Signal cable ive tried a different monitor n it stil wont boot up
  • 1 more comment
  • mikeybabby Jul 14, 2008
    i wud use the restore disc only i cant get the damn thing 2 switch on.the monitor just wont power up n the disc drives wont work neither n the harddrive light stays on a constant yellow???
  • Martin B
    Martin B May 11, 2010
    Would this be the same light that goes yellow when the PC is on standby?
  • Martin B
    Does it beep?
    Sergeant:
    Champion:
  • 327 Answers
Only one other thing can think of is that the video card went did you try restore disk i would try this first if does not work i would get new video card sounds like vidoe card went to me but never know could just be the drivers are corrupt
Posted on Jul 14, 2008
  • victoria bennett
    victoria bennett Jul 14, 2008
    only other thing is i had that problem one time and it was the mother board or the harddrive went only way to know for sure is to try a different hard drive if that does not fix it then it is the mother board 50% chance it is the hard drive
Gateway sx2110g no signal
if it has a graphic card try pulling it out and putting it back in test again. if card doesn't time for replacement
Oct 24, 2015 | Gateway Computers & Internet
Hi my pc boots and fans are spinning like normal
You need to check the monitor also. The LED monitors do not last as long as the old CRT's. Also try a different cable. The LED monitors I have had usually stop working without warning. They will turn on but cannot display a picture.
Oct 19, 2014 | Computers & Internet
Monitor will not boot up is reading no input signal
So either the computer isn't generating a video signal, the cable isn't carrying the signal to the monitor, or else the monitor isn't capable of receiving a video signal.To test this, first try a video cable that you know is good, in case your cable is bad, If it works with the other cable, the problem was your original video cable. If it still doesn't work, put your original cable back, and hook another computer up to the monitor. If the monitor makes the same message, the problem is with the monitor. If the other computer works when connected to this monitor, your problem was that the original computer isn't booting (which could be due to several reasons I will list below), or the video adapter is broken.Possible reasons for the computer not booting: bad power supply, bad power button, bad hard drive, bad memory, bad motherboard component. If you determine that it isn't booting, unplug everything except the keyboard mouse monitor and power cord, to see if that makes a difference. If it boots after that, something you unplugged was causing the problem, plug them each back in one by one, rebooting in between, and when it stops booting properly, the last thing you plugged in is causing the problem.
Mar 02, 2012 | Acer Computers & Internet
My dell 470 wont boot up every thing seems to be working but when i turn on i get a blank screen and no signal displayed Edward
This means that your monitor is not receiving a signal from your graphics card.
Here are the things that you can try:
-Disconnect and reconnect your monitor from your computer.
-Try using a different cable to connect your monitor to your computer.
-Try connecting your monitor to another computer, if it works there it means that there's a problem with your graphics card and it may require a replacement. If your monitor is still saying no signal even if it has been connected to another computer that works fine then the problem is with the monitor.
Apr 22, 2011 | Dell Precision Workstation 470 (204816690)...
No signal
Check cable connections. Check using a different monitor.
The only other possibility is that you're trying to drive it with a signal that is beyond the capability of the monitor. But the computer boot-up (BIOS) screen won't exceed the monitor's capability.
May 15, 2010 | Sharp LL 172A-B 17" LCD Monitor
My whole screen has a blueish green tint
  • Make sure the plugs are hard into the sockets, one loose pin can cause strange colour problems.
  • A faulty signal cable between PC and monitor can also cause colour problems, try a different cable if possible
  • Try it on a different computer to find out whether the computer or the monitor is the problem. If it's the monitor and none of the above works, it will need service or replacement. If it's the computer, your video card is likely to be the problem.
Apr 09, 2010 | Samsung Syncmaster 940BW LCD Monitor
EMachines T3656 Desktop wont boot and no signal to monitor
Try to check the monitor cable if it is properly connected to your motherboard. If you will have a video card you need to attach your monitor cable to the video card.
Jan 28, 2010 | Computers & Internet
Monitor - no signal
it doesn't seem to be a monitor problem but a computer problem, is this a desktop or a laptop ? see if you can re-sit the display adapters.
Jun 03, 2009 | Tiny Computers B1996 19" CRT Monitor
Samsung 17" Flat Screen PC Monitor
Problem from motherboard side.
- No display from motherbaord circuit (Display IC)
- Try to figure out with PCI Display card or
- Try to connect different monitor or this monitor to different computer to cross check your dignosis
Jun 02, 2008 | Samsung Computers & Internet
No signal on first boot
I think is a power supply problem,,
Mar 10, 2008 | Nokia 445 Pro 21" CRT Monitor
Computers & Internet Logo
David Payne
David Payne
