Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf360 I get error F-01. Do you know what causes this error and what my machine need sto put it right?
  • 97 Answers
i think this is related to a motor fault:-
check the brushes
check all the wiring harness (sometimes they rub and break)
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 01, 2008
What's your question?I have washing matching hotpoint Aquarius wf360 with erorr code F-01
Motor triac problem. The triac would be in the unit that controls the motor speed.
May 04, 2015 | Hotpoint Washing Machines
Hotpoint ultima wt741p is showing F:01 on the display screen when the machine starts up -the machine starts but no water comes through and the drum stays idle - any advice please ????
F:01 is display say some error problem occur in your machine, maybe the motor that pump water to fill the machine has not working or its sensor that water is flowing is not working also.
Jan 29, 2011 | Hotpoint Washing Machines
Error code on washing machine wf640
have you checked you have turned on the water back on???? check but red and blue, or just blue it must be 90degree left or right.
Mar 08, 2010 | Hotpoint Ultima WF860 Front Load Washer
F-01 error hotpoint WMD960P
Error code F01 is indicating ashort circuit motor triac.
Check connections on motor the motor plug and then control module.
Please rate my solution.
Nov 17, 2009 | Hotpoint Washing Machines
Error code f-01
Error code F01 indicates a short circuit moTor triac.
This is part of the electronics that control the motor, it can be caused by worn brushes in the motor or a faulty pcb .
to check the motor brushes, remove the rear panel,, remove the belt and undo 2 screws that secure motor, lever motor back with a screwdriver or similar, unplug the motor leads , and remove the motor.
You will see the brushes at the armature end.
remove and inspect, you should see if they have shorted by discolouration of the armature.
If you clean the armature with emery paper and it looks o/k, then you can try fitting new brushes, but there is no guarantee that it will work,as the pcb may have shorted.
This being the case then it could be quite expensive to put right.
Plz rate my solution.
Jan 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Error code f-01 on hotpoint washer dryer aquarius model wd 640
f-01 means there is a motor problem.
may be the motor and/or the circuit board that controls it.
Error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint WF640
the f-01 error code on your hotpoint all in 1 washer/dryer is a short circuit code for the motor. the only way to clear the code is to have a service tech come and inspect the reason for the error.
May 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wf860
I've the same problem with my Hotpoint washing machine WF860P giving F01 flashing on screen ,machine not working, how could over come this and make the machine work again?
Please if you know the solution let me know
Aug 15, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
