Question about Hitachi Televison & Video
My convergance on my Hiatchi model #53UWX10B has gone bad what components on which board should I replace. Can I get a service manual as well.
  • Hitachi Master
  • 8,617 Answers
You will need to replace the two STK392-110 Convergence ICs and you will need 6 feed resistors as well 3.3 ohm 1watt, 1.8 ohm 1watt, 2.7 ohm 1watt, 1.5 ohm 1watt 3.9 ohm 1watt, and a 2.2 ohm 1watt. You can get replacement ICs and resistors at the following link with free instaltion instructions with pictures and you can also get your service manual for your model too. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jul 14, 2008
No picture or sound with a red flashing power light. Have replaced the convergence IC's but no change (do not have the chirpint sound). Removed main power board & green LED does not light up
On that model the conv IC is usually not the solution. I believe its the blown capacitor problem with is an easy fix. Check the site www.TvRepairKits.com for a repair kit.
Apr 11, 2012 | Hitachi 53UWX10B 53" Rear Projection...
53uwx10ba.....seeing double/triple, colors primarily red white blue...can we fix this ourselves? and does the front of the tv come off?
Yes,but the front that not what u wanted to be open.The back of the tv that what u wanted to be open.That where the tv convergence board is,that the board require reparing.Yes,if U have all the tools and can do basic soldering works too like take out desoldering ICS take it out of a circuit board and resoldering ICS on put in onto a circuit board and also desoldering/resodering like take out small components parts and replace with new small components parts onto a circuit board?Yes?The tv convergence board must require replaces like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.Tries websites like Tvrpairworld.com,Tvrepairkits.com to buy a whole complete convegence kit belong to ur tv make and model the kit also will have a dvd disc of tutoring job too.Or tries tvs shops will cost u like $300-350 for parts and labors.
Sep 03, 2011 | Hitachi 53UWX10B 53" Rear Projection...
What does it mean when you get a error code 5 when you are doing the magic focus?
Mean ur tv convergence board it is dead,any codes error at all,mean the tv convergence board have components it is dead and the board it just dosen't conververt it three CRTS tv colors Tubes like R,G,B colors lines yokes anymore.Now.The tv convergence board must have it parts replaced like 2 STK convergence ICS and some or all of it resistors too.After the tv fixed it convergence board,the tv will run the entire Magic Focus function,without any error codes at all.The tvs shops will cost u like $300-350 for parts and labors.
Jul 10, 2011 | Hitachi 53UWX10B 53" Rear Projection...
Will nt turn on only geet a blinking lite
u may have a bad convergence board , check for bad resistor next to the convergence ic and u will see that they are burn
Apr 23, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Akai/Samsung PT4299HD Convergence Problem
Try resoldering the pins on the ICs first. If that fails to resolve the problem, change the IC responsible for RED. You should be able to determine that from the service manual. In that area you should also see either fuses or low valued resistors that feed the STKs. Check those as well.
Let me know if you need further info.
Dan
Feb 13, 2009 | Hitachi 53UWX10B 53" Rear Projection...
No raster, no sound on 53UWX10B
double check the wire connections, as the filaments not being lit makes me thing a wire isnt connected properly, or one may have been loosend while doing the convergence repairs.
Jun 12, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Convergence i.c. board
Yes, you need two convergence ICs for your model STK392-110 heres the link to the site.
Apr 29, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Red Halo Hitachi 53FDX20B (2002) model year
You can get the replacement Convergence ICs at this website I am posting. Just order the same STK numbers that are on your Convergence ICs. They provide instalation instructions and free on line tech support with every purchase. Heres the link.
Apr 11, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitchai 53UWX10B colors dont line up.
I have a service manual for the 43/53 uwx10b
Oct 16, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53uwx10b
Hitachi has created a repair kit part# X480293 for this problem. It includes: (2)STK392-150 convergence ic's,resistors RK42 = 3.3 ohms,RK46 = 1.8 ohms,RK50 = 2.7 ohms,RK54 = 1.5 ohms,RK58 = 3.9 ohms,RK62 = 2.2 ohms,all 1 watt resistors.
Aug 20, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Televison & Video Logo
50 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
