Question about Creative Labs Audigy Gamer Sound Card
Audigy 2zs how can i connect my Audigy 2zs thru SPDIF_IO with my FX 8600 GT graphic card so I can get sound on my LCD TV which is connected with HDMI cable with my PC?
  • Anonymous Dec 16, 2008
    Problem Solver:
  • 11 Answers
U need a 2or 3 pin spdif cable from the spdif on ur gpu to the spdif on ur mobo/soundcard. check manuals of ur gpu and mobo/soundcard for correct pin diagrams. dvi wont carry audio even if using HDMI adaptor, u need to ling the gpu to soundcard/mobo depending on what u use for sound.good luck
google "nvidia spdif to soundcard cables"
Posted on Nov 22, 2011
How do I get the high def side my Dynex 40in LCD tv to work
TRY connecting thru your composite connections to see if that works, also try a new HDMI cable. if it works thru composite & not the HDMI input then you have either a source issue or a bad MAIN/IO PCB
Sep 23, 2014 | Dynex DX-L42-10A 42 in. LCD TV
Sound output through hdmi
DVI is "Digital Video Interface". No Audio is transferred through this type of connection - even if one end of the cable is HDMI.
BEST solution would be to purchase a video card with HDMI output.
Alternate solution would be to run audio from rear audio jack to TV (assuming you have an input on the TV that will accept it)
Dec 29, 2012 | ASUS P5K64 WS Motherboard
I can get picture with hdmi connected but no sound. Do i have to connect the optical digital audio cable from PC to TV to get sound? Actually the video and sound go to stereo receiver first, video passes...
If your video card supports audio over hdmi in that case you need to find the s/pdif port on you motherboard and the port on your video card (usually right next to and sli or xfire bridge) then you can send the sound thru the hdmi. if not you will have to connect your optical audio cable or a 3.5mm audio out to rca left and right out to your receiver for audio. what video card and mother board are you using? if you know this i can tell you exactly where the ports are for the spdif cable to video card and mobo.
Mar 15, 2011 | Computers & Internet
I installed the Audigy 2ZS sound blaster on my laptop. When I try to open the graphic equalizer,I get the message "CTEQ out of memory" Can you help?
You should update your sound driver. Update of Sound Card Driver.
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Click on Sound, Video and game controller
  • Right click on sound driver from the list.
  • Click on Update Driver.
  • Update Driver Wizard start.
  • if the problem is still exist.
  • Replace the sound card or have a local tech take a look at the sound card.
Creative Sound Card Driver
Mar 17, 2010 | Creative Labs Creative Sound Blaster Live...
HI I have a 9500GT Video card and it is connected to my TV. I get video but no sound, I have tried connecting the card with the supplied cable to the pins on my Gigabyte GA965G-DS3 motherboard (spdif and...
How are you connecting it to the tv? Also what is the brand and model of your television? Do you have a possiblity to connect with a DVI cable and then use 3.5mm -> stereo connectors for sound. (
Oct 15, 2009 | Palit Microsystems Computers & Internet
Hi, =)
Basically what you need is to connect the S/PDIF out from the soundcard\motherboard I/O ports to the 8500 graphics card S/PDIF in and HDMI should now carry both video and audio.
So you have to check the video card. On the top part you'll see a white plastic with 2 pins inside of it. This is the connector SPDIF input from the video card. So what you have to do is look up in your motherboard for a connector with 3 pins that says SPDIF OUT. Even though it looks with 3 pins ONLY 2 of them are needed. You will basically need ONLY a cable like this:
You can get it at a local pc technician shop for 2 bucks only.
Anyway what you do is connect one end of the cable to the two pins from the white connector from the video card and the other end of the cable to your motherboard on the first 2 pins of the SPIDF OUT connector. Now the way to know which ones are the first two, do it this way: The first two considering reading SPIDF OUT meaning that the first one is the one closest to the "S" letter of SPDIF OUT.
If it does not work trying connecting the cable differentely as you might be connecting in a reverse order (positive-negative). Don't worry about burning anything as it's only a sound cable, and it does not carry any power.
Once you do it, go to windows control panel and select SPDIF as your default sound playback.
And you're ready to enjoy sound and video thru HDMI now!
Aug 11, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
No sound on tv when laptop connected via hdmi
if you are running windows xp or linus i may not be able to help altought the problem might be solved in almoust the same way. For windows vista right click on the volume icon in the system tray icons and choose playback devices select HDMI output ( for 5920G is "Realtek HDMI Output" ) then press the "Set Default" button. The other way around is to go in the Control Pannel in the "Hardware and sound" cthegory and select sount than seth the default output to Realtek HDMI Output in the "Control Pannel Home" view, or in Classic view click/doubble click on "Sound" icon ( a speaker ) and do the same. In windows XP there is a similar approach. In linux go to System ->> Administration ->> Soundcard Detection and you should find a setting equivalent to the one in Windows
May 29, 2009 | Acer Aspire 5920 Notebook PC
No signal on HDTV
Your graphics card is probably too old to support HDTV signal (720p, 1080p)
Dec 04, 2008 | Nvidia GeForce FX 5200 Video Card Graphic
Creative Labs Audigy Gamer Sound Card Logo
126 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
