Question about 2wire 1800HG Router (RG1800HG00)
Pirates I think someone is using my router, but I dont know how to disable it, I only use my ethernet connection(hardwire).
  • 363 Answers
I'm guessing this is a wireless router in which case you need to look at the router configuration and enable some security features such as changing the access rights and your admin password.
Usually typing the ethernet router IP address on the in your Internet Explorer address box will bring up the configuration.
Having an open router path to the internet for other wireless users is fine by the way. And unlikely to comprimise your security. You simply become a free mini ISP.
But if you feel it is slowing your own usage then block it.
Posted on Jul 14, 2008
My wireless connections will not work! last night both lap tops and my daughters zip it were unable to establish a wireless connection. It happened once before about a month ago and were able to...
OK, to clarify.
Ethernet = modem?
Wireless box = router?
Do you have hardwire connection to router?
Check the wireless settings in router with hardwire connection.
Most routers use random channel search for wireless.
I usually set this for to use one channel only.
Stops random interference and connections.
FYI: Most routers are on 2.4ghz - same as cordless phones and some hand radios - the frequencies over lap sometimes - even though they aren't supposed to.
Microwaves will also disrupt signals.
Apr 04, 2010 | Computers & Internet
Can I hook up a wireless router with only laptops
you need a pc or laptop using a hardwired connection prior to using the router, hence the name router, it routes the hardwired conenction and broadcasts it wirelessly.
Dec 29, 2009 | Belkin (F5D7230-4) Router (587009)
Do i have to hardwire my Sony HDTV to my router to get it on my network, there is no mention of hardwiring in the manual
hi Steve
2 things to check. Is there an ethernet socket on the back of the TV? is there any mention of connecting by wireless? Chances are that if it connects by wireless there will be instructions how to do it as it won't be simple.
I think you'll find an ethernet socket on the back and then it will probably just work by plugging it in.
Nov 23, 2009 | Computers & Internet
The ethernet controller on my Dell Latitude C540/C640 Notebook has not worked in a while. I am able to get wireless internet access, but no luck when I try to connect to my router via a direct line. I...
If you are using Windows XP, go to Control Panel > Network Connections. Right click on Local Area Connection and then click Enable. (This is only applicable if the ethernet port is disabled).
Also, you may go to Device Manager (Right Click My Computer > Manage > Device Manager) and then check if the ethernet is disabled or has a question or exclamation mark.
If both dont work, your ethernet controller is broken.
Jun 07, 2009 | Dell Latitude C640 Notebook
I cant connect internet through hardwire(ethernet) but i can connect to internet by wireless... and it keeps on telling me Unidentified network.
Not really ...
1 thing that should not be in common between your wireless and modem is GATEWAY...
Your default modem gateway will be
change your router gateway to or
to do this ...
1. click on start menu , type cmd , enter
2. COMMAND PROMPT dialogue box opens .
3. type . IPCONFIG
3. note your Default gateway.
4. open internet explorer
5. type your default gateway in browser address
6. it will prompt you to give user ID and password .
7 Your USER ID and password is ADMIN .
8. your router setup page opens .
9 change your local IP address to .
10. Check mark on BRIDGING MODE .
11. Disable and enable your ethernet .
12 . now try connecting to INTERNET .
It should work . .
May 22, 2009 | D-Link Vonage-enabled Wireless Router...
Can't browse my bank web site using Trendnet TEW-432BRP router.
When you are hardwired to the router you should disable the wireless internet access and enable the local area network.You should do the opposite when you are trying to connect to your router wireless.
Feb 28, 2009 | Trendware TEW-432BRP Wireless Router...
Connection to iMac not working
the easiest way is hard wire a windows laptop and use the CD that came with the router.
Oct 13, 2008 | Microsoft Broadband Networking MN-500...
Wiring up 2700hg-b
Just run an ethernet cable from the back of the PS3 to the back of the router
Jan 01, 2008 | 2wire 2700HG-B Router (2700HGB)
Computer found router before why doesn't it now?
Download Network Magic (no need to buy, free one will work) once installed look at your network map, you should see your router click on it and note the IP address. Type this address into your browser.
Dec 09, 2007 | Linksys Wireless-G WGA54G 802.11g/b...
Networking with Motorola SBG 900 Gateway
No, you don't need a router... that gateway supports up to 253 devices on your private network segment. That being said, you only have one ethernet port, so if your desktops have LAN cards rather than wireless, you'll need a hub to split off enough ports. If you add a router, it'll give you a whole new level of complexity. A gateway is a router/modem combo. It converts the Cable Internet signal from your ISP to ethernet and isolates all of the computers behind it into your own private network. A hub is basically an ethernet splitter... it won't isolate a new network segment, it'll just add more ports. Get a hub, they are cheaper and won't add a new level of complexity.
Sep 09, 2007 | Cisco (1841) Router (cisco1841)
2wire 1800HG Router (RG1800HG00) Logo
44 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
