Nokia 5800 XpressMusic Smartphone Logo
Posted on Jan 15, 2011
My phone keeps calling random ppl from my contacts, it cuts calls off by calling the person im speaking to, sends blank txts then locks the keyoard so i cant type txts, voice command starts by itself then goes straight to call someone
Anonymous
Level 1:
New Friend:
  • Contributor 72 Answers
  • Posted on Jan 25, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
72
Questions
Helped
6305
Points
8
You could try backing everything up and doing a master reset, but back everything up first (its so important I said it twice). to do master reset just dial *#7370# and accept. after the master reset you can restore your files by restoring it from the back up.
I hear a random clicking sound when im on the phone but the person on the other end doesn't hear it
View topic - Loud clicking noise randomly during phone calls - Ooma
www.ooma.com/forums/viewtopic.php?f=4&t=13207
Jan 19, 2012 - The clicking noise can only be heard by myself ... ... Loud clicking noise randomly during phone calls ... I have not tried calling from a landline.
Weird Popping/Clicking Noise during Call ' MacRumors Forums
forums.macrumors.com > ... > iPhone > iPhone
Jul 4, 2010 - I have experienced the same popping and clicking sounds. .... I want tohear if what your phone is doing to see if mine is the same. share.
How can I tell if my Phone is being tapped? - Nathan M. Smith
https://sites.google.com/a/.../howcanitellifmyphoneisbeingtapped
May 4, 2010 - I have heard clicks while talking to some of my friends across the country ... in use and i hear a crackilng sound.. what is going on... im not a criminal....... Even on my cell phone i will hear unidentified beeping and random dial ...
I keep hearing a clicking sound in the background - Tested
My phone won't send/receive calls or txts. NO SERVICE
what you need to tell the service provider is that to delete the vLR on they network then add it again
Phone wont send or recieve txts
On every phone there are settings that can stop you sending texts. However all phones should still receive texts even if all the settings were changed. As the text message is directed to you mobile number you should still be receiving?
When you compose your text and select contact does the phone move them to the out/sent box?
Settings to check for sending are your 'message centre number' (your network provider can supply and they are normally different for pay monthly and pay & go) 'Message sent as' should be 'text' (not fax or email etc).
Text problems are common where people change or delete digits from the message centre number by mistake.
If you cannot receive texts i would recommend speaking to your provider for help as it may be your account details at their end? (beyond your control). Hope that helps?
Apr 21, 2009 • Cell Phones
Cuts out
it is problem of connection wire of the flap. take it to ur nearest service center.
2answers
Motorolla br50
This is an issue with the switch/routing system with your carrier and they are the only people that can correct it. Call *611 and speak with tech support, this is easily resolved. Dont settle for less than resolved when you call them. Call from a phone other than that cell.
E900 keeps cutting out
Cutting out as in the person on the other end of a call is dropping, or the phone is turning itself off.
Call dropping problems are usually signal strength issues, affected by location, phone model, the mobile network your connecting too, the charge on the battery.
Phone randomly turning off is general a handset fault. return for warranty repair
Message problems
call you mobile service provider and ahve them fix the problem, it is a network issue.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
