Question about Texas Instruments TI 880 Matrix Printer
TEXAS INSTRUMENTS BA-11
HAD BATTERIES REPLACED AND NOW THE CALCULATOR WILL NOT DO CALCULATIONS REGARDING REAL ESTATE FINANCIAL PROBLEMS. IT DOES HOWEVER CALCULATE SIMPLE MATH. WHAT CODE OR BUTTONS DO I NEED TO USE TO GET INTO THE REAL ESTATE FINANCIAL CALCULATION MODE.
Press "2nd" then "fix" (Mode). This will get you back into the Fin mode.
Jerrycain!@gmail.com
Posted on Apr 15, 2009
Where to buy replacement batteries
You should be able to buy a CR2032 battery at just about any electronics or office-supply store.
Aug 09, 2011 | Texas Instruments BA Real Estate...
I have a BA Real Estate Analyst (lost manual) and I do not know how to reset decimal place to two places to the right of the decimal.
Press 2nd [FORMAT] 2 ENTER. FORMAT is the 2nd function of the decimal point key, ENTER is the second key on the top row of the keyboard.
May 01, 2011 | Texas Instruments BA Real Estate...
I have two BA real estate calculator with the same problem. Each one is slightly off in the calculation. Example. $100,000 loan 6% rate 30 year term should have a 599.99 payment and when I input this...
$596.57 is what I get with payments occurring at the beginning of the month. Set it to handle payments at the end of the month. My calculator gives $599.55 for this case.
I'm not sure about the BA RE, but on the BA-II Plus you change the Begin/End setting by pressing 2nd [BGN] and 2nd [SET].
Mar 09, 2011 | Texas Instruments BA Real Estate...
Texas Instruments BA-ll Executive Business analyst. How do I put it back into financial mode?
Turn calculator ON. Press the MODE once or twice. As you do so look at the screen. When Mode is in Financial, the screens displays a small Fin.
Feb 11, 2011 | Texas Instruments BA-II Plus Calculator
Having a problem with turning on a new BAII plus financial calculator. i presed the on/off butun but its not working at all.what can i do?
The first step is to replace the battery and see if that fixes the problem. If it doesn't, please reply to this post and we can go on from there.
Sep 21, 2010 | Texas Instruments BA II PLUS Financial...
Change battery
For up to 1000 hours of operation, use Panasonic
LR-44, Ray-O-Vac RW-82, Union Carbide (Eveready) A-76, or equivalent battery types.
For up to 2500 hours of operation, use Mallory 10L14 or D357, Union Carbide (Eveready) 357, Panasonic WL-14, Toshiba G-13, Ray-O-Vac RW-42, or equivalent battery types.
1. Remove slide cover. Place calculator face down.
2. Using a small Phillips screwdriver, remove screws from back case.
3. Pull off back case.
4. Remove discharged batteries.
Caution: Avoid contact with other calculator
components while changing batteries.
5. Install new batteries positive side up, as shown on diagram inside case.
6. Replace back case, and then replace screws.
7. Press ' ! !.
Battery Information
The BA Real Estate calculator cannot hold data in
memory when the batteries are removed or become discharged.
Aug 18, 2010 | Texas Instruments BA Real Estate...
Inst manual
The length of a rectangle is twice its width w. a second rectangle, which is 8 cm longer and 3 cm narrower than the first rectangle, has perimeter 154 cm. Make a sketch of the rectangles expressing all dimensions of w. Then find the dimensions of each rectangle.
Oct 03, 2008 | Texas Instruments BA Real Estate...
Help the the ba 2 plus
You might have to contact Texas Instruments for a paper copy, but for now, I found this for ya. It is a rather large "pdf" though.
http://education.ti.com/downloads/guidebooks/financial/baiiplus/BAIIPLUSGuidebook_EN.pdf
Sep 05, 2008 | Texas Instruments BA-II Plus Calculator
149 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
