jam, follow the steps below.
1. Remove all loose paper from the paper In tray.
2. Do not pull paper jam from under the front cover.
3. If there is more than one sheet stuck in the printer, remove the paper sheet at a time.
4. Make sure no scraps of paper are stuck in the printer.
5. If there is open the door at the back of the printer.
6. Pull the jammed paper out of the printer.
7. Check again to make sure no scraps of paper are stuck in the printer.
8. Close the back door.
9. Restart your computer.
Thank you for using FixYa.
Mar 24, 2011 | HP Photosmart 2610xi All-In-One InkJet...
Paper was jammed, it split. We went through back of HP Officejet7310 to remove paper. After we removed it three lights came on and kept coming on without stop constantly. Auto Answer, Exclamation, and...
FLOWO THE STEPS
1. 1
Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2
Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3
Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4
Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5
Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Step 6
Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
7. Step 7
Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Apr 25, 2010 | HP PSC 1610v All-in-One Printer
Message says Paper Jam, but there is no paper
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 25, 2009 | Brother MFC 420CN All-In-One InkJet...
Kodak ESP3 paper jam when theres no paper
Kodak esp3 always showing paper jam .I have disconnected and followed instructions to fix through IT phoneline No joy! How can I fix this problem ? mary
Jul 28, 2009 | Office Equipment & Supplies
Samsung ML 2010 won't paper feed
Lift up the front of the machine a couple of inches. I put a small bo under it. The paper then feeds slightly downhill.
Worked for me.
Jan 30, 2009 | Samsung ML 2010 Laser Printer
Brother printer, paper inside, but I do not see paper inside.
PAPER JAMMED INSIDE THE MFC
1. Remove the Jam Clear Cover located in the back of the machine..
Squeeze the plastic tabs located on the right and left side of the cover
and pull the cover off.
2. Remove any paper you can see jammed in the machine. If you cannot
remove the jammed paper from the back of the unit follow the in
structions listed below for reinserting the cover and then continue to Step 4.
3. Re-insert the Jam Clear Cover. The top of the cover has a slotted
opening in the center approximately 1/4 inch wide. Hold the cover by the
plastic tabs located in the front of the cover on the right and left side and insert the cover into the opening until it securely
clicks intoplace (both sides).
4. Open the scanner cover by pulling up on the lower right corner of the
cover until it locks into place.
5. Remove the jammed paper. If the paper is jammed underneath the print
head, unplug the machine from the AC power outlet. Gently move the
printhead to the far right side of the machine (the "home" position) and
then remove the jammed paper.
6. Lift the scanner cover to release the lock and then gently push the
scanner cover support down and close the scanner cover.
To test print the Help List by pressing Menu/Set, 6 (Print Reports), 1
(Help List) and then Black Start. The Help list should begin printing.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 12, 2008 | Brother MFC 420CN All-In-One InkJet...
Paper jam!!
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
put the cables back and switch on
Aug 25, 2008 | Brother HL-2070N Laser Printer
Bogus paper jam
I had the SAME problem with my printer and after hours of searching on the web I found this solution on fixyourownprinter.com and it WORKED! I cleaned the contacts of both of the ink cartridges and then popped off the cover of the optical sensor on the side of the ink cartridges (black plastic cover over sensor assembly snaps off) there is a hole in the middle of the sensor, push it in with a thumb tack or toothpick and push up on sensor assembly and it will come off the side, clean the contacts on that and reassemble..the blue sensor light should come back on and you should be back in business.
Feb 04, 2008 | HP PSC 2175 All-In-One InkJet Printer
Epson Stylus CX9400 Photo Printer Logo
229 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
