Question about Maytag Refrigerators
Wide by side fridge not cooling - Maytag Refrigerators
  • 2 more comments
  • blindsided54 Jul 14, 2008
    :)) no to all the above things........so with what ive been told about prices to fix, i'm of soon to go buy somethng other than a maytag........no ownder the guys have nothing to do--no on es' a repeat buyer:)) l ol thanks for your help!!
  • robert samples May 11, 2010
    is the compressor running is there any frost in the freezer back wall near the bottom do you hear the fan running in the freezer
    President:
  • 1,314 Answers
Ok sounds you have a bad defrost timer if you give me the model number ill tell you whaere it is its about a 25.00 part and you can do it your self get the model number off the serial plate in the fridge section
Posted on Jul 14, 2008
Fridge s/s cool on freezer but no air cooling fridge side
First, inspect the back wall of the freezer for frost build-up. Defrost failures are a common cause for incorrect fridge temps, and the frost will block air-flow even if your damper is wide open. if there is no frost, verify that the evaporator fan in the freezer is spinning, THEN check the damper door to see if it is open during cooling. Call a tech, guessing will likely lead to a broken machine and/or tons of wasted money!
Apr 26, 2016 | Refrigerators
Water leaking from bottom freezer ice builds up
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 05, 2011 | Maytag 25.6 cu. ft. Wide-By-Side...
Fridge/frezer not cold,only at the bottom,act like fan that blows across coils is not working,how do I fix
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 04, 2011 | Maytag 25.6 cu. ft. Wide-By-Side...
Kenmore sidebyside 106 is freezing wide open on freezer side and barely cooling on frig side. there is ice in venting on the frig side
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Jan 25, 2011 | Kenmore 53642 / 53644 Side by Side...
Maytag Widey Side not cooling enough
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. If it is that it's going to fill the pan under your fridge and overflow.
Apr 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag Fridge (Model # MZD2766GEW) not cooling
Apr 06, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag wide by side not cooling. just prior to this frost build up on top of freezer. Compressor not running.
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. My coil was solid ice.
Apr 05, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Refrigerator double door side by side
Friend,
ngfam1 At your service!
Sounds like a Thermostat problem!
How old is the fridge?
if the fridge is 10 years old or more you may not be advisable to put good money into bad! New fridges are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Aug 28, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
