To find a source for replacement parts
Hello , I repair as # of mackie mixers and I am trying to find a source for (new) replacement parts(I do alot of work on vlz boards) and having a tough time doing so ?
my email : pc_bass@hotmail.com
  • 4,234 Answers
Contact Mackie directly at: www.mackie.com/
Dan
Posted on Aug 29, 2008
  • ABRsvcs Aug 29, 2008
    pc_bass,
    I don't quite understand the TFT rating. I repair Mackie boards as well and have found that Mackie is very helpful. A quick call to them can get you part numbers, pricing and availability. Unless there is some other issue for which I can assist further, can you please rate the provided info as helpful. Thank you.
    Dan
Hi my mackie thumps 100 watt aren't delivering a decent volume ,,I,m using mackie mixer please help
Is this a new problem? In other words, was it working correctly at some point?
You ned to isolate the problem. Plug a different source into the speakers and plug the mixer into a different amp/speaker. See which part isn't working correctly.. Either way, it's likely you need to take the part that's not working to the shop. You can contact Mackie to find the nearest service center. Service Locator Mackie
Nov 28, 2016 | Mackie Music
I have a Mackie 406M Powered Mixer. can't get sound out of it anymore. all the input level set lights stays on. any suggestions
That sounds like the amp board died. Mackie parts can be hard to source, and Mackie is really slow to ship, so I suggest taking it to a Mackie authorized service center. Here's a link-
Contact Support Mackie
May 18, 2016 | Mackie Music
Need a power transformer for a Mackie 1202-VLZ mixer
The transformer itself will have the codes you need to replace it either printed on it or on a label stuck to it. Mouser should have what you need.
Sep 16, 2014 | Music
The Mackie SRM150 Monitor
The problem could be a defective linear regulator component on the preamp/mixer board. Checkout the link for repair instructions. https://lieven.kks36.be/2017/12/14/mackie-srm150-repair
Jul 30, 2017 | Mackie SRM150 Compact Active PA Spkr ea
Hello, I recently bought a Mackie Profx8 mixer here in the UK and I cannot locate the fuse. The AC socket does not have the fuse tray underneath (unlike my Mackie speakers) and there is no indication...
Essentially if the fuse goes, the unit is rendered useless until it is repaired. Replacing the fuse without repairing would likely cause further damage in the unit. Fuses blow for a reason that is usually a failure in the unit. Failures don't fix themselves. The ability to replace the fuse is therefore a moot point. To keep your unit safe ALWAYS power all interconnected equipment from the SAME power receptacle or conditioning module. This means running extension cords to powered speakers if that is what you have to get power the mixer. Powering mixers at one end of a room from a receptacle and the amps or speakers from a recpetacle on a stage at the other end will likely damage you equipment when a ground fault occurs or ground bounce in the building wiring ruptures the sensitive input/output circuits of your equipment.
Jun 18, 2011 | Mackie ProFX8 / TH-15A PA Package
I need a new mains transformer for my Mackie 1402vlz3 mixer but can't locate on in the UK. NB 1402vlz, not 1202 vlz as per the product below. (Can't get 1402 on the categories). Where can I source one, or...
Your best bet is to contact Mackie directly for a distributor in the UK.
The contact information is listed below.
Dan
LOUD Technologies Europe PLC GENERAL CONTACT Unit 1 Century Point, Halifax Road. Cressex Business Park
High Wycombe, BUCKS, HP12 3SL, UK
Phone: + 44 (0) 1494 557 398
SALES Email: eusales@loudtechinc.com
SERVICE Email: euservice@loudtechinc.com
Aug 20, 2010 | Mackie 1202vlz3 12 Channel Mixer
Hello. I'm missing the bottm plate of the mackie 1604 vlz pro. I bought it on ebay and the bottom plate that covers the internal parts did not come with it. Is there anything I can do about this? Do they...
Mackie does sell parts. If you cannot afford or get the part, procure some metal and make your own. Mackie is headquartered in Woodinville WA I believe.
(800) 898-3211 Monday-Friday, 8am-4pm Pacific Standard Time
Aug 06, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
I want to hook up a an interface to a mackie mixer. What is the common denoinator to hook up, let's say a digi 002 and a mackie mixer so i can have a mac computer with pro tools operational with also the...
you can just piggyback the mixers - take the outputs from the mackie mixer (assuming it is NOT a powered mixer) ... those should be line level outputs - send them into a line level input on the digi 002 and then set that channel on the digi 002 and once set, just leave it, and control the mackie channels individually ... should work fine ...
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.rexark.com
Oct 14, 2009 | Digi 002 Rack FireWire-based Pro Tools LE...
308 people viewed this question
 Grubhead
Grubhead
