I need the software to connect my scanner i havent got the disc to install it
    Genius:
  • 1,011 Answers
Dear,
if u dont got the disc to install it then check that software in the manufactor's website. that will help u alot.
Posted on Jul 14, 2008
I have a Visioneer 4400 usb scanner and the disc for it still, but how do I get it to work with my Dell computer which has windows xp?
Make sure you turn off all antivirus / firewall program off that might be blocking the driver to load/ install. once the scanner is detected, it will prompt you to provide the driver. You may then install other visioneer scanner softwares that are bundles with your system to use with the scanner. Make sure you are installing the right driver for your operating System, in your case XP 32bit or 64 bit
May 05, 2010 | Dell Dimension 2400 PC Desktop
Did not get HP solution center software with computer
Well HP solution center is a software, use by HP Imaging and printing devices like HP printers, scanners and its All in One devices. it comes with a CD and you have to install in your computer. This application is used by those HP products, and is not inbuilt with the HP computer.
If you have any of those HP products, install software using the software disc. If you do not have the disc, goto HP.com and search for the products applications. Download the software and install it in your computer
Dec 18, 2009 | HP Computers & Internet
How do I connect the scanner to the computer. I have plugged in to a USB port. and the scanner is ready to use. But nothing shows on the screen. The scanner is used to send negatives to the computer.
did you install the software before you plugged the scanner into the computer? In most cases you will need to install the software onto the computer and then once it is installed the software will inform you to attach the scanner via the usb port.
Nov 03, 2009 | Computers & Internet
Disc burner or software not found
U must be using vista. So uninstalling the scanner or try system restore to time before u installed the scanner(hopefully that is vista compliant) and see if u can burn ur discs, if you can, then there is a resource conflict after installing the scanner, which can be chaged on the drivers--properties--resorce tab..........sodeep
Mar 28, 2009 | Dell Inspiron 530s Desktop Computer
The door on my pc is brole an I need to install my scanner,how do I get to use the scanner without putting in the disc.
You can download the software and drivers by going to the manufacturer's website and search your model.
Mar 13, 2009 | Computers & Internet
I tried to scan a picture an the scanner said i need to install or run software for feature. i put in the disc that came with the 1610 and it was turned down by the 9400
Hi!
lets do this step by step.
(1) Go to the control panel and use the ADD/REMOVE program and delete everything relating to your printer? scanner.
(2) Go to the printer icon in the control panel and make sure the printer / scanner is gone..No more printer.
(3) Go the C;/program files and delete all folders pertaining to the printer/Scanner.
(4) Reboot.
(5) Re-install the software. Remember if, when you did the first install, did you have to install the software **PRIOR** to connecting the printer? if so, please do it the way you did it initially!
That should solve it.
A last resort is to do a System restore to a date that it worked. Do you Defragment on a regular basis?
Mastersage.............................
Mar 04, 2009 | Computers & Internet
I have a CanoScan LiDE 70 scanner. It won't speak to my computer. It is plugged in to USB. Message appears saying try switching it on, but I can't find any switch. Icon appears in directory. Tried re...
first check whether u have installed all the usb drivers
then uninstall the scanner software and install it again without connecting your scanner.
there is no switch on it u will have to remove the power connection
restart ur computer when u finish installing the drivers
connect your scanner when u restart ur computer
Nov 13, 2008 | Computers & Internet
Diac to install printer scanner is scrathed badly when i opened it
Most software discs packaged with printers and scanners are outdated by the time you by them from the store.New driver downloads can be found that are up to date by visiting that products website and downloading new drivers.Vista is good at automatically finding drivers when you plug into a usb port. Sometimes no disc is needed.
Nov 07, 2008 | HP Computers & Internet
I have new Hp photosmart C4385 all in one scanner, printer, copies. The printer was initially onstalled. Working w/ wireless HP pavillion. It print & copies fine. Scan does not work. When I enter...
I had a similar problem recently... You have to actually install the scanner software. You probably only installed the print drivers, but not the scanner software. If you don't have the CD handy, go to www.hp.com/#Support. In step one select "Download drivers and software (and firmware)". In step 2 enter your model number (photosmart C4385) and then press "go". It will lead you to a page to select your operating system. Follow that link to download the entire CD (large file).
When you are installing the software, make sure to install the scanner software too.
John Lox
Apr 14, 2008 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
