Question about Car Audio & Video
Need a lightbulb for behind station/clock display delphi delco radio in pontaic 2003 product id 2001 ser man 2 part # 09390762 no number listed on bulb or plastic base bulb & base one piece LeRoy norfarm@cvol.net
5 Suggested Answers
  • 30 Answers
SOURCE: Oscillator out. No radio and clock is locked up
could be a 555 ic. 555 is the widest used timer ic or "clock" chip. you will need to check the gates of this ic.
Posted on Sep 15, 2009
  • 146 Answers
SOURCE: I BOUGHT A RADIO THAT
can you still get to the silverado??
if so open the glove box and look for a small sticker with numbers on it and no other info - that is the unlock code for the radio
if you cant get back to that car you might be in a bit of trouble because they dont give out unlock codes or the people stealing them wouldnt be discouraged from taking them that is whole point for unlock codes
Posted on Mar 28, 2011
emissionwiz
  • 64286 Answers
SOURCE: Delphi Delco P/N 12244075 was
Hello
The factory radio connector wire colors go by Make, Model and year of the Vehicle, please provide this information and I'll get the wire color disignations for you asap.
Posted on May 01, 2011
  • 407 Answers
SOURCE: I want to connect a
1997 Buick Lesabre Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Radio Ground Wire: Black/White
Stereo Radio Illumination Wire: Gray/Black
Stereo Radio Dimmer Wire: Brown/White
Stereo Radio Antenna Trigger Wire: Dark Green
Stereo Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6? x 9? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Posted on May 12, 2011
pctech1
  • 1940 Answers
SOURCE: I have a 1992 geo
  1. Press the RCL/PROG button to set the time.
  2. Use the TUNE button to adjust the hour (left TUNE arrow) and minute (right TUNE arrow).
Posted on May 31, 2011
I need the stereo code for a 2000 grand am i just bought it and the stereo is on LOC ...i puled out the stereo and on the top it says delco electronics part NO. 09380152 SER MAN Y underneth the...
You will have to contact GM for the code. There are no generic codes and each is unique to prevent use after theft, otherwise a code would be rendered useless in preventing use after theft. Unless the person or place has the code for the radio, you will need to contact GM.
Jul 07, 2011 | Car Audio & Video
I want to connect a stock delco radio from a 1997 buick lasaber into a 1997 Grand jeep Cherake the radio has cd/tape/am/fm/ need to know what coler wire goes where. serial man.no. stock no. is 16249434 ...
May 12, 2011 | Car Audio & Video
We have a radio in our RV and no manual. It is a Jensen VR185. Can you help us to set the time on this radio.
Press T/F (7) momentarily to change the information displayed by the unit from mode-specific
information (radio frequency, CD track number, etc.) to the clock display. Press T/F again to
return to the default display.
The T/F button is also used to set the clock to the correct time. Press and hold T/F to enter into
clock set mode. When the time flashes on the display, rotate the volume control to adjust the
hours. When finished, press T/F again and rotate the volume control to adjust the minutes.
When no adjustments have been made for five seconds, the unit will resume normal operation.
You may also download the manual here:
http://www.jensenheavyduty.com/downloads/dl/file/id/96/vr185_owners_manual.pdf
Mar 07, 2011 | Jensen Car Audio & Video
Wiring diagram for delco radio model 16194445
i have ac delco radio for my gmc serria and the clock comes on but nothing els
Sep 12, 2010 | Car Audio & Video
GM Radio Locked but will not display codes by pressing 1&4 or 2&3
Does your GM car or truck Radio display LOC and does not turn on? Chevrolet, Buick, Pontiac, GMC, Cadillac, Oldsmobile vehicles used a theft system to lock the radio when power is lost. This system was used from the ealy 1990's to the early 2000's.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
Instructions:
  1. If your radio displays the word LOC, you can retrieve a set of factory numbers in the radio that enable you to get a backup unlock code. If the radio says INOP, you will have to leave the key in the "ON" position, or let the car run for at least 1 hour before you attempt any unlock procedure. INOP means a secondary theft lock due to too many false attempts to unlock the radio.
