Question about HP Pavilion tx1000z Notebook
Wireless lan: pavilion tx1000
I have my pavilion tx1000 with Vista, suddenly my wireless lan disappear and i can't find in hardwaare device, i've done a lot of system restoration but it didn't work, can anyone help me. please email me at: warlags@yahoo.com
tnx
  • 8 more comments
  • Anonymous Dec 19, 2008
    I had the same problem on the exact same model... Soon enough, your laptop's going to die especially if it seems like your laptop heats up super excessively when you watch videos of any kinds or play any type of graphics games.
  • cahlel Jan 22, 2009
    i have my pavilion tx1000 with Vista, suddenly my wireless lan disappear and i can't find in hardware device, i've done a lot of system restoration but it didn't work, can anyone help me. please email me.
  • Eric D53 Mar 01, 2009
    Folks! You are not alone on the issues with the HP tx1000, tx1320us, and all of the other like models that have the motherboard defect. I keep hoping HP will wake-up and do the right thing by correcting this issue. Please keep posting and calling.
    Here are links to other messages in the forums dealing with the same bad motherboard.
    http://h30434.www3.hp.com/psg/board/mess...
    http://forums13.itrc.hp.com/service/foru...
    http://forums11.itrc.hp.com/service/foru...
    Motherboard 441097-001 HannStar JMV-4
  • bk100 Mar 10, 2009
    hp tx1000 died just after the warranty expired. i see tons of other posts online with the same problems. the motherboard is broken. it is a **** model.
  • luisjugo Apr 11, 2009
    I have a tx1332la and i have the same problem. Suddently the wireless lan disappear! I tried everything, reinstalled the drivers several times and nothing!
  • Adeade1 Apr 24, 2009
    It's crazy. I have the exact same problem. My wireless lan just disappeared. But when I use my sprint wireless card, it works. I called hp and they told me sorry my warranty expired 9 days earlier and I have to pay to even talk to me. Now my mother board is totally dead and I was considering spending almost $300 bucks to fix it or just get a new laptop and remove my hard drive. This is really a junk. Now that I have seen several people have the same problem, Maybe it's time to scratch hp off my laptop list. I have always used hp in the past several years though.
    Ade, New York city
  • sakashdeep May 02, 2009
    my lan is also undiscovered , i can only use the net using a wire !! Its a pity that there is no reliability these days !
  • Anonymous May 03, 2009
    same problem,, but let it overheat again and it finally booted. I think I will not turn it off indefintly.
  • lemmiemiller
    lemmiemiller Jul 20, 2012
    i had this SAME ISSUE.. wifi stopped working but i got it to work again by reseting my comp, hitting f8 then doing a WINDOWS MEMORY DIAGNOSTIC. i let it run then my comp reset, now my WIFI works again!!
  • lemmiemiller
    try this reset comp F8 do a WINDOWS MEM DIAGNOSTIC let it complete comp does a auto reset WIFI SHOULD BE WORKING!!!
It's not the assistant, it is the way the motherboard was designed. The nVidia chipset overheats and the first sign of danger is the missing WiFi card. Sorry, but this will only get worse; soon the laptop will be inoperable. Back up your data and hope for the best (while looking for another brand of laptop to purchase). You can try to escalate the repair by calling CS, but know that if it is fixed, it will break again. Let me repeat, this will happen to every tx1000 series laptop.
Posted on Jan 29, 2009
1. uninstall hp wireless assistant
2. never buy hp products again
Posted on Nov 27, 2008
Same problem here with the tx1000 Pavilion notebook. First, a sudden loss of wireless, then repeated blue screens of death. Called HP and they said warranty expired 10 days ago. They want $450 to fix it. All the posts say this problem will reoccur so it sounds like a waste of time and money. I will never EVER buy another HP product. HP should recall the tx1000 Pavilion. For shame, HP!!!!
Posted on Feb 28, 2010
The problem lies between the board and the terminal slot of mini-pcie that sit your wireless card. The solder joint eventually create a gap due to heat cause by nearby power regulator in battery terminal and also the tendency to pop-up one of the lead terminals of the slot especially at the back ( pushing up when you insert the wifi card and screw it). Resolder the joints by applying heat using pointed soldering iron and avoid shorting the leads, as much as possible use magnifying glass. Hope this helps!
Posted on Apr 15, 2009
wireless  lan: pavilion tx1000 - noavatar_s.gif puma165165
I believe this to be a SCAM to get your EMAIL address. If you have fix post it. The fact is there is NO FIX. This issue is well documented on sites like hplies dot com. This issue will be the start of the end of HP. They are putting a blind eye to this issue. It is due to a defective Navidia chipset that there is NO FIX. Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Hi everybody, I´m goin to do a little tutorial about "how to fix wireless for HP TX1000"
If you want to know more about please write me at manuel_salruiz@hotmail.com
If already exist one, please let me know.
Cheers from México City
Did you think this was helpful?
