Remote needs bateris every day - Televison & Video
Remote has gotten something spill on it.
Posted on Jul 14, 2008
LG Magic. Why does it drain batteries?
If what I am seeing is correct, the LG Magic remote is a remote with a lot more features, and a lot more power demanding features than a regular remote control.
Dec 09, 2015 | Televison & Video
SAMSUNG TV MUTING IT SELF
Hi, you may are having problems with your Remote Controller, try this for the fowlling order:
1?- remove the bateries from the remote controller
2?- turn on the tv with the power button on the tv
3?- wait a little bit, to see if it is mutting itself
4?- if not, your problem may be with the bateries, try new ones
5?- if the tv still mute itself you have a faulty remote controller, buy another one
Oct 16, 2013 | Samsung TV CS29Z40
Keyless for a ford freestar 2004 i replace the batery in the remote control and now the remote not work
You need to reprogram it here are the steps
1. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in
RUN. Door locks will cycle to confirm programming mode.
2. Within 20 seconds press any button on first keyless remote. Door locks will cycle
to confirm programming.
3. Within 20 seconds, press any button on second keyless remote. Door locks will
cycle again to confirm programming.
4. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Mar 13, 2013 | Televison & Video
Just can not turn modele191va on with remote. Just got it home and nothing works . Please help
Generally:1step check bateries in remote
2step is to find IR mark or simular point on device ,and check that is not some object in front which can broke or close or hide that,in way that signal from remote can not came in controled device
3step is to come more close and find IR glass on device and put remote top side where is IR(infra red) diode to exact direction
4 step is to visually check top of remote,and remote IR signal point of reception,maybe is some sticker on it.
And if is new,remote and device,which is not previouslly used, sometimes makers even they put charged batteries,they put some paper or plastic which prevent contact of bateries that bateries in remote get discharged, so look for it,and remove it..
(sorry i dont own device,but this is way for all, if your device and remote not use IR signal that only means that remote not need be putted in allmost good direction,if work with radio signal,but i dont belive it,as its rare,and more expensive way for remote control)
Aug 30, 2012 | Vizio Audio Players & Recorders
I have a 2004 Kawasaki zzr 600 that does not keep the charge longer than 2 days. What is causing this problem
hi, you probably have a "almost dead" batery, but in order to properly check, proceed as folows:
1 - give the batery a full charge
2 - disconect both cables (+) and (-) from batery
3 - check charge and see if batery holds it - a good batery must keep 12,7 to 13,2 volts for a very long period
If after this test,considering that batery is ok, then chek your wiring loom for ground losses
good luck
Sep 13, 2011 | 2004 kawasaki ZZR 600
Change or charge battery
Hi, depending on what happens when the batery is fully charged, does it go flat aftera day or two or does it stay charged? If it keeps going flat take it to a battery centre to test the amps that the batery makes. I f the amps is out the battery is dead.
But
If the batery is fine after charged and the amps is correct and the bike still makes the batery flat.
Then you have to replace the Stator and the magnitor.
Dec 09, 2010 | Yamaha YZF-R1 Motorcycles
I have a Hitchi Radio/CVD player KC-92CD and I don't know what batteries I need for the remotre
Take out the batteries and check?Very small long tube battery kind?That the AAA kind of bateries.Long tube battery kind?That the AA kind of bateries.Square battery kind?That the 9 Voltage batteries kind.
Oct 21, 2010 | Hitachi Televison & Video
Batery hang problem
batteries have a charge memory in the, when you purchase a new battery the best thing to do is to fully drain the battery before charging it up, this will tell the battery that it needs full charge, if you charge the battery before this it will only charge the battery to a certain percentage.
what you need to do now is find a way to fully discharge the batteries
kind regards
Dec 23, 2008 | HP Compaq Business NX9110 Notebook
Broken wii remote
Try windex on the sensor bar on top of your TV. Also check that the sensor bar is properly connected, it's not reading that particular remote.
Nov 28, 2008 | Nintendo Wii Console
Bose 321
I have same issue. This happened on 12/31/2007 after 13 months of operation. Though remote is not controlling the unit, it controls TV. I went to BOSE showroom (Chennai, India) and remote worked perfectly with their GS display unit. Then I went to service center. Serviceman promised me to send a CD with software upgrade. Let me wait for a day or 2 receive CD and test it. Have you got any solution.
Dec 28, 2007 | Bose (321GS) System
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