  2. Looking at the face of your GM Delco radio, hold down the preset buttons 1 & 4 OR 2 & 3 (Depending on year and model) for approximately 10 seconds or until a set of 2 or 3 numbers comes up on the display. Write the numbers down.
  3. Next press the AM / FM button. A new set of 3 numbers will now show. Write these numbers down. You will then need to call a 1-800 phone number with these numbers to get the unlock code. There are many sites on the internet that can get it for you- for a small fee. Or, try calling your local GM Dealer and ask for them to do it. Many times they will do it for free. It only takes a minute.
  4. Once you have the unlock code, enter it by pressing the MIN button until the display shows the last 2 digits of the unlock code, then press the HR button until the first 2 numbers or shown. Then press the AM / FM button to enter the code. The radio will now display SEC, and normal function is restored.
Also, its possible that you need RESET your GM Radio; this is the procedure: While performing maintenance on your car, you may disconnect the radio from the battery in your GM vehicle. GM cars contain Delco radios that are protected by Theftlock, which locks the radio after it has been disconnected from a power source. Iit can only be reset and unlocked with a car-specific security code. Identifying the security code for your GM vehicle is the only way to reset the car radio and disable the Theftlock protection device. jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
Instructions:
  1. Turn on your car. Your Delco radio will show "LOC" in the LED display.
  2. Press and hold down both the second and third preset buttons. Hold these buttons down for at least six seconds.
  3. Write down the two- or three-digit code that appears in the LED display.
  4. Press the AM/FM button on the radio.
  5. Write down the next two- or three-digit code that appears in the LED display. You should be left with either a four- or six-digit number. Turn off your car.
  6. Call the Delco radio automated customer support line at 1-800-537-5140.
  7. Press "1" and then press the pound sign. The automated voice should respond "Invalid code, try again."
  8. Enter the number 139010 into your phone and then press the "*" sign.
  9. Enter the four- or six-digit number you wrote down from Steps 3 and 5, and then press the "*" button.
  10. Write down the four-digit code given by the automated voice.
  11. Turn on your car. Enter the Delco unlock code using the procedure outlined by your GM owner's manual. Normally, the unlock code is entered with the "HR" and "MN" buttons on your radio.
  12. Press the AM/FM button. If you have entered the code correctly, your LED display will read "SEC" and the radio will be unlocked.
Hope this help.
Mar 18, 2010 | Car Audio & Video
How do I set the clock and preset radio stations on a Pioneer fhp800bt Premier?
Usually, you need to have key on and radio off. press and hold function button till u see settings menu. Set radio stations by press and hold preset # while on station till beep or display blinks.
May 07, 2009 | Car Audio & Video
May 06, 2009 | Car Audio & Video
My dvd will not eject?
What model number is this.
A Kenwood will sometimes eject the disc when you press the reset button.
The reset button is a very small round hole that you need a pen tip or paperclip, something small to press it with. It is on the display.
If you can not find the reset switch you can always unplug the harness in the back of the radio for a minute and then plug it back in, but if you have a security code protected radio you will need to enter the code to use the radio again or use the remote to clear the code. If you need that done and have a remote, let me know and I will post the procedure for that, but i must have the model number of the radio. Be aware that by resetting the unit, you will need to set the clock and preset radio stations after.
If resetting does not work, you will need to take it to an authorized Kenwood service center for repair. There is no other end user method for ejecting the disc.
let me know if you need more help with this, but please remember to list the model number. Thanks
Jun 20, 2008 | Kenwood Car Audio & Video
Delco factory radio display is saying loc
There is a code. This usually happens when the battery dies, when you disconnect the radio or disconnect the battery. Unfortunately only the dealer or delco repair shop can unlock it.
have a great day!
May 28, 2008 | Car Audio & Video
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
