Question about Cannon Office Equipment & Supplies
Help!! I can't get my printer (canon i475D) to stop printing!! I have almost run out of ink & paper!! I click "cancel printing" but itg won't cancel!! Any suggestions wil b e appreciated. J. Hastings cfarmhouse@charter.com
    Scholar:
  • 51 Answers
You can manually clear out your print queue by doing the following:
open up My Computer
navigate to the c:\windows\system32\spool\printers directory
leave that window open, then go to start and right click on My Computer
Click manage
now there will be a menu tree, and one of the options will be "Services and Applications", expand that tree and click on "Services"
in the right hand side, there should now be a list of services available on your computer. scroll down and click on "print spooler"
now click "stop the service" (located in the upper left hand corner of the list of services)
once the service is fully stopped. switch back to the printers directory window.
delete ALL files in this directory.
swap back to the services window, and click "start the service".
your print queue should now be cleared out and the only thing that will continue to print will be whatever is left in your printer's actual memory. to clear the printer's memory out you can try unplugging the printer for approximately 15 to 30 seconds and plugging it back in.
I hope this solves your problem, and please do not forget to rate my solution.
Posted on Jul 14, 2008
How do I clear the in use alarm on a canon mx340 printer?
The in use alarm appears to be related to fax reception and printing. There are some options below that you could try:-
Memory Reception If the machine receives a fax under one of the following conditions, it will not be able to print the received fax and will store it in its memory. The In Use/Memory lamp is lit and Received in memory is displayed on the LCD. When the problem is resolved as described, the fax stored in memory is printed automatically.
  • Ink has run out: Replace the FINE Cartridge.
    i_green_arrow.gifRoutine Maintenance
    i_note_e.gifNote
    • You can set the machine to forcibly print a received fax even if the ink has run out.
      However, part or all of the fax may not be printed since the ink has run out.
      Also, the contents of the fax will not be stored in memory.
      If the ink has already run out, we recommend that OFF be selected for Auto print in FAX user settings to store the received fax in memory and print the fax manually after replacing the FINE Cartridge. After you replace the FINE Cartridge and select ON for Auto print, the fax stored in memory will be printed automatically.
  • Paper has run out: Load the paper and press the OK button.
  • A different size of paper from that specified by Page size is loaded:
    Load the same size of paper as that specified by Page size, then press the OK button.
  • Page size is set to other than A4, 8.5"x11"(LTR), or Legal (or 8.5"x14"):
    Set Page size to A4, 8.5"x11"(LTR), or Legal (or 8.5"x14").
  • Media type is set to other than Plain paper:
    Set Media type to Plain paper.
  • You pressed the Stop button to cancel printing of a fax:
    Press the FAX button
Alternatively turn the printer off, open the devices and printers section of Control Panel, right click on your printer and select "see what's printing" and left click on this. A window will pop up which may or may not contain a list of documents. If it does these must be cancelled (Menu - Printer - Cancel all documents). Once all documents have gone from the list turn the printer on and try to print.
Other than the above suggestions I would need to know more about your OS and exact problem. Hope this helps.
Aug 06, 2014 | Canon PIXMA MX340 Wireless Office...
I got error p07,how do i fix it...pls help..
Waste ink absorber full or platen waste ink
absorber fu
Aug 23, 2011 | Canon Pixma MP270 All-in-One InkJet...
How to fix B200 E30 error for mp198
A. Entering into service mode
  • Turn off the printer off is the printer power on. And remove the printer USB cable from your computer..
  • While the printer is OFF, press and hold the Start/Stop button on the some other canon printers model press Resume/Cancel button.
  • While still holding Start/Stop button or Resume/Cancel button, press and hold the POWER button.
  • When the POWER LED (green light) lit, release the Start/Stop or resume/cancel button (still holding the POWER button).
