Question about TruTech PLV16260 Television
Rca L37WD12YX1 unit plays fine then just shuts power down. not lose connection. great picture. never know when it might go off.
  • DocDale1 Jul 14, 2008
    Replace Capacitors in power supply, fixed it.
Rebuilt power supply by replacing capacitor on power board ,they are not swolen but if you pull and check them you will find out that they have changed in value.
Posted on Jul 15, 2008
I'm not getting any sound out of my speakers
have you rechecked the connections in the back of the theater system? since you unplugged it have you checked to see if your settings are back to what you had them at
Jul 22, 2012 | RCA Dvd Home Theater System Rtd325w...
Our RCA model # L37WD12YX1 won't turn on. It was working fine but we couldn't control the sound so we unplugged it and then when we plugged it back in, no picture at all.
This is caused by bad epprom chip, the tuner shielding developes cracks on the main board due to bad solder joints which in turn damages the epprom, a skilled technician is required for this job.
Jan 04, 2011 | RCA Televison & Video
My RCA big screen plays for about half a movie and picture dims then shuts off. Sound still works. I shut off for a few minutes picture comes back on and shuts off again after few minutes.
These units are famous for loose connections around the high voltage transformer and also bad capacitors in the power supply. The deflection PCB has to be removed to fix this problem. You probably would need to have a repair shop check it out for you. Thanks
Oct 29, 2009 | RCA HD52W56 52" Rear Projection HDTV
"Unusable Signal"
Ok. PCB means Printed Circuit Board.
It looks similar to the picture down below. A part must have gone bad on your PC board. So, the RCA shop ordered a replacement PC board to fix the problem. It's an interchangeable part. All newer TV now have PC boards, which each one hold a different function.ebc3c7f.jpg
Mar 13, 2009 | RCA L42FHD37 42 in. LCD HDTV
TV turns on can hear sound then shuts down.
Did you check the high voltage transformer and the high voltage splitter (distributor). RCA HVT is known for going bad. i have the part number for both if needed. 5520-559-5774 john
Aug 14, 2008 | RCA HD56W58 56" TV
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
36 inch RCA 36v430t
Mike-It looks like the power supply is going on your tv-it can be replaced. This happens, usually, when little kids are playing wth the remote or power button on the tv. Turn it off and on a whole bunch of times in a row, kids love to do that, and it burns out the power supply part- to make a CRT tv like your RCA36 incher- which is a beautiful machine- I have the RCA/PROSCAN 36 incher-LAST longer...You should always wait 5 min between turning it off and on. Don't ever sell it. This one is worth fixing. It has better color and sound Than the new plasmas and lcds-The Pros know this. Be carefull, they might try and talk you out of it-so they can fix it and have it for themselves. So what if it's not High Deff. It's a great set.
Jul 02, 2008 | RCA F36650 36" TV
Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Jan 25, 2008 | RCA HD56W58 56" TV
RCA 20f510td
Sounds like a thermal breakdown of a componet. it could be in the main power supply regulaor supply or even a bad capacitor in the power or sweep supply. In some cases Zener diodes can break down and change values after warm up. In some cases also bad solder connections in the highvoltage section, or the power supply can cause this problem. It is a hard call without being able to look at the set. Just a few leads on where to go first. most likly a combo unit, such as this one , would cost you more then a new one these days. Good Luck PS Please dont forget to rate this thread.
Dec 09, 2006 | RCA 20F510TD 20 in. TV/DVD Combo
TruTech PLV16260 Television Logo
453 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
