Question about AT&T E5813B Trio Cordless Phone
Peripheral handset has poor reception
My base is working fine. the second handset is 100 ft away and rings but when answered has poor audible quality and breaks up.
the retailer said to place the peripheral handset on the base for 20 minutes which did not help much.
anything else you can suggest before i take it back to the retailer?
JD
2 Suggested Answers
SOURCE: handsets won't hold charge and have no base subscription
smash it into little pieces! That's what I'm doing with mine.
Posted on May 31, 2008
When answering mode is on I do not want to hear the ringing(4x) tones before going to answering.I've switched off the 'call screen' option. still I hear the ringing although not recording at least.
Just set the ringing volume to off.
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level. Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according to their individual settings
May 29, 2015 | Uniden DECT 6.0 Cordless Phone ID
Speaker not working on panasonic kx-tga410
*** This phone is a POS ***
I've had three of four handsets stop giving audible feedback when a button is pushed, and 2 of 4 speakerphone stopped working.
Apr 03, 2012 | Lands Phones
I just bought Model D-1660-2. I cannot make the second handset work. I have charged the battery for more than 20 hours. I set all the Handset setup modes as instructed in the manual. Works for the main...
Welcome to FixYa.
Reset the units/set up by doing the following:
  • Turn OFF all the HANDSETS.
  • Remove the batteries of the HANDSETS.
  • Unplug the power source of the BASE.
  • Unplug the phone line of the BASE.
  • Let it stay that way for 30 mins.
  • Insert the battery again of the HANDSETS, make sure it is charged properly.
  • Plug back the power source of the BASE.
  • Plug back the phone line to the BASE.
  • Register any handset that is unregistered (refer to manual).
Keep me posted.
Jas247
Sep 10, 2011 | Uniden Cordless Phone
I have a Uniden cordless phone #D2CT 6.0--I love the phone but the party on the other end of the line can barely hear me -how can I fix this or this a bad phone???
At 20 ft line of sight, you should have perfect reception with most any cordless phone.
The fuzzy signal can indicate:
1.
A weak signal between base and handset.
20 ft line of sight should have a good strong signal.
Your handset may be defective.
Or, your handset battery may be weak.
Your base unit may be defective.
2.
You may be experiencing RFI Interference.
Is the base unit next to any other electronic devices?
If it is next to a wireless router or some other wireless device, it may be overloaded by the nearby signal (even if on a different frequency)
I've got a 5 year old Panasonic 5.8 Ghz cordless phone connected to my VoIP box. I just tested it from about 25 ft away from the base unit in another room with a wall in between and my reception is perfect.
I did the same test with my Panasonic DECT 6.0 phones (1.9 GHz). The first handset is slightly fuzzy, but otherwise good signal. The 2nd handset was perfectly quiet with good strong signal. So, there is a difference between two identical handsets connected to the same base unit. This indicates to me that one handset is better tuned than the other. Nothing I can do about that but get a new 2nd extension cordless handset. Sometimes, it's just luck of the draw
Feb 15, 2011 | Uniden DECT 6.0 Cordless Phone ID
The handset lights up and the incoming number is shown but you dont hear it ringing
Many times there is a volume switch on the actual handset itself. Most commonly on the left side of vtech devices. there are three different volume levels. By pressing up on the button you should be able to turn the volume up until it has an audible tone confirming volume change. Handset should ring with incoming call when audible tone is heard by pressing up on volume button.
Oct 13, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
I have a Panasonic KX-TGA652 dual handset no answering machine. The problem I have is the 1st handset "the base set", doesn't seem to work properly, the 2nd handset works 100% fine. The problem is this,...
Id try the following in this order:
  1. Try swapping batteries with another set and see if the problem follows the battery
  2. Try re-registering the handset, they could of missed one at the factory. that is done by selecting menu->initial settings->register handset
If this doesn't work, then return for warranty/exchange. Mine seem to work great right out of the box.
the poodle guy!
Sep 29, 2010 | Panasonic Lands Phones
How do i put the ring tone back in the handset
    Does the Phone Power Up?
  1. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  2. Does the Battery Hold a Charge?
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
  4. Listen for a Dial Tone
  5. If the GE cordless phone powers on, and beeps when you press keys, but no dial tone is heard, one of three problems is the likely culprit. The phone's batteries may have an insufficient charge to fully power the phone, a condition that can be corrected by simply placing the phone back in the charger. If the batteries are charged, but no dial tone is heard, it is also possible that another telephone in your home or office is "off hook" or in use; verify that all telephones, fax machines and modems are securely on the hook. If there is still no dial tone, your telephone service may have been disconnected or require service by your local telephone company.
  6. Listen for Static
  7. On some GE cordless phone models, particularly older models, static may be heard if the radio signal between the handset and base unit experiences interference. Common sources of interference include unshielded electronics, appliances, and radio transmitters, as well as high-tension power lines. If your phone offers an option to change channels, try several different channels to see if the static is eliminated. If static continues to exist, or if static can be heard on wired phones sharing the same line, your telephone line may require service.
  8. Verify Your Handset is Registered
  9. Some models of GE cordless phones may display a message on the display screen that the handset needs to be registered. If this message appears, move the handset close to the base unit and press the "Prog/Mute" button near the bottom of the handset. Next, press the "Pager" button on the base unit (your handset may instruct you to perform this step). Finally, press the "Prog/Mute" button on the handset one more time to complete the registration process. Your GE cordless phone should now work correctly.The GE Cordless Phone brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems .
  10. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  11. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  12. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears
Nov 17, 2009 | Uniden Cordless Phone
NO CALLER ID 25881EE3-A
The GE Cordless Phonemag-glass_10x10.gif brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems.
    Before You Start
  1. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  2. Phone Setup
  3. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  4. The Basics
  5. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Nov 14, 2009 | Uniden Cordless Phone
Poor quality of voice and can't hear the
My DSL filter had gone "bad" I needed to replace the inline filter.
The suggestion was also to move the base unit away from the kitchen area because of all the technology that I had happening in one area.
Jun 11, 2009 | Uniden Cordless Phone
KX-TG9344
This is the info from the users manual, it seems a bit strange,
but claims if you set the number of rings before it answers, (for the answering system) to "2" it will stop the audible caller ID.
Here it is from the manual.
If you turn on the answering system
and set the number of rings “2” (page
38), the unit does not announce the
caller information. If “Toll saver” is
selected and there is a new message,
the unit does not announce the caller
information.
When you receive a call while on the
phone, the 2nd caller’s name is not
announced even if you subscribe to
both Caller ID and Call Waiting with
Caller ID services
Jan 02, 2009 | Panasonic KX-TG1033S Cordless Phone
AT&T E5813B Trio Cordless Phone Logo
19 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