  • Still holding the power button, Press the Start/Stop button or resume/cancel button TWICE then Release the POWER button. Wait until LCD printer to display 0 (zero) number
  • After the display is 0, attach the printer UDB cable to your computer, its will detected new device installed (its normal), now go to resetting steps
B. Resetting Ink counter on the Printer
Run "service_tool 1050.exe". you can download the service tool software from this link:
http://www.ziddu.com/download/10241255/ServiceTool_1050.zip.html
  • Confirm detected USB-port numbers on USB port column.
  • Click "Main button" on Clear ink counter section. Make sure there are papers in the paper feed because the printer will print after the process is complete.
  • Click "platen button" on the "Clear ink counter" section. The printer will print again.
  • Turn off the printer and then turn the printer on. You printer is ready for use.
Aug 08, 2011 | Office Equipment & Supplies
I want to scan, but there is printing operation error. Ink has run out. And I can't scan because it says printer maintenance is in progress, scan later. Is it possible to cancel printer operation and...
Yes you can cancel the maintenance process of your printer..just do this steps 1. Click the start menu on the left side of the taskbar then click control panel 2. On the control panel click devices and printers 3.double click your printer icon 4. on the printer window right click the documents you want to be stop printing the chose cancel print.. after doing these steps you can start now scanning. that's all! hope it will help you
Jul 12, 2011 | Canon PIXMA MP160 All-In-One Printer
I have a Canon MX 340 printer. I have installed a brand new Canon 211 XL color cartridge, which I believe is compatible with this unit. Whenever I go to print something in color, I am getting the...
Click on Printer & Faxes in the Control panel. Right click on your printer icon. On the drop down menu click on properties. You will see many Tabs relating to your Printer. One of them will be Maintenance Tab Click on it and on the page which opens do the needful.
Jan 20, 2011 | Canon Office Equipment & Supplies
My Canon I550 quit printing.
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
bullet.gif Two flashes: Out of paper or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
bullet.gif Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. However, when printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it will be a cause of trouble.
See Replacing an Ink Tank
bullet.gif Six flashes: No print head installed
Install a print head.
bullet.gif Seven flashes: Defective print head
Contact a Canon service representative.
bullet.gif Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
i_note_us.gif Note
Canon recommends to call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on.
If the problem remains, contact a Canon service representative.
Apr 14, 2009 | Canon BubbleJet i550 InkJet Printer
Pixma 4200 compatible ink cartridge problem help
The ink detection is a critical function of the printer.
Ink actually acts as a lubricant for the heads, and running (Printing) without ink is equavalent to driving a car without oil.
I.E. It will seize eventually....
Hopefully you didn't print much without the ink, and your heads are still in good shape...
Here is a chip reset procedure....
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Feb 05, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Waste ink full
This step is a "reset" step for the Canon CLI8 cartridges. The original Canon CLI8 cartridges have a memory chip on the back of the cartridge, which sends a signal to the printer when the cartridge is empty. Your printer won't be able to determine how much ink is in the compatible cartridges, but you can easily monitor the ink level by noticing the ink level drop in the cartridge as you print (the cartridges are see-through), or by noticing low ink output on the printed pages when you run out of ink. The "reset" procedure below is the best procedure we know of to date to allow your printer to use Uni-Kit cartridges which offer a tremendous savings over the Original Canon products.
Oct 31, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
Canon S 520 doesn`t print
Two flashes: Out of paper, paper jam or paper feed error
If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL
button.
One of the ink tanks is empty. Replace it.
Remove and reinstall the print head.
Also, ensure that the protective tape has been removed. If reinstalling the print head
does not resolve the problem, replace it with a new one.
becomes completely full, contact a Canon service representative to have the waste ink
tank replaced. Canon recommends to call for service as soon as this error occurs. Once
the waste ink tank becomes completely full, printing will be no longer
possible.
Oct 19, 2007 | Canon S520 InkJet Photo Printer
Top Cannon Office Equipment & Supplies Experts
Cosma Papouis
Cosma Papouis
Victorman
Victorman
Greg Cann
Greg Cann
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
