posted by erin_david on Jul 14, 2008
Vacuum's brush does not spin on (low) carpet unless switched to "high" but then roller does not pick up hair on carpet. Belts are in good condition. Maybe belts are loose?
Solution #1
posted on Jul 15, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40485&thid=782631
No spin
Posted by erin_david on Jul 14, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Your problem is that you may need to change the belt every 4 to 6 months as a recommended belt change on the vacuum and also keep an eye on the brushes or brush strips; they also help in the vacuum working properly. Here is a typical belt change on a Hoover. Normally there are screws, clips or levers that would remove the bottom plate or if that does not work then the top cover will come off and that will expose the belt. Once that is off and the belt is exposed then cut off the old belt and then lift up the brushroll on the pulley end and install the new belt around the pulley end and re-install the brushroll. Then use a belt puller or a screwdriver with a bent right or left end to stretch the belt onto the motor pulley and then track the belt in a straight line and reverse you steps in the reinstall of the top cover or bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
No spin
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Hoover U6437-900 / U6439-900
Email this problem
Email this problem
Can you Help with these Vacuums problems?
Hoover U6437-900 / U6439-900 Windtunnel...
Wind tunnel not picking up when...
I am unable to get my... Answer This...
Hoover Windtunnel shuts off
My Hoover Windtunnel shuts off... Answer This...
bag lid assembly wind tunnel...
I need this bag lid assembley.... Answer This...
Brush Roll belt won't engage on...
I replaced both the flat belt... Answer This...
Repair Service
Find Vacuum Repairman Near You:
