Question about Plantronics Explorer 220 Bluetooth Headset Wireless Headset
Trouble light I have a plantronic Discoveryy 655 FCC id: al8-d655 After charging several hours when I turn it on the blue light notifies me its on but then shortly after I receive 3 short red lights and I don't know what that means. Can you help? thanks ruby
  • 16 Answers
3 red rotating lights mean that their is an error with the connecting device is not connecting to the network of your phone. Most likely your headset is too far from your phone, and this is causing an abrupt interruption of the connection, or it is possible your device no longer can connect via blue tooth and is not functional.
My suggestion is to go to the plantronic website and do a search online for your user manual, it will pretty much tell you the same, register your device on the website and then call them for repairs and mailing instructions, if you desire to keep this headset and not purchase another.
ManOwar
Posted on Aug 07, 2008
Read the manual online
thanks!
Posted on Jul 15, 2008
Plantronics audio 995H wireless headset not charging when plugged into computer. It does not show a red light for charging. When turned on it stays blue for several seconds then flickers red for 2 or
38cafd7a-6060-4717-bc4f-b4db91cc266a.jpgI recently fixed my 955 headphones... it's probably not going to be attempted by most folks, but it saved a great set of headphones from being tossed and replaced.
Basically you need to remove the right side padding and take out the 3 screws. This gets you access to the battery. The battery is a standard 3.6V lithium battery. Pretty much the same that is in most cell phones and many small toys. You can simply replace the battery with something like:
http://dx.com/s/3.7v+li
Or... here's what I did... add a lithium USB charger to the battery.
http://dx.com/s/li+arduino
Now, if the battery dies I can plug it into USB and the phone will work while it charges.
Nov 12, 2013 | Plantronics .Audio 995 Digital Wireless...
Can't hear audio plantronics audio 655
if the light stilll shines but you can't here anything then it's broken
just like mine :(
Dec 19, 2012 | Plantronics .Audio 655 Stereo Headset
Are any parts avialable for my PLANTRONICS 330 IC:457A-E3XXCL D7 FCC:ID AL8-E3XX The mic filter is gone the over the ear is broken and the ear piece is gone.
The only accessories available for the Explorer 330 are the power adapters, not the things you mentioned. If you need a new bluetooth, check out the latest headsets at this link:
Plantronics Bluetooth Headsets
Good luck from Headsets Direct!
Sep 14, 2011 | Plantronics Explorer 330 Headset
Charger shows blue light, however after charging for several hours, headset will not turn on. This is a re-furbish headset from eBay however cannot tell if the charger is working or a bad headset, any...
Since you have nothing to compare it to, it's going to be difficult to pin down the culprit. Being a refurbished headset you want to make sure the ac adapter is the right one (the light on Plantronics chargers is green, not blue). You can call them at 800-544-4660 x5 x5538 to get the specs on the charger.
Jun 26, 2011 | Plantronics Voyager PRO Bluetooth Headset
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
Not charging and no light saying it is
There is a possibility that the battery could not be taking the charge, but typically the light is red while charging and green when done. Sometimes if the is fully drained it can take up to 15 or 20 minutes before the red charging light comes on. Try leaving it charging for 24 hours.
May 05, 2010 | LG HBM210 Bluetooth Headset Wine Red Color
Need guide/manual for Plantronics 222 Blue Tooth
first question,i have anplantronics explorer 242 when i plug it iun to charge it the light ired then after a few min. it turns blue,how do i know when its fully charged? will the lights go off?
Dec 16, 2008 | Plantronics - Bluetooth Headset Plus Base...
Bluetooth headset
USING THE HEADSET
US USING THE HEADSET
1. Headset
2. Control Button
3. Light Indicator
4. Microphone
5. Earloop
6. Speaker
7. Charging Jack
A. Charging
Charge for at least 20 minutes before
first use. Complete charging in 2 hours.
Headset will not function when charging.
B. On/Off, Volume↑↓
Press the Control Button for 2 seconds
to power on. Press the Control Button
for 3 seconds to power off.
C. Pairing
Begin with Headset turned off.
Press button for 6 seconds. Release
button when Light Indicator flashes
blue/red. Headset is ready to pair with
Bluetooth device.
D. Pairing
Use your device’s menu to begin
pairing mode and select “320
Plantronics” on the display. When
asked for passkey, enter “0000.”
Jul 13, 2008 | Plantronics Explorer 320 Wireless Headset
I own a Plantonics Discovery 655 FCC ID: AL8-D665 I want to install it on to my razr and i dont know how.
I have a Discovery 665 and I want to get it working with my MOTOROLA RAZOR
can you help me
Jun 29, 2008 | Plantronics Discovery 640 Wireless Headset
Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
167 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
