Sleep mode turn off simpletech 500gb pinifarina
I have problem, I can't turn off the sleep mode I don't know how to turn it off. I need it so my pvr could record with timer.
  • Anonymous Apr 12, 2009
    This solution is not even close. This question refers to WD's my book sleep mode...NOT the computer.
    Scholar:
  • 51 Answers
Hi
Go to system Preferences and click on energy saver. Change the sleep setting to Never. This will stop the computer from sleeping. Also go into schedule and see it it is set to shut down or wake up at a given time.
Hope that helps.
Posted on Jul 14, 2008
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
How do I turn off the sleep mode?
Sleep mode is enabeled in the system bios, before the OpSys will use it.
Disable it in the bios, and it will no longer be available.
Hit 'delete' right when you first turn on your computer,
I don't know what you got, but explore that thing anyway and learn stuff until you find it.
Please rate this answer
Aug 02, 2011 | Computers & Internet
Dell monitor flashing green power button black screen.
Your computer is in sleep mode, a low power mode that conserves power by turning off the screen and hard drive.
Push the power button on the system and the computer will resume.
If you don't like this feature, you can turn off sleep mode in the power options in Control Panel
Jul 26, 2011 | Dell Dimension 2400 PC Desktop
I need a driver/SW for DELL D610 sleep mode, Pls. send me download version and installation instructions
Hi
Sleep mode don't need drivers,
It's pre-configurations are pre-installed in the Control Panel > Power Options
Go there, try to adjust and test the options for sleep mode ( when to sleep: close screen, press power button ,, ) and after how much time ..
Please,tell us your results
Good Luck
May 19, 2011 | Dell Latitude D610 Notebook
My machine is also set to sleep mode and cannot rcv. faxes!
Sleep mode does not affect the reception of faxe check receive settings instead
Aug 28, 2009 | Brother IntelliFAX 2800 Laser Fax
Simpletech pinifarina 500GB external drive - unable to access
A few things to check but assumes USB for other interfaces similar steps may be followed
1. ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer.
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply (Dont use any other unless you know it has both the same voltage and current rating eg. 12V 500mA anything rated below that would not work properly)
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select computer management.
Now select Disk Management and expand the window.
Your drive should be listed here (if not then you need to check your computer hardware has not got any issues before proceeding)
If your drive is listed and says healthy then right click on it an select Properties, click tools and then error checking, Check now, tick the two boxes and then start.
This will attempt to fix any errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed ut did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. when it is done restart your computer and you should be good to go.
Aug 16, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Monitor goes into Sleep Mode immediatly upon turning on computer
Ok. I think "sleep mode" means that your monitor might not have a tight connection. Tighten all connections. Also, push the power button on your tower. When you gegt back, go to screensaver- power settings- and from there you can adjust.
May 24, 2009 | Dell Dimension 3000 PC Desktop
Can't switch on monitor screen
You must go into the BIOS of you computer and turn off the sleep mode and also in windows. Disconnect the monitor and power it on without hooking it up to the computer. If the monitor turn on and is working , then hook it up to the computer and try with with the sleep controls off to see if it works correctly.If this works you must check the owners manuals of the motherboard and monitor for the correct operation of the sleep mode functions.Then reinstall the sleep mode operation and see if everything works correctly. If the monitor fails to work. Try the monitor on another computer and see if it will function. If all this fails to get the monitor working , then you will need to have the monitor tested in a service center to find the problem and have it repaired. You should also check your computer on another monitor just to maker sure you don not have a problem with the computer too. Hope this helps you with your problem.
May 12, 2009 | Mag Innovision LT776s 17" LCD Monitor
I have a LCD panel it is connect to to the LCD. I need to change a setting on the computer to make it stop going into sleep mode, however, now that it's in sleep mode, how do I get out of that so I can make the change?
Jan 09, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Need help monitor stays in sleep mode... :(
power down, everything, leave it off for a few minutes, turn it back on.. when it gets booted, disable sleep mode option in advanced power features.
Mar 19, 2008 | Computers & Internet
Computers & Internet Logo
1,081 people viewed this question
David Payne
David Payne
