Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door opener remotes
I purchased a home with a Sears HBW1255 139.53681B I have two remotes but can only get one to program.. I tried pushing the buttoms together that didn't work either. I also bought a clicker compatible to the existing remotes and even with those only one will program.
How do I get two remotes to work for the opener?
Joseph DeBenedetto
  • 2 more comments
  • DaveWilliams Aug 07, 2008
    I have a Sears Model 139.53954 purchased in late 03. Recently replaced safety sensor lights. Having replaced the sensor lights I can now only get it to program to 1 remote. If a program to 1 it will not program to a second, if I clear and program to second it will not program to first.
    I purchased new 3rd party remotes, Chamberlain Clicker Universal Remote Control, KLIK1U, rather pricey, and have the same problem.
    My opener programs by button not dip switch.
  • bjadams688 Aug 10, 2008
    I have this same exact issue. Moved into a house with an existing Sears garage door opener, and I can get either remote to program by itself, but I can't get both to work at the same time
  • bailey154 Aug 16, 2008
    I have a Sears HBW1127 Garage door opener with 2 remotes HBW1255. I have replaced batteries in both. Each will program individually but I cannot get them both to program together. How do I program 2 remotes to one opener?
  • Anonymous Jan 25, 2009
    I am able to open the door by the wall button only.I can't use the hand remote nor am I able to program any of the car factory remotes.Please email me at tonyaubrey@sbcglobal.net
  • 118 Answers
Guest- You opener is locked. Hold down the lock button on the wall control for 3 sec. and it will unlock the opener.
Posted on Jan 29, 2009
I had the same problem and found a very simple solution. There is a small metal tab on the back cover (where the battery mounts) that should contact a small metal area on the circuit board. I bent the tab up slightly and my remote now works.
Posted on Jan 14, 2011
I really need your help. My Craftsman unit model number is 139.53615SR manufactured 1/92. I have a three car garage. The original two remote controls were lost and since then I've used the setting in my...
Have your neighbor bring over his remote and open or close your door with it. Then hold the smart/learn button in for 6 seconds on your opener. Then see if he can open your door. He shouldn't be able to because that procedure erases the memory in your opener. No remotes should work. You need to get that remote #53778 back and program it and then see if your neighbor can open your door. If he can open your door at any point after you have held that button in for 6 seconds you need to get a new door opener.
Oct 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
Is there a univeral remote for craftsman garage door openers?
Depends on the age of the opener. The model number is on the end of the opener closest to the door. Using it go to Sears parts and you can find out if the remote is still available.
Dec 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Only one remote programs
It is really important to that you have the correct remotes for your opener. The model number is on the end closest to the door and starts with 139.
Dec 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
If you go into the actual unit (on the ceiling) you will see the "code" of the opener. You then program the inside of the remote(s) (take them apart) to match what the actual opener is. Or you can look at the one that works and make the other(s) match that. It is a series of little toggles.
Feb 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Grage door blinking yellow, click and won't open with anything.
TRY RESETTING THE UNIT BY UNPLUGGING IT FOR ABOUT 5 MIN.
IF WHEN YOU PLUG IT IN THE REMOTES STILL DON'T WORK TRY TO REPROGRAM THEM.
IF STILL HAVING TROUBLE--
COUNT THE FLASHES - GOTO LIFTMASTER.COM DOWNLOAD A FREE PDF FOR A SIMILAR UNIT (THE MODEL NUMBERS ARE DIFFERENT BUT THE CODES ARE THE SAME).
HOPE THIS HELPS
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,553 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
