Question about Dell E173FPb 17" TFT LCD Monitor
Power button is flashing green
I have tried turning it off and on, pushing the power button, messing with the mouse, etc.
  • 105 Answers
These models are prone to shorting of the inverter drive transistors, 2sc5707. An in-circuit ohm meter test will reveal which are shorted if any. They should be replaced in pairs even if only one is shorted. Bad solder joints on the transformer can cause them to short so look for bad solder.
Monitor Mike
Posted on Oct 02, 2008
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red Light
you need to change your power box there is a bad connection with the wires. its over heating you might whant to buy another at game stop or take it in to get fixed. the more you messed with it it might mess up your whole system.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
Mouse works for a few minutes then stops working
This has worked for others:
First, power off the mouse, then push on the green-lit button on the transmitter that you plug into your USB. (It doesn't feel too much like a button but you will see that it starts flashing.) Hold it down for about 15 seconds. Then power on your mouse and you will see that it should start working.
Aug 24, 2011 | NexxTech NWOMMI Mouse
I put in new batteries but no luck. No lights go ...
Answer:
With the buttons toward the top:
The top LEFT slider button is for power. Slide toward the outside for ON. Light on top of mouse turns green after about 1 second, and stays green for about 10 seconds (assuming the batteries are okay). When the batteries are failing, it blinks red.
The top Right PUSH button sends a connection signal to the PC. When pressed, the indicator light on the top flashes green and red, indicating the special connection signal.
This is the mouse side of the equation (good batteries, slider turned on, connection button pressed and released.).
NOW: the PC must have a working receiver, with drivers installed, and Bluetooth software installed. it sould detect the mouse. If it asks for a passkey, say none (mouse doesn't need passkey).
You should not need Microsoft Intellipoint. it doesn't have a configuration for this particular mouse model anyway.
Good Luck!
May 21, 2010 | Microsoft Bluetooth 5000 Mouse
Wireless Logitech mouse with NO connect button on it. Only buttons on it are Power and Reset (and one to open battery case). Cannot figure out how to connect to receiver. Was previously connected, but I...
Ok, try this in the steps ordered
1 remove the receiver from the USB port
2 remove the battery from the mouse
3 turn on the pc
4 after everything is loaded on the pc, plug the mouse receiver into the USB port
5 put the battery back in to the mouse and let it "find" the receiver.
If these steps don't work, try doing the steps and use a different USB port. If that doesn't work try a different battery in the mouse.
If none of this works and the receiver hasn't been bent (happens allot in laptops), then it sounds like your mouse took a dump.
Mar 18, 2010 | Logitech Cordless Mouse
Swissgear spyder mouse will not work
Had the same problem with my wife's...you have to push the connect buttons on both the receiver and the mouse almost simultaneously after turning the mouse off and back on. Keep trying, it took me lots of tries.
Jun 07, 2009 | AVENUES The SPYDER SwissGear Wireless...
My laptop don't turn on but the green light in
you have power but no screen? try swipping your finger over mouse pad or pushing keyboard....also try a power cycle...unplugging battery but leaving the the poewr adapter in..push power button down for 1 minute....then press poewr button again...it might solve the problem...if not shine a flash light at screen see if you can see a faint image..there might be a problem with the inverter or backlight that lights up the screen...also try external monitor ifyou hvae one...and make sure computer power adapter is good and the battery is good...if this doesn't help you might have to get it serviced...if under warranty call warranty companie...if not under warranty call local computer repair shop
Apr 16, 2009 | Acer Aspire 5520-5908 Notebook
MY UPS PRINTER IS NOT RUNNING ZEBRA: UPSLP2844
Bit of a tough one to know where to start "Printer is not Running"
They usually sit on a bench and do not run anywhere :-)
Is your power supply plugged in?
Is there a green light on the power Supply?
Is the printer turned on?
Does the green feed button cause a label to eject?
If yes to all the above then try a reset
1) Turn printer off.
2) Hold down feed button whilst turning printer on.
3) Let go of the feed button as soon as it starts to flash and then wait.
4) Printer will measure out 4 labels then print out a Hex dump ending with a not to "Push Feed to Exit"
5) Push feed
Follow the above instructions, if you mess around tapping the feed button (not following the above) you can change the printer between line mode and page mode. To swap that back is another storey.
David
Dec 09, 2008 | Zebra LP 2844 Thermal Printer
Light flashing and tv won't turn on
Hi there, I have a Mitsubishi HDTV 1080 and when I tried to turn it on the tv this morning it wouldn't turn on and the power light is flashing green. I pushed in the reset button but it just keeps flashing and still won't turn on.
Oct 05, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Green Light Flashing in Power Button
so the sound of mouse click is from the button being pushed.
is the light flashing codes at you in the form of flashing?
looks like you may have a short in the p/s.
Apr 09, 2008 | Philips 55PW9363 55" Rear Projection...
Dell E173FPb 17" TFT LCD Monitor Logo
65 people viewed this question
Alun Cox
