Question about Sewing Machines
Serger How do i get the light assembly off to adjust the needle bar
  • midwifebcs Jul 14, 2008
    Not particularly helpful. If I HAD a service manual I wouldn't have asked the question
  • 2,071 Answers
Click below there is a picture guide how to take:
Sewing Machine Maintenance
Posted on Jul 14, 2008
    Guru:
  • 1,894 Answers
You will need a service manual for doing this
My serger will not sew light fabricssuch as light weight cotton or flannel
is it an industrial serger or for the home?
try different needles
also try adjusting the tension
Mar 11, 2016 | Sewing Machines
Have an Toyota 6600 model Serger. The knives won't cut, won't stitch and tread keeps breaking from the right hand needle...
you might want to replace the knives
you might have the serger checked for a timing problem
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
10. If all of the above suggestions don't help then the serger needs to be checked for a timing problem at a sewing machine repair shop.
Nov 05, 2013 | Sewing Machines
I have re-threaded, changed needles, adjusted the differential and cutting width but cannot sew a single seam without the stitches skipping, sometimes several in a row and sometimes only one.
SKIPPED STITCHES ON A SERGER
1. Is the needle bent or worn--replace
2. Is the needle inserted correctly into the needle holder--check needle
3. Is the Serger threaded correctly--rethread
4. Is the presser foot pressure right for the fabric--adjust
5. are the needles the correct ones for the serger
6. Possible timing problem--need to be checked at a sewing machine shop
Sep 18, 2013 | White Sewing Speedylock 1600 Mechanical...
Brother 1034d serger. Seems unusually noisy (mechanically) in needle/cutter area. Not motor or belt as noise is metal parts clacking even after new needles, cleaning, oiling. Is this sound normal for...
in response to all serger, no, after my babylock serger is cleaned and serviced it runs quietly.
as for the brother, it's possible thats normal, try contacting a repair shop in your area and tell them about the serger and see what they say.
it's possible that the serger may need some type of adjustment
or a part may have broken .
Sep 06, 2013 | Baby Lock Eclipse Serger
SERGER HAS BEEN RETHREADED AND HAS A NEW NEEDLE BUT WILL ONLY SERGE FOR ABOUT 1.5 " and THE THREAD BREAKS AND LOWER LOOPER COMES UNTHREADED.
7. Is the thread feeding off the cone/spool freely?
Aug 21, 2013 | Singer 14SH654
Singer serger 10uj13 overredging sitch skipping
Aug 14, 2013 | Sewing Machines
Kenmore serger thread keeps breaking
Mar 26, 2013 | Sewing Machines
Can serger for about 3 inches on my brother 1354d serger and then thread breaks
Jan 01, 2013 | Sewing Machines
Pfaff serger stuck
your needle bar has been pushed up and is out of adjustment. You need to take off the side cover, there should be a screw on the back of your machine holding it on. Remove this screw, and remove the cover.You may have to remove the light assembly to reach the screw on the needle bar. Once you can see the needle bar, rotate the handwheel until you can see the screw on the needle bar. Loosen this screw SLIGHTLY until you can turn the needle bar. Hold and rotate the needle bar back and forth as you push down slightly. This will lower the bar.Lower it about 1/4 inch. Adjust the needles by turning the bar so that they are straight across. Tighten the needle bar screw so that the bar doesn't move. Turn the handwheel to see if the threads will be picked up. If not, adjust until they are. Tighten the needle bar screw tightly,reinstall the side cover ,and tighten the screw. Change your needles.Rethead and sew.
sewman7
Jun 17, 2008 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
