I'm going to assume that you are talking about the New Xbox 360 Slim that has wireless capabilities. You must go into your settings and go to the network settings. When you choose to connect wireless-ly, choose your routers signal, and if it has a passcode you must enter this in to connect to your router. If you are using the older "fatboy" xbox, you cannot connect to a wireless router unless you purchase the xbox wireless network adapter. Please note that you cannot use the wireless network on the new xbox slim if you have a network cable plugged into your console!
The 360 requires a wireless adapter, which I assume you already have. This would connect to your wireless router or other wireless access point you have in the house.
If you are having issues connecting still, make sure your High Speed modem is a docsis2.0 modem or higher.
If you are still unable to connect through your wireless, I suggest plugging an ethernet cable directly from your router into your 360. This is to make sure you get the best and most reliable connection.
If location of router versus location of XBox is a problem, a long ethernet cable can be purchased from a website like Newegg or Amazon for a cheap price.
Follow these instructions to set up the Xbox or Xbox 360
connections to a wireless home network. These instructions assume the
wireless router is already installed with a working Internet connection.
If after following these instructions you are unable to network your Xbox with the wireless router, see -
Connecting Xbox to Wireless Networks - Why Things Go Wrong
Here's How:
Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
Turn
on the console and navigate to the wireless settings screen. On the
Xbox, the menu path is "Settings -> Network Settings -> Advanced
-> Wireless -> Settings" On the Xbox 360, the menu path is "System
-> Network Settings -> Edit Settings."
Set the SSID
(network name) on the Xbox to match that of the wireless router. If
your wireless router has enabled SSID broadcast, the SSID name should
appear pre-selected on the Xbox display. Otherwise, select the "Specify
Unlisted Network" option and enter the SSID there.
Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
Set the Security Type to match that of the wireless router. If your router uses WPA
encryption and the type of adapter connected to the Xbox does not
support WPA, you will need to change your router settings to use WEP encryption instead.
Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
Save your settings and verify the network is functional.
On the Xbox, the Wireless Status screen displays whether a connection
has successfully been made with the wireless router, and the Connect
Status screen displays whether a connection has successfully been made
through the Internet to Xbox Live.
On the Xbox 360, use the "Test Xbox Live Connection" option instead.
Tips:
Even
when your wireless connection between the Xbox and the router is
working perfectly, you may still experience difficulty connecting to
Xbox Live. These issues can be caused by the quality of your Internet
connection or the firewall and Network Address Translation (NAT)
settings of your wireless router. Additional troubleshooting may be
required in these areas to achieve reliable Xbox Live connections.
Turn on the console and navigate to the wireless settings screen. On
the Xbox, the menu path is "Settings -> Network Settings ->
Advanced -> Wireless -> Settings" On the Xbox 360, the menu path
is "System -> Network Settings -> Edit Settings."
Set the SSID (network name) on the Xbox to match that of the
wireless router. If your wireless router has enabled SSID broadcast, the
SSID name should appear pre-selected on the Xbox display. Otherwise,
select the "Specify Unlisted Network" option and enter the SSID there.
router uses WPA encryption and the type of adapter connected to the Xbox
does not support WPA, you will need to change your router settings to
only supports WEP.
connection has successfully been made with the wireless router, and the
Connect Status screen displays whether a connection has successfully
been made through the Internet to Xbox Live.
If you need more help post back!
Thumbs and testimonial are welcome!
I assume the wireless router is configured correctly and the PC can connect to the wireless router and the Internet. Follow these instructions to configure the XBox.
In the Xbox Dashboard, go to My Xbox and open System Settings.
Select Network Settings, Configure Network.
On the Basic Settings tab, select your wireless settings.
Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
If your network has wireless security, enter your WEP or WPA key.
You can try fixing this using Xbox360 repair guide that covers almost all xbox 360 problems, you can get a copy from here http://xbox360repairguide.com
Had the same problem connecting zyxel NGB334W to XBox 360. Other computers and devices would see the SSID but the XBox 360 would not. I had no luck talking to the techs at zyxel, they said it was incompatible with the wireless XBox device. Good news!!! This can be resolved. I went into the setup (192.168.1.1) / Wireless Lan / Advanced / Wireless Advanced Setup. Under the 802.11 mode set to 802.11b. Factory is 802.11b/g and this was not seen. Hope this helps you out.
Basically i know its a rip off but if u wanna use wireless with the xbox 360 u need to buy the official xbox 360 wireless router which is about £60.There is another way if u dont use wireless u can connect the xbox 360 to a router or the phone line then go to your windows firewall and set it up manually.Hope this can help you .Joe stevenson
