Recently I noticed the directions that indicate if the turn is to the left or right is not stated. Is this normal? I do not recall this being an issue until recently.
The voice states everything up to "right" or "left" so you can tell something is missing in the sentence. later it will start working again.
Have you tried a hardware RESET? The button is hidden behind the front panel, which snaps off by a fingernail slot located directly under the GARMIN logo on the front panel. * Use caution removing and reinstalling the front panel... it's somewhat fragile.
If this does not help, you need to try to run all updates (there may be several!) using Garmin's Webupdater. (Connect to computer with USB cable first.)
Hope this helps!!
