Question about Vacuums
I just bought a new dirt devil vacume today an there was no warranty card in the box to send back only instructions to use it.
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=783056
Generic problem for all Vacuums
I just bought a new
Posted by beckyspuppet on Jul 14, 2008
I just bought a new dirt devil vacuum today and there was no warranty card in the box to send back only instructions to use it.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can always call the Royal factory and they can send you out a warranty card or the cust serv dept can do it over the phone, you would need the brand name, Model # and serial # in order to register the factory warranty. Other wais as a rule you have a one year factory warranty with your customer receipt as proof of purchase or you can call the factory.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 16, 2008
Dirt Devil Bagless Breeze Cyclonic
Filters can clog quickly or you may have a clog somewhere which will reduce airflow causing the motor to overheat and shut off. It will come back on after it cools down. If that is the problem you may need to clean or replace the filters. If that does not solve it I would take it to a Royal warranty repair shop.
Apr 18, 2014 | Dirt Devil Vacuums
I have a dirt devil vacemn that has a warranty of 3 years. I bought it in May 2007. Can I return this where I bought it, walmart
Unfortunately, no. Wal-Mart maintains a 90 day return policy, that is to the best of my knowledge. If the machine is broken, obtain its serial number and warranty information and have them ready and call DirtDevil support and let them know what is wrong with the machine. From that point, Dirt Devil should either send you a new or refurbished machine of the same model or provide you with some voucher to cover the cost of the repair or replacement of the machine.
Dec 21, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
I recently ( approx. 2-3 months ago ) purchased a dirt devil. Now it is not picking up properly. When I push vacuum forward it picks dirt up a little bit, when I pull it back all the dirt falls out of...
Hi sounds like your line is stopped up somewhere , check ur suction an make sure your brushes are spinning, if they are try a wire clothes hanger to the hose at the bottom hose to dislodge anything that mite be stuck
Jul 01, 2009 | Dirt Devil Vacuums
The vaccum doesn't pick up dirt, it sprays out
There is probably a second or third filter (besides the canister) that needs to be cleaned.
I doubt that it's rotating the wrong direction.
Apr 25, 2009 | Dirt Devil M084600 Dynamite Bagless...
The belt is broken of my dirt devil
Remove brush roller and black caps at each end of the roller. Clean and oil the bearings.they must turn freely.
Dec 10, 2008 | Dirt Devil Vision Turbo W/Bonus Upright...
Dirt Devil Vibe No Suction
Sounds like there is a clog somwhere. Check the hose - you can undo the hose with a screwdriver but because of that bend use a pipe cleaner or a long wire to see if there is anything blocking the tube. Next check the dirt channels from the bottom of the hose on the Dirt Devil Vibe once the hose has been taken off. Check that the bottom part is clear and then tip the machine over, remove the bottom sole plate (4 screws, 2 at the front and 2 at the back near the rear wheels) to check the roller brush - sometimes if there is an obstruction in the dirt channel from the roller brush suction will not get through.
Dont forget however that there are two filters on the Dirt Devil Vibe. The top filter has to be unscrewed and then unlocked. Tap it a couple of times to dislodge any dirt and then lift out the second part filter at the top of the bin.
Dont forget to rate if this advice works. Thanks.
Jul 30, 2008 | Windsor SR12 Sensor Bagged Upright Vacuum
I have a dirt devil that is only 2 years old, I used it and sparks began to shoot out from the front grill area. I called dirt devil's corporate office at 12noon today July 25th, and was told that with out...
The sparks may be from the carbon brushes in the motor. Bagless vacuums do not filter dirt out as well as a bag does so dirt and grit gets sucked into the motor. Filters should be cleaned frequently and replaced at least once a year. If the filter gets clogged the motor can overheat. If you got two years out of a $39 vacuum you did well. Many people are lucky to get a year.
Mar 24, 2017 | Dirt Devil Vacuums
DIRT DEVIL VISION BAGLESS UPRIGHT
Check further down, by the brush roll, the inlet may be clogged, or something like a nail or pin wedged sideways in the hose, and catches debris and clogs up. This has a one year warranty, if you still can't firgure it out, take it to a warranty shop and take proof of purchase with you.
Dec 29, 2007 | Dirt Devil Featherlight Bagless Upright...
Vacuums Logo
70 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
