Question about Canon NP 7130 Black and White Copier
CANON NP 7130
Hello, I'm having a problem with my canon np 7130 copier and canon can't help me. Whenever I make a copy the machine prints out a page with the image from the original document in the back but full of a black shadow from top to bottom, the page is covered in black with the image on the back, and going down the middle of the page there is a white intermittent vertical line. What could be causing this? and how can I fix it?
  • 318 Answers
This is your drum unit or transfer unit that must be replaced.In what area are you?
Posted on Nov 03, 2008
I have a Canon NP 7130F which prints out only blank paper
check cartridge setting how-
check all spring on correct place
check ITR spring touch point
check printer to cartridge touch point
Apr 01, 2014 | Canon NP 7130 Black and White Copier
Canon NP 7130 F copier Copies are dark in some areas and light in other areas. We no longer have a service agreement on this machine. I cleaned the feeding roller in the ADF, new toner in machine,...
Enter in service mode and do an cartridge adjustment. Maybe the toner is not uniformly distributed in cartridge. Also you can search on internet for service manual, this may help you a lot.
All the best !
Dec 03, 2017 | Canon NP 7130 Black and White Copier
Will not reset for next copy
Sounds as if it is low on toner.When they run low, the motor will continue to run trying to add more toner.The toner add system is a glorified flour sifter.Eventually it will set the add toner on.Good Luck
Mar 24, 2009 | Canon NP 7130 Black and White Copier
Double ptinting
try to clean the upper roller on heating section the final stage of the machines if the image is seen to be of the first objected copy this solution is only if you observed that the image of the previus object (source paper) is printed on the next copy or it repeats printing the lines.
and if it so replace or fix the new oil roler in heater unit.good luck vote me pls
Aug 27, 2008 | Canon NP 7130 Black and White Copier
Canon np 7130
first try to look for the drum if it scratch no matter the distance btn lines
then if the drum is ok. look and adjust the position of the lens to home position.
Aug 07, 2008 | Canon NP 7130 Black and White Copier
Gray background, but copied text is visible
With toner being dropped I would take a close look at the cleaning unit next to the drum. Sometimes they become clogged or wear out. Inside the machine, can you see toner that has spilled or piled up? If so that is an indication of a faulty cleaning unit.
MM85
May 23, 2008 | Canon NP 7130 Black and White Copier
Canon np 7130f keeps running
does anyone know where to get an owners manual for cannon np7130f online for free??
Jan 22, 2008 | Canon NP 7130 Black and White Copier
Canon imagerunner 7130 b/w copier
Is it copying the size of a Letter paper?
If yes it's not set to Legal, go in the menu and set to Legal.
Oct 20, 2007 | Canon NP 7130 Black and White Copier
Canon NP 7130 Black and White Copier Logo
283 people viewed this question
old marine
old marine
