I own a SimpleTech 250 GB, Model # 96300-40001-001. My CPU is an HP n7700s for which I'm upgrading my memory. I want to download my entire HD to my SimpleTech and have no instruction manual although I bought it new. How do I do this in "simple" terms? Thank you, Marvin Hays
Solution was to do nothing. I was working in the CPU and wanted to back the HD in case the HD was damaged and/or data lost. I did the work and everything turned out okay.
Posted on Jul 15, 2008
I need the dc power supply for SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Your solution is a 12 volt 1.5amp chord. With a negative outside/ positive inside plug tip polarity. Simple Tech model and part number: SYS1298-1812-W2
Jan 08, 2012 | SimpleTech 250GB USB2.0 7200 RPM External...
I want to increase the memory ram of my lap top: HP pavilion ze4910us What kind and how much memory can I install ?
You can upgrade, have a look at the specs;
Pavilion ze4910us Memory Specifications Standard Memory 512 MB (removable) Maximum Memory 1.0 GB Memory Expansion 2 sockets Memory Comments PC2100/2700 DDR SDRAM SODIMMs CPU Type 1.4GHz Intel Celeron M 330 Model Comments 400MHz FSB Memory Upgrade for HewlettPackard Pavilion ze4910us Laptop, the HewlettPackard Pavilion ze4910us Laptop takes the PC2100/2700 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your HewlettPackard Pavilion ze4910us Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for HewlettPackard Pavilion ze4910us Laptop.
Hope that helps.
Dec 15, 2010 | Computers & Internet
Error code 16
Code 16 is a hardware or firmware failure you need to Surf a little and reveiw the home page. Hold on ill get the address to take you too the solution
http://www.simpletech.com/support/support_downloads.php
This may resolve the problem and grant you access to your HD
Oct 18, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech 500 GB external hard drive - unresponsive
If you really can not get it to work anymore, you could try opening it up and connecting the hdd directly on a IDE/SATA port in your computer. This will only work if you have a desktop, for a laptop you would need all kinds of converters.
May 03, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech hard drive not working
I have that problem similiar to yours. My simple tech stopped working for like two years so i decided to open up my simple tech and removed my HD away from the old enclosure so I can try building my own external hard drive for the first time. I bought another new 3.5 enclosure, IDE/ATA for the old HD. I put it in the new enclosure and it worked!
It's the only solution you can have. No need to retrieve data or re-format your HD. You can leave it the way you like...if you wanna reformat it...up to you.
Jan 27, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech 80 GB Portable HD Won't Read
It sounds like a problem with the board inside the case,- the actual hard drive is probably OK. Opening the case will void any warranty but there may not be much left anyway. There should be 4 screws in the bottom of the drive,- front 2 may be hidden under a sticker. Try installing the drive in your new case or an empty drive bay inside your computer. I have had external hard drive cases fail before and the actual hard drive was ok.
Jan 23, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Computer memory upgrade
Standard Memory 256 MB (removable) Maximum Memory 2.0 GB Memory Expansion 2 sockets Memory Comments PC3200 DDR SDRAM DIMMs CPU Type 1.6GHz Intel Pentium 4 Model Comments 400MHz FSB
- Always believe HP - its there product - Staples is not the manufacture.
Jul 22, 2008 | Computers & Internet
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
