Question about Sony Playstation 3 (PS3) Console
Playstation 3 hello i cant figure out my WPA-PSK/WPA2-PSK security setting i figured everything else out but my security setting if i could get some solutions back that would be great
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey 192837465,
In order to determine your WPA/WPA2 settings you will most likely need to access your home network's router menu. Unless you're confident in doing this yourself, I would strongly suggest contacting your internet service provider (ISP) first for technical support or step-by-step guidance over the phone. Any changes that are made while accessing your router's main menu may directly impact your connection, and can even potentially cause problems with your existing network.
If you feel this shouldn't be a problem, the first step will be to sign onto a computer that is already connected to your secure home network. Once you're on the computer, you'll want to launch an internet browser and visit the default website for the router itself. This typically will be one of the following, but may vary depending on the make and model of your router:
192.168.0.1
or
192.168.1.1
If you're not sure which default website to visit, you'll need to refer to your owner's manual documentation for the specific address. When you've found the correct website you may be prompted for a user name and password. Again, these are typically found in the owner's manual documentation for most routers, but if you had your home network set up by a third party (like your ISP) it may be in the material that you were provided at the time of installation.
After you've entered the correct user name and password, you should be able to access the router's main menu. In the main menu, WPA/WPA2 settings may often be found by clicking on the "Wireless" or "Wireless Security" options. Again, where these are located will vary from model to model. You will need to write down the WPA/WPA2 key exactly as it is presented in this menu, and then enter it into your PS3's network settings in order to access the internet.
Additionally, please keep in mind that other factors may apply that could prevent your PS3 from accessing your home network, such as MAC filters.
If you're still unsure how to proceed, you may wish to contact your ISP or a Geek Squad® agent at your local Best Buy™ store for further assistance.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jul 15, 2008
Belkin model no.f5D8236-4v2 need security key
  • Open a web browser on the computer. In the address bar of the web browser, type http://192.168.2.1 and hit "Enter."
  • login using login details..
  1. Click on "Security" in the left-hand column under the "Wireless" heading.
  • Use the drop-down menu and select "WPA/WPA2-Personal (PSK)."
Select either "WPA-PSK, WPA2-PSK, or WPA-PSK+WPA-PSK2" as your Authentication; doing this will set the Encryption Technique automatically.
  • Enter a word or group of characters in the password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length.
  • Click the "Apply Changes" button to save the settings.
  • You've now set up WPA/WPA2 security on your network.
For reference,follow this blog-----Belkin N F5D8236-4 Wireless Router
Sep 03, 2012 | Belkin Wireless Surf Router (F7D2301)
How to set up a internet password for a mac with net gear
  1. se an Ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  3. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
    For Steps 4-9, refer to Figure A below.
  4. Select Wireless Settings from the Setup menu in the left-hand navigation bar.
  5. Under Wireless Network, enter your desired network name in the Name (SSID) box.
  6. Under Security Options, select WPA-PSK [TKIP] + WPA2-PSK [AES].
  7. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into the Passphrasebox.
    • WRITE DOWN or KEEP NOTE of your network name, security option and passphrase - you will require them to connect wireless computers and devices to your network.
  8. Click Apply to save the settings.
Mar 08, 2012 | Computers & Internet
How do you write an ASCII network encryption key?
Hello. Wireless security strength depends on the mode of encryption you are going to use (WEP, WPA-PSK [TKIP], WPA2-PSK [AES], WPA-PSK [TKIP] + WPA2-PSK [AES]).
WPA-PSK should be enough to secure your Wireless network.
ASCII - Choose from any key available on the keyboardHexadecimal - Characters ( 0~9 and A~F)
  • Before setting up wireless security on the router, make sure the computer you are going to use to setup wireless security is directly connected to the router using an Ethernet cable(wired).
  • To setup wireless security on the router, access the router user by typing http://www.routerlogin.net or 192.168.1.1 in the address field of your browser and then press Enter.
  • Enter admin for the router user name and your password (or the default, password).
  • Choose Wireless Settings from the Menu on the left.
  • Select WPA-PSK under Security Options. Input the Passphrase.
Passphrase can be 8~63 Hexadecimal characters or 8~63 ASCII characters.
Take note of the passphrase then click Apply.
Hope this helps. Have a nice day.
Nov 24, 2011 | NetGear Computers & Internet
Cant figure tha wpa - psk/ wpa2- psk number to connect my playstion
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the Playstation, laptops and orcomputers with these router's wireless settings. Then the playstation, laptops and desktopcomputers can communicate with your wireless router.
May 15, 2011 | Computers & Internet
Need to lock my connection
moz-screenshot.png Protecting your network with WPA/WPA2 security
Setup steps:
1. Connect the computer to one of the four LAN ports on the router.
2. Open a web browser on the computer.
3. In the address bar of the web browser, type http://192.168.2.1
4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
5. Click on Security in the left-hand column under the Wireless heading.
6. Use the drop-down menu and select "WPA/WPA2-Personal (PSK)".
7. Select either WPA-PSK, WPA2-PSK, or WPA-PSK+WPA-PSK2 as your Authentication; doing this will set the Encryption Technique automatically.
8. Enter a word or group of characters in the password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length. Note: The PSK (Pre-Shared Key) is case-sensitive ("A" is different than "a").
a. Unchecking the Obscure PSK box will allow you to see the security key that has been typed.
9. Click the "Apply Changes" button to save the settings.
Any/all wireless computers that connect to this network will be required to have this Pre-Shared Key (password).
Apr 07, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cant get the ps3 to connect to router with password that i set up...computer does just fine
change the wireless security settings options in router Security Options None
WEP WPA-PSK [TKIP] WPA2-PSK [AES] WPA-PSK [TKIP] + WPA2-PSK [AES]try this link it might help http://manuals.playstation.net/document/en/ps3/current/settings/connectwireless.html
Dec 29, 2010 | Computers & Internet
Lost paperwork to my berklin wireless router, need to know how to put a security password to log on. i live in an complex and there are some people i believe are hacking in. my computer is new and running...
Hi here is the answer if you want to setup wpa/wpa2 security then follow the below seps
Sep 26, 2010 | Computers & Internet
I cant open youtube because my parents made a password on my computer to acess the internet and i cant watch any videos
Check this it wil fix your problem
if your security is wpa then uncheck obsure psk your password you can make of not of it
Setup steps:
http://en-us-support.belkin.com/app/answers/detail/a_id/35
Want to secure my network
go to address http://192.168.2.1
  1. click login in top right corner of the page, and then submit
  2. Click on Security in the left-hand column under the Wireless heading.
  3. Use the drop-down menu and select "WPA/WPA2-Personal (PSK)".
  4. Selecteither WPA-PSK, WPA2-PSK, or WPA-PSK+WPA-PSK2 as your Authentication;doing this will set the Encryption Technique automatically.
  5. Enter a word or group of characters in the password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length. Note: The PSK (Pre-Shared Key) is case-sensitive ("A" is different than "a").
  6. Click the "Apply Changes" button to save the settings.
Jan 03, 2010 | Belkin (F5D9230-4) Wireless Router...
Sony Playstation 3 (PS3) Console Logo
78 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