Posted on Apr 11, 2009
Watch this video and ur problem is solve. thats for all tx1000 series problem because gpu solding is not good.
http://www.youtube.com/watch?v=ctHTF3oNdx
Posted on Nov 01, 2009
I discovered a repair for the problem with the TX 1000 blue screen and loss of wireless. You must remove the motherboard,. First remove keyboard then slide out CD tray then remove top cover. You should have a reasonable mechanical skill do do this. After you remove the motherboard apply a liberal amount of heat on the NVIDIA chips there is one on the top of the board and one under the heat sink assembly which is very small. After you apply the heat hold the chip down for about one minutes to allow it to reseat. You must also clean the old cooling paste off the chips and the cooling sink. I had to scrape mine off with a knife. Replace the rubberized heat sink pad with a copper shim you can make from a thin piece of copper or get one off Ebay. Apply a LIBERAL amount of new heat sink paste then put back together. If all else fails you can replace the motherboard which is reasonably priced, google it the HP part number is 441097-001 also there are many listed on Ebay also showing repair facilities for about $100. Good Luck your repair may be as simple as a couple of hours work, or send in for a inexpensive repair
Posted on Feb 02, 2010
  • lemmiemiller
Try this
reset comp
F8
let it complete
Posted on Jul 20, 2012
Avoid damage for your Laptop, The better solution is buy an external usb wi-fi card, just 39.00 more less, use the laptop until that expire and then, never buy again an HP Product,
Posted on Oct 28, 2011
  • puma165165 Jul 10, 2010
    Hi everybody, here is the Pro way to fix it.
    If you want, we can fix it for you for $90 with 120 days waranty.
    Cheers
    http://www.youtube.com/watch?v=i-iBj_Tpw...
  • lemmiemiller
You can see the solution at the web site at http://www.taydoc.com/index.php?board=12.0 their got the solution I did it for myself and it work again :)
Posted on May 14, 2009
    Problem Solver:
  • 7 Answers
This is a problem with many current hp laptops. to get moving on this issue, you need to plug your laptop into a router directly via an CAT5e patch cable (if need it can be bought at most major retailers including walmart) after plugging in, you should have no problem getting online and getting windows updates. windows has released an update with information as to go about reporting and resolving this issue
Posted on Jul 15, 2008
HP pavillion TX1000 network adapter
Is it showing in device manager as installed?This is a usual sign of graphic card beginnig to fail.
Jan 11, 2014 | HP Pavillion Tx1000 Tx1205amd Turion 64 X2...
My hp pavilion tx1000 wirele is not working
Sounds like a pretty reaccurring problem with the series...here's a link to the HP website with people with the same problem:
http://h30434.www3.hp.com/t5/Wireless-Internet-and-home/Problems-with-pavilion-tx1000-s-wireless/td-p/8613/page/6
You could always try reinstalling the driver to see if that cures it...here is a link to the wireless driver for the TX1000:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-61975-1&lc=en&dlc=en&cc=uk&os=2093&product=3185028&sw_lang=
Hope this helps
Mar 19, 2011 | Computers & Internet
How & i can get that wirelees card
You can find it on these sites:
http://www.getpartsonline.com/436253-001.html
http://www.shop.com/436253+001+HP+Pavilion+dv9400+tx1000+Series+Broadcom+Dual+Band+802+11n+PCI+Express+Laptop+Wireless+Card-188769408-p+.xhtml
http://wize.com/wireless-adapters/p1572145-436253-001---hp-pavilion-dv9400-tx1000-series
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 28, 2010 | Broadcom 436253-001 Wireless Adapter
Installed windows 7 on my hp tx1000 tablet pc and now no wireless card
wireless card issue is a typical promblem with the Tx1000, first thing is that you changed the operating system and window 7 is unable to pick up the wireless card hardware, and a driver is needed to be installed for the wireless card, which you can find at the Hp site or the broadcom site if you have the broadcom wireless card. Other then that, if nothing works, then try to see if the laptop can locate the wireless card trough the hardware/sound device manager in the control panel. After opening the device manager and scrolling to hardwares and the wireless card is not found, then this is the typical tx1000 wifi mystery promblem. This promblem is associated with the laptop overheating and thus caused the card expansion slot to become defect. This by far is the start of a more promblematic issue that many other tx1000 owner is having. Google "mysterious wifi card on hp tx1000" and there are thousand out there with the same situation.
Nov 04, 2010 | HP Pavilion tx1000z Notebook
HP Pavilion TX1000 wireless network adapter dissappeared and i can not see any network to connect to.
Just a thought:
There may be a switch or button that turns the wireless network off.
Check your manual or you may see the keyboard icon with radio waves going up, press this key. Check connection now.
Oct 16, 2009 | Computers & Internet
Pavilion TX1000 - WiFi card suddenly not detected
The solution is, get a USB wifi adapter, because that card is done. HP REFUSES to recognize this problem, and since the majority of failures happen after the warranty expires (mine did) HP just says you are SOL. You can get decent wireless adapters for $20, and your wireless problems will be solved. Unfortunately, expect your laptops motherboard/chipset/dc port to fail within a year :(
Apr 17, 2009 | HP Pavilion tx1000z Notebook
Bluetooth in HPTx1000
I believe there's a switch on the HP pavilion TX1000 to enable its Wireless LAN and Bluetooth.
To the right of the audio inputs and outputs is a slider switch and an LED. This one controls the wireless devices, both the Wireless LAN and Bluetooth and is blue while the wireless devices are enabled and red when they are not.
If you are using Windows Vista on your computer, you may go click on this link for instructions on how to use bluetooth with Vista.
Using Bluetooth with Vista
Sep 12, 2008 | HP Pavilion tx1000z Notebook
My network wireless adapter keeps dropping off
I would check with HP and see if they have a Vista driver for the wireless card. It sames to be the driver is in consistant.
Jan 03, 2008 | Computers & Internet
Wireless Device Disappeared
Go into Device Manager (right-click on My Computer, choose Properties, Hardware tab and Device Manager button) and expand the Network adapters section. What network adapters do you see listed?
Sep 12, 2007 | Computers & Internet
Computers & Internet Logo
6,131 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
