Question about Technics SL-1200MK2 Turntable
Power problem I was using my 1200 for about 4 hrs like i do in any event a suddenly the leds on the on off went off, but i turned it back on and it gets power but when i push the start button the leds blink and lower the power and the platter never spins, what could be wrong, thx for any help the power also goes down with the pop up light bulb is on
  • DJLG Jul 18, 2008
    thanks I changed the q2 and the q3 and now they are back to work for 10 more years hehehe
  • 515 Answers
Sounds like a short. A resistor probably burned out, and is causing unregulated power to hit your system. If you look at your main PC Board, underneath the turntable platter (disconnect your turntable), and remove the board. You'll be able to look at the board, and see if there are any burn sections on the board. If so, than the components around that area will need to be replaced. Generally R213 gets burnt, and Q2, Q3 get burnt, causing this sort of issue. This is not something I would recommend fixing yourself, and I would suggest seeking professional assistance.
You might also want to take a look at your fuses, which are located on the left side on a smaller PC board. If you don't see any fuses, then your unit does not have any fuses (common) installed.
Hope this helps.
- OPTiC
Digital Analog Therapy
www.DJPROLAB.com
Posted on Jul 14, 2008
How to fix my lcd tv and magic remote?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 29, 2015 | LG 47LW6500 47 3D LCD TV
TV comes on but flashes on and off like a strobe light why?
It must have any defect. My guess is a bad soldering in the power supply. When it gets warm ir will lose he connection. But there could be lots of other causes.
Jan 18, 2015 | Coby TF-TV3217 32 in. LCD TV
Sony TV WEGA wont turn-on. stand by LED
line o/p transformer &transistors are gone .. any service person can replace them
Apr 22, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Timers & recorded events erased
Ocassionally these receivers have been known to do this. It is not an issue that normally repeats itself however it is very frustrating. The upside is it ussuaaly will result in 150 hrs of record time. If you did not receive the150 hrs delete all timers and recording and reboot the system. You should have the 150 hrs once it comes back online. Thanks for using Fix Ya.
Aug 02, 2009 | DISH Network DVR-625 DTV Receiver /...
My 6 to 7 yr old television suddenly went dead
There is a board that manages the power going into your tv I would check around with local mom and pop tv reapir shops. The board is not expensive its the labor I am not sure where you live but I am sure there are local techs that work on flat panel tv's. They are pretty affordable these days. Most flat panel tv's are rated for 60,000 hrs as there life span. Hope that helps
Mar 25, 2009 | Panasonic Televison & Video
Canon S2 IS won't turn on with rechargeable batteries??
I would let them charge til you get an indication that they are done. TV remotes require very little power to operate, while digital cameras need a lot, so that's why the batteries would work in the remotes though not fully charged.
Jun 16, 2007 | Canon PowerShot S2 IS Digital Camera
Technics SL-1200MK2 Turntable Logo
181 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
