Question about Panasonic PV-GS29 Mini DV Digital Camcorder
Camera WILL NOT turn on!
Here's my problem: My camera will not turn on when I push the switch to the on position. I have tried minor things that I can do myself without tools or the risk of damage. I have fully charged the battery, and tried using the power cord but the red light will not indicate that the camera is on. This is weird: but one way that it does work is when the battery is in place and I eject the tape, the red light goes on above the switch and the tape ejects. If it wont turn on why will this function work? I'm puzzled. How do I get this thing to work?! Thanks for your help. Same here.....
    Scholar:
  • 101 Answers
If you live in a humid environment or the camera has been subjected to moisture, it may be shorted or it may have a moisture sensor that keeps it from turning on. Try taking out the battery and the tape, open the tape door, and use a blow dryer on low to dry it out, you can even use a 50-70w light bulb and position it near the open tape door and leave it on for an hour or so, make sure the bulb is not touching any plastic or it will melt it. I also agree with Abrsvcs that it may be a faulty power switch, but try drying it first, as I have seen many camcorders stop working completely if subjected to any slight amount of moisture or humidity.
Posted on Jul 23, 2008
  • 1,183 Answers
As told by Abrsvcs, the camera needs to be taken in for repairs.
Following is the link for the Panasonic support
http://www.panasonic.com/business/provideo/support/tech_support.asp
Thanks
proton
  • 4,234 Answers
The eject funciotn will work even with the power button in the off position. It is essentially an override command. The power switch should have a couple of positions, be sure that the camera is not in the standby position. With teh Eject working, the power system is working and some commands are understood by the microprocessor inside the unit. It is possible that the switch assembly itself is bad. I have seen this occur on a number of occasions.
I would not attempt to repair this yourself unless you have worked on cameras before. There is very little play in the cables inside and it is easy to tear one.
I would take this in for repair.
Dan
Posted on Jul 14, 2008
  • Panasonic Master
  • 19,396 Answers
It can be a faulty battery
  • Ginko
    Ginko Jul 14, 2008
    It can be a faulty battery causing a short, take it to your local shop and ask if they have a spare battery to test it before buying a new one.
  • Ginko
    Ginko Jul 14, 2008
    Check also that there is no liquid on the battery contacts inside the camera.
    If it is not the battery there may be several faults causing the same, board faulty, lens jammed shorts etc.
    In this case you should contact Panasonic service. Call the number listed on last pages of your manual.
    Check also guaranty terms
Nikon coolpix S3000 - lens error! - appears after turning on camera, lens goes out then in, message on screen will not go away, camera will not do anything at all except turn off. Does this mean the...
I got a same problem with different mode.
I planed to send it back to manufacturer, before packing it, I just knocked the back of camera with my palm in switch ON mode... the lens just retracted into normal position...
It can work for you to......
I am not an expert, it is just my experience I am sharing here.
If Lens struck with Lens Error!! on the screen, charge the batteries, switch on the camera, when the lens tries to move, feel free to knock a bit hard at the back of the camera with ur palm...... you cant hurt it any more than it already is., it might help the misplaced gears to aline back in if it is a minor problem.
Sorry about this un expert advice but it worked for me...
Just try it before sending in...
Feb 26, 2011 | Nikon Coolpix S3000 Digital Camera
Nikon Coolpix S610C dropped camera turns on and lens will extend but turns off and lens retracks in a few seconds. The on/off button does not always respond.
Feb 14, 2011 | Nikon COOLPIX S610c Digital Camera
When i turn on my camera it says that the memory card is protected. and it says to reset the switch on the card. how do i do that?
It seems you have a SD memory card with a write protect switch on it.
This s a safety feature so that you do not accidently erase stuff.
You need to remove the card fom the camera, and examine it closely for a small slide switch.
To remove from camera, you normally push it in a little to have it pop out a little, like a push button, then it's released and can be pulled out easily.
Look on the edges, bottom and sides. If you see a very small lever slide it with a finger nail to the opposite position and return the card to the camera, again pushing it in to click and pop out just a little to lock in place.
Try camera again.
If there is no switch on the device there is another problem. Try formating in a PC.
Dec 28, 2010 | Kodak Easyshare M341 12.2MP Digital Camera...
Hi i have a Panasonic d-snap, model sv-av50 but i loss my driver cd, how can i get the drivers & sd jukbox ver 4?
put the camera on the dock or use the usb cable turn it on then push the switch below the record button in the downward position. your pc will then pick up the camera and install the drivers. I too spent 2 days looking for the drivers for this thing.
Sep 20, 2009 | Panasonic SV-AV50 Digital Camera
Card is locked
There is a small lock switch on the side of the memory card, slide it to the other position and try again.
1. Turn the camera off
2. take the memory card out
3. slide the lock slider to the other position
4. place the card back in to the camera
5. turn on the camera.
if the problem remains repeat steps 1 to 5.
if the problem still remains its now obvious the issue is not with the memory card, you may try another card on the camera if you wish.
The most likely cause for this issue is in the memory card reader of the camera. there is a small lever/switch on the side of the card reader that detects if the card is locked or unlocked. You would have to take the camera apart and pull the stuck lock "detector"/switch up so that it doesn't touch the the metal.
Sep 06, 2009 | Canon PowerShot SD850 IS / IXUS 950 IS...
Error message "push the reset switch"
The Panasonic manual for this problem is stupid. It says "Pushing reset button MAY help resolve the problem"...
nothing else-no explanation of possible problem.....worthless.....
Aug 10, 2008 | Panasonic PV-GS300 Mini DV Digital...
Lens stuck open
try little rubbing alcohol around outer surface of lense this should loosen up the sticky ness of it
remove the memmory card and turn on this should reset camera
May 13, 2008 | Samsung Digimax 4500 Digital Camera
PUSH THE RESET SWITCH PROBLEM
hmm...maybe:
You need to know in which position was camera turned of.
So try turning it on in RECORD OR PLAY position.
It will work then...
May 04, 2008 | Panasonic NV-GS15 Mini DV Digital...
Press the reset switch
Same "Push the reset button problem in panasonic gs 200 camera. i turned it upside down but it didnt worked out. its an expensive camera please please please tel me how to fix "Press the reset switch" problem
Dec 26, 2007 | Panasonic NV-GS11B Mini DV Digital...
Panasonic PV-GS29 Mini DV Digital Camcorder Logo
131 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
