SOURCE: Woffer Problem GENIUS SW-HF 5.1 5005
Don't do anything to your speaker, it may ruin the warranty for it. The best thing to do is take your new speaker back to the store where you had just bought it. They may replace the speaker if found a factory defect on it. Contact first the store where you bought it.
I hope this could help you..:-) Thanks..
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
