Question about HP Pavilion dv6000z Notebook
Data recovery I have a 40GB external hard disc which i connect via usb port to my toshiba laptop.The external hard disc developed a problem,it was not mounting, but with the use of getdata back software i was able to retrieve data from it and then copy the data to my laptop,after which i formatted the external hard disc and started saving entirely new data in it. Unfortunately due to a fire outbreak, my laptop was burnt to a useless state.This tragedy caused me to buy a new HP laptop of 250GB hard disk ,2G RAM and 1.87GHz processor speed.My external hard disk however was not lost in the fire.The external hard disk also works well with my new laptop.My problem now is ';how possible is it to retrieve the information that was initially in the external hard disk before i formatted and saved new information on it?';Is there any software or technique that can be used?I am referring to the information that was on the external hard disk when it had a problem, that is the info i was able to save to my laptop using get data back software .I tried using getdata back software again but it only displays the info that is on the hard disc after formatting.I will be overjoyed if a solution to this is been posted to me ,considering the importance of this data.I can be reached via my email at binbuba@yahoo.com.Thank u. Still need a solution for this problem
  • 51 Answers
I will suggest u to try with ontrack data recovery software which is really helpful.
Posted on Jul 14, 2008
Hello, What cable or adaptor do I need to transfer all data from the hard disk of my Toshiba Satellite Pro A200 to my new laptop via USB port? Thanks.
You won't be able to transfer hard drive data by plugging one computer into another via USB. In order to transfer data, you will need to remove the hard drive from the Toshiba Satellite Pro, use an external hard drive enclosure, and attach that to your new computer with any USB cable.
The hard drive can be taken out by removing screws on the bottom of your laptop. The drive can be found in the bottom left of this picture: http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-02.jpg
Here is an example of the exclosure you would need: http://www.newegg.com/Product/Product.aspx?Item=N82E16817816013
Mar 14, 2011 | Computers & Internet
I cannot connect my external hard drive through the sata port
Install the external hard drive into an USB hard drive adapter case. You can then connect this into the Toshiba's USB port. The Toshiba will see this as an external storage device.
Jan 08, 2011 | Toshiba Satellite Pro M300-S1002X Notebook
Hi! i have an external hard disc Toshiba PX1396E-3T01. i've connected the divice to my pc but the red light doesn't turn blue but instead keeps on blinking blue. what's wrong?
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 23, 2010 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
External hard drive is not detected
Check Following Instructions:
1. Check your USB cable properly connected to the computer.
2. Go to My computer - right click on property - Hardware - Devices Manager - in below - USB Mass storage device - right click on this - and Uninstall - then again right click - click on Scan - it should be reload your USB drivers
your External Hard Drive will be detected
Apr 25, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
New computer won't recognize my Firelite, works on old computer
You need drivers for USB, if you remember when you bought smartdisk you got the installation disc, that you now need for a new computer.
Oct 31, 2009 | SmartDisk FireLite - 80GB - 5400rpm - USB...
Sony Vaio laptop could not access 1TB external hard drive
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program to recover your files.
http://www.asoftech.com/adr/
Oct 20, 2009 | Western Digital Computers & Internet
Usb 2.0 error
did you connect directly to your laptop or you connected via external USB Hub?? Your notebook model should support USB 2.0 ...so it should not face the problem you post..unless you're not connecting it directly.
takecare.
May 05, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion dv6000z Notebook Logo
73 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
