Question about LG WM1812C Front Load Washer
Front Load Washer
I just Got off the phone with Best Buys, i am very upset about this also because like you said all that money down the drain. Isn't there something we can do? I bought the extended warranty through best buy and they say they cant do anything about it, that its a manufacture defect and warranty does not cover that. All I want is a good washer and dryer that doesnt stink up our clothes and washes them right. Did you ever get anywhere with this?
  • 489 Answers
Call LG customer service and tell them your problem.  1 800 243 0000.
Posted on Jul 23, 2008
Washer won't drain
ND means No Drain(ing). First check that the drain hose isn't kinked. Then, check to make sure the drain hose isn't pushed so far down into the standpipe that it is sealed closed. If it is too tight in the standpipe, it will create a siphoning effect. It has to sit freely but securely in the pipe.
May 30, 2012 | Samsung WF337AA Front Load Washer
Tip
Is your Whirlpool or Kenmore front load washer not draining
<span>Hello.<br /><br />The most likely problem is that the drain pump screen is clogged so its not draining and if it isn't draining it wont spin.<br />To check the pump remove the lower panel and the lower right side will be the pump, unscrew the big white cap a little and use towel(s) to catch the water that comes out ,when all water out remove completly and check for blockage,<br /><br />Good luck,i hope this helps<br /><br />Gene</span>
on Aug 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Samsung vrt front load washer will not spin out, ( not working)
I have the same washer and mine wouldn't spin out all the way sometimes leaving the clothes very heavy and wet. My problem was that the drain hose from the washer that you put inside your drain pipe had created a suction preventing it to drain properly. It might be worth checking. I know for forking out so much money on the thing it sure can be finicky.
Apr 18, 2012 | Samsung WF206ANS Front Load Washer
Front loader stuck in final spin - not draining
Very likely the reason your washer isn't draining is because the filter screen on the drain pump is blocked so it cant drain, its a fairly common thing wrong with those type front loaders soi have written this tip covering how to clean that filter, http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Oct 06, 2011 | Kenmore Elite 45986 Front Load Washer
Do i need to winterize front load washer
If your unit will be in an unheated house you should. There will always be some water in the drain line and the bottom of the tub. Most of the water in the tub will evaporator so it isn't a big concern, but the water in the drain line and drain pump is.
Aug 18, 2011 | Kenmore 44832 Front Load Washer
Washer isn't spinning. Everything else seems to work.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Washing Machines
My samsung WA10R3 won't spin - it making a noise as if its trying to spin but the drum isn't turning and the water isn't coming out Thanks
heatman101
Aug 11, 2011 | Samsung Washing Machines
Front load washer did not drain
First check the filter for coins or other junks.
Make sure the drain hose isn't blocked, restricted or kinked.
If this is not the problem, may I know as to what error message you get and the make & model of machine?
Thanks.. :)
Jun 09, 2011 | Frigidaire Affinity ATF6000F Front Load...
It won't drain, code nd. Hose isn't kinked.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 16, 2011 | Maytag Neptune FAV6800AW Top Load Washer
F02 what does it mean
I have had this issue more than once. It was an easy fix for me (maybe a 20 minute job and best of all no money). For my F 02 error it was my 4 year olds socks that some how got down the drain line and stuck in the clean out. Here is what you do. There are 3 screws bottom of the front access plate. Remove these and the lower access plate will pop right off. Right in front you will see the pump and the drain line. It has a clean out right there. Unscrew the cap (be ready for alot of water to rush out, so have alot of towels ready). Once the water is drained remove the cap. The cap has a trap so that larger items do not get to the pump. This is where I find the socks stuck. Clean it out, tighten the cap back into place, put the access panel back on, and hit run. Has worked for me at leaste 3 times. Those pesky kid socks every time.
Apr 28, 2007 | Kenmore Elite 45986 Front Load Washer
LG WM1812C Front Load Washer Logo
52 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
