Question about Car Audio & Video
Sometimes car stereo stops working and then sometimes it starts working again. when you shut the power off it sounds like a motor is still trying to run.
    New Friend:
  • 101 Answers
The motor your hearing could be the power antenna .'s motor.what kind of radio?/ tape/cd? when does it work?radio ,cd,?yell me more
Posted on Jul 14, 2008
The wipers have stopped working but the windshield wiper fluid still works. After they stopped working and I had shut the car off for about 5 hours then ran to the auto store for fuses I started the car...
Sounds like the wiper motor is bad. Check to see if you are getting power to the motor and if you are that should be the problem. When you turn power off to the motor it is set to go to the normal position so more then likely it just loosened up a little to go back to the regular position when it did that to you. I hope this helped and good luck.
Jan 30, 2011 | Ford Windstar Cars & Trucks
Our dryer starts up and runs for a while (15-25mins) then a sound develops and the dryers stops working. It appears that whenever it cools down it will run again. On start up sometimes a strange sound is...
You definitely have a motor issue starting to develop. The motor bearings will usually allow the motor to run initially, but start to get loud after they heat up and eventually bind causing the motor to stop. The motor has a thermal switch on the side that will shut the motor off if it gets too hot, and will re-set after about 15 or 20 minutes.
The motors for this style dryer (I can't look up the exact part as I need the complete model # off your machine's model tag) are usually about $140-$160.
If you would like to get the motor and install it yourself, let me know and I can provide you walk-through directions on replacement of the part.
Aug 18, 2010 | Kenmore 800 6983 Electric Dryer
I am istalling a jvc car stereo in my 92 chevy truck. The stereo wire connections have been cut. I was able to find the car stereo wiring schematic online. My problem is: when i turn the key to accesory...
hi this sounds like you have connected the permanent live wire to an auxiliary wire, ie, what ever the power source you have connected it to, only works until the vehicle has started, then the power is stopped, sorta like.. say, the starter motor, it only uses the power when it is needed then when it is running it shuts the power off, just like the lights on the dash ect ect, your best bet would be to find a permanent live from the battery supply...hope this helps
Jul 14, 2010 | Car Audio & Video
Car starter not working properly
hi if the times when it dont start you just hear a faint clicking sound every time you turn the key to start the car then this indicates that the starter motor selenoid is up the shoot it will evntualy stop working all together and would leave you stranded without being able to get your car started again.
The only real solution is going to be get the starter motor replaced the this will solve your problem.
Let me know how you get on or if you need further assistance ok
Dec 13, 2009 | 2006 Dodge Ram 1500
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
My 1998 outback will sometimes start and sometimes will not. There is power going to the battery and after 10+ tries the car may start. When shutting off the engine and trying to restart the car it repeats...
the clicking sound is the starter solenoid on the starter, replace it, the contacts are burnt that engage and supply the starter motor with power to spin the engine over, this is a very common problem on Japanese starters.
Jun 28, 2009 | 1994 Subaru SVX
Heater motor works intermitantly
This Realy Sounds Like A Bad or Loose Ground Although it Could Be the Power Plug too Check for Loose Plug At the Blower motor And Also try to Catch When its Off but Switch is on And SMACK it With a Screwdriver this will tell its the GROUND Wiggling the Power lead W/Blower On & it comes on Says Its the Hot or POWER Lead to motor. Beyond that Its gona be the RELAY But AS I Said I think its Power or GROUND LOOSE Hope this helps !!
Jan 30, 2009 | 2000 Jeep Cherokee
Stopped running in middle of cycle
hi thanks for the question when your dryer stopped and you tried to restart if no noise the over load thermostat embedded in motor is suppose to open and not allow it to start then the motor cools down now it works till the motor over heats again and shuts off again. i would vacuum out the inside clean motor and check the venting right to the outside and try it again but remember do this with power off thanks the appliance doc
Aug 31, 2008 | Whirlpool LER5636P Electric Dryer
Car Audio & Video Logo
530 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
