Sharp Aquos LC-30hv4u
Sir GURU-
My Sharp LC-30hv4u won't power up and red led flashes four times and repeats. Can you tell me what error code this represents? Local shop want's $100 to diagnose this problem and I suspect the repair charges will be more than the TV is worth. Please e-mail treid(at)san.rr.com
  • 1 more comment
  • treid Jul 14, 2008
    The display fits tight in a cabinate and heat builds up behind. It seems like there was a fan noise before but not now. I do not have a surge protector. Is there a vane switch that prevents operation if the cooling fan fails, or it can't get air due to dust in the intake?
    I don't have a schematic and I do not know if the power supply lives in the display or in the AVC system. This TV has a lcd display and a separate control box (AVC). It has two cables going from the AVC to the display. I have a concern that this email has been routed to your rear screen projection team. I don't know how that happened.
    HAI,No vertical Deflection (V STOP), Screen goes to a single horizontal
    line then the video signal muted. Check IC1509, Q1505,CAPACITORS.
    Are you saying that the four flashes from the red power led indicates this? There is nothing at all displayed on the screen. No white line. The led comes on green, thinks for about five seconds, then flashes red four times and repeats.
  • 47 Answers
HAI,No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505,CAPACITORS.
Posted on Jul 14, 2008
    Master:
  • 497 Answers
Check power supply secondary outputs.
· If voltages are present and at proper the level, then the problem is in the Vertical deflection drive
circuit.
· If the secondary voltages are low or missing, then the problem is in the power supply.
  • Yaz  S
    Yaz S Jul 14, 2008
    and also use an air compressor and vacuume out all the dust
    hope this wrks
    Thanks for using Fixya
    Guru:
  • 1,894 Answers
This looks like a power problem sir.
do you use a surge protector?
  • dewan nafees ahmed Jul 14, 2008
    4 blink means a repair would range around 150.00
    thank you
    ok make sure that you use a surge protector always for the unit.
    use a external fan and try cooling the unit.
    it works many times.
I have a LC-37GB5u, the unit comes on for one second then off then the OPC red LED flashes two times per second. I have replaced the 82uf caps and all four MosFETs. with no change.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Dec 03, 2014 | Sharp AQUOS LC-37GB5U 37" HDTV LCD TV
Sharp aquos LC-30HV4U red light on , does not power up , any ideas ?
I have not had that exact problem, I'm sure you have tried powering off for more than 10 minutes, for some reason that has alway fixed my issues with the same model you have. Good luck!
May 27, 2014 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Flashing red light and
this is a inverter board defective, please send to repair shop, for repair.
Nov 29, 2009 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
The screen and the module both are showing red lights . The screen will not show a picture and I have tried to reset. Any options?
Press the VOL+ and Channel - button on the set and than the power button while holding the two buttons.
If the set starts then the fault is the error counter wich must be reset to 0. Max is 5 faults,if a sixth error is measured the set stops.
Nov 02, 2009 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Can I use the AVC system of a Sharp LC 30HV4U on a LC 37HV4U TV
i have the sharp lc-30hv4u but i dont have tha avc box i need buy the box if do you have i can buy call me 702 3280184 thanks
Oct 15, 2009 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
replace the supply board
or repair it *** there's problem with supply
Jun 13, 2008 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Mar 13, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Televison & Video Logo
169 people viewed this question
Top Televison & Video Experts
Electro Med Services...
