Back to:
Tags:
Kenwood KAC-7202 Car Audio Amplifier
Kenwood kac-7202 (by 3 users)
posted by Dadragon0813 on Jul 14, 2008
i was riding and my subs just went out, i check all cables and i cant find anything, the amp comes on red light in the triangle and fan blows, but no bass what could it be.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Sep 24, 2008
i have the kac-7202 kenwood amp and im not sure if the red light is sopposed to be on because my subs pump. the louder i turn it up on my deck the fuse on the amp blows, everytime. what the hell. can someone answer this?
Comment by ekopel, posted on Jul 17, 2008
I have the exxact same problem...for like 2 minutes, it would only output bass if it was more than 50% volume. I ordered a new HIGH to Low converter...maybe thats it?
Solution #1
posted on Aug 19, 2008
Not Rated (0)
InVision_A_V
Rank:Wiz Wiz
Rating: 83%, 27 votes
Nope it's not a high-to-low level converter problem, it's most likely a problem with one of two things. 1) either you've blown the output stage in the amplifier, or 2) you've hooked up your subs wrong and your amp is seeing to low of an impedance. The amp is supposed to be 1ohm stable, but we had the same problem. When the indicator light goes red it means that the amp has gone into protection mode, now you have to figure out why. If something in the amp goes bad or just disconnects from the board it will cause power protection mode. If you fry something on the board because you are running the amp to hard or at the wrong impedance it will go into thermal protection mode, however there's no simple way to figure out which has happened.
Have you tried hooking up some different subs to see if the problem remains? try this. If the problem no longer happens then you know it's your subs, if it does still happen then you'll know it's an internal problem.
Years ago I had a Kenwood KAC-821; long story short, I melted the main power wire right off of the board, everytime I turned the system up the amp would shut down.
Take you amp to an authorized dealer and have them bench test it for you.
Let me know what you find out.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on kenwood kac-7202:
I don't want to Accept this solution
Can you Help with these Car Amplifiers problems?
Ford Escape with premium sterio. Added KAC-7202 and worked...
Car Amplifiers
you can request for more solutions by requesting solutions...
Amp powers up (switchable) but has absolutely no output -...
how did you fix the problem with your kenwood amp? mine is...
did you figure out you problem with it
Loading problems.
Repair Service
Find Car Amplifier Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
